Question about Hinge Saws
I need a upper wheel shaft hinge part no. 45-2 for a WA-14M band saw sold by C.I.I. in 1992. Is it the same as Part no. 45-2 HINGE/SHAFT ASSEMBLY UP. WH., 1314330452 for a KC-1433FXR?
4 Suggested Answers
  • 4088 Answers
SOURCE: i need to find a shaft hinge for a model JWBS-14CS
Take the part to a competent welding service. Good luck!
Posted on Jun 25, 2010
SOURCE: very old craftsman band saw model#103.24280
I just acquired a 103.24280 Sears Band Saw, but I don't see that part number. I would be willing to sell you the part if I knew what it was. Don@BuxMontHomebuyers.com
Posted on Sep 12, 2010
  • 32 Answers
SOURCE: I have a #1030103 Craftsman band saw with a broken
I don't know if this will help but I remember seeing a site that talks alot about older saws like the 103. it was under antique/vintage bandsaws. also bobvilla.com may help. Good luck its a good saw.
Posted on Oct 26, 2010
How do you remove the upper wheel on a craftsman 12 inch bandsaw
Check with bandsawmanuals.com if they have the manual for your band saw. You might want to try these steps. First, you need to unplug the saw and remove the band. Then remove the outside snap ring.
I am not sure but you might have to remove the self locking screw in the shaft.
Once the snap ring is removed, you should be able to remove the wheel and the outer bearing.
Then remove the back bearing from the shaft. Next, install the bearings in the reverse order.
Aug 29, 2014 | Craftsman 113.243300 & 113.243311 12" Band...
How to put together the drive shaft assembly on a Grob 4V - 36 vertical band saw
I suggest you to check the operators manual. If in case you don't have the manual, contact Grob's technical assistance or you can get a manual available online. I got old manuals from bandsawmanuals.com but they don't have available manual for 4v-36 . By the way, I like the solid build saws from Grob, what's your usual cutting workload? I have 7x12 band saw with a Haltbar band saw blade from sawblade.com ,I cut structural steel, channel, angle, tube, plate, pipe, round bar,
Dec 27, 2013 | Grob 4V-36 - 36" Throat Band Saw
How to put together a drive shaft on a Grob 4V-36 verticle band saww
Here are a couple of links than might help: http://industrialmanuals.com/grob-4v36-band-manual-grob-series-manual-p-171.php
http://industrialmanuals.com/grob-operators-instruction-series-band-machine-manual-p-998.php
I included the 24" as they are mostly the same in design. One is just, well, generally bigger. I imagine with and exploded parts view you should be able to figure it out
Saw motor runs fine. output shaft stops under load
I don't have any personal experience w/ band saw output shaft failure. This is kind of technical but I suggest you to check with a repair man or you may download a manual bandsawmanuals.com . They have free manual for Dayton 2LKU1 . Hope that helps.
Aug 19, 2013 | Dayton Wire Wheels DAYTON 2LKU1 Miter Band...
I have a craftsman band saw model 137224120 and need a shaft for the lower wheel and tried to order one and this part has been discontinued, any idea where to find a replacement one
I have the same saw and my shaft was also worn out. I was frustrated that there is no replacement part. Here's what I did (and it's worked great - so far): I put JB weld (metal epoxy) on the worn section of shaft and let it cure overnight. I then chucked the shaft in my drill press and ground the JB weld back to the correct diameter by holding a metal file against it. I polished it smooth with some 800 grit wet/dry sandpaper. Replaced it in the saw and it works with no wobble.
Feb 27, 2012 | Craftsman Saws
The problem with this saw is that the bottom wheel seems to move the blade forwards almost slipping off.
If you are talking about a band saw, the lower wheel is not usually adjustable. If it is running off of true perpendicular, then investigate the lower shaft bearings and the wheel mounting to the shaft. Normal adjustment is corrected with the upper wheel tracking adjustments. Hope this helps!
Jan 23, 2011 | Garden
Blade comes off
The wheels are not parallel to each other causing mis-tracking. Check both wheel bearings for any slop. Make sure the wheel surfaces are not broken up. There should be tracking adjustments on the upper wheel. Turn the machine by hand until it tracks perfectly. Make sure the lower wheel is tight to it's shaft. Hope this helps!
May 22, 2010 | Porter Cable 5028 Band Saw Stand 7721 7723...
Top wheel part broke off
I suspect the part you need is 150086 "Upper Wheel Shaft". You can confirm this by checking the exploded diagram for your bandsaw which can be downloaded at http://content.wmhtoolgroup.com/manuals/708115K_man.pdf.
See page 25 for exploded diagram showing wheel shafts, bearings, etc..
It might be worth checking with JET about warranty since I believe that band saw has a 5 year warranty. You can check here for a service center near you.
Jan 10, 2010 | Jet 710115K Jwbs 14CS Deluxe 14 Inch 1 1/4...
Saws Logo
52 people viewed this question
Top Hinge Saws Experts
Tom Chichester
ray gallant
Are you a Hinge Saw Expert? Answer questions, earn points and help others
