Question about Frigidaire Ovens
I have Frigidaire gallery oven with an F 10 error code. What does the code mean?
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 6 Answers
A faulty RTD sensor probe is one of the causes for an F10 code or overheating oven. The sensor probe is supposed to detect the exact temperature in the Frigidaire electric range cavity and relay it to the oven's main control so it knows when to shut off the heating elements. Follow your wiring diagram to find the probe's location, which can differ among the models. Inspect it for any obvious damage such as cracks or tears in the wiring.
Posted on May 08, 2017
Is there a reset switch when you are gettng an F20 error code
There are no sort of magic "fix my problem reset buttons" on ANY appliance. Please provide me the model number of your product for the definition of your F20 error code & I'll be happy to help you
May 29, 2016 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire stove error code
F68 = Power Line Failure. Turn power off for 30 seconds. If this does not correct it, check the electrical supply for proper voltage, ground, and polarity, if all of this checks ok replace the EOC-Display board
Aug 08, 2014 | Frigidaire Gallery 30 " Stainless Steel...
F-10 alarm on gallery series
Hi Friend, I am happy to assist you!
Typically error code F10 indicates that your Frigidaire range has detected an issue with the runaway temperature (overheating). Let's attempt reprogramming your range by either unplugging it or flipping the household circuit breaker off. It is best to wait roughly ten minutes and then turn on your range. Usually this will clear most false error codes. If issue persists, at this moment I would suggest contacting a professional to proceed further. Most likely the RTD Probe (Resistance Temperature Detector) or the EOC (electronic oven control) will need replacing. Hope this helps! - Z
Jun 13, 2014 | Frigidaire Ovens
F10 code after frigidaire wall oven on for 15 minutes
Good Morning Dave, thank you for allowing me to assist you!
If you are getting error code F10, it typically means that your range is experiencing an issue with the runaway temperature (overheating). One of the best ways to determine if this is a false error code is to reset the power to your range by either unplugging it or flipping the household circuit breaker off for about ten minutes. If the error code persists, I would be advisable to reach out to a professional to proceed further. Most likely the RTD (Resistance Temperature Detector) or the EOC (electronic oven control) will need replacing. Hope this helps!
Nov 21, 2013 | Frigidaire 30 in. Electric Gallery Series...
Flashing PF 32 error code
Hello - This manufacturer does not show to have such an error code for a wall oven. However the error codes F30/F31 indicates that the unit either has an issue with the oven sensor, wiring with the EOC or the probe connections is open or shorted. Contact a professional to move forward accurately.
Nov 10, 2012 | Frigidaire 30 in. Electric Gallery Series...
How to unlock the frigidaire oven range door and remove error F3?
How do you adjust the oven door on a Fridgedaire Gallery Series gas stove?
Jul 13, 2009 | Frigidaire 30 in. Electric Gallery Series...
F7 error code- what does this mean?
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
Display Condition Remedy
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
May 17, 2009 | Frigidaire 30 in. Electric Gallery Series...
F10 Error code on double oven.
Sir,
Check out this link
suggest to reset it by shutting off both main breakers to the stove , wait for one minute and switch breakers on again.
Thanks Good Luck
Appreciate to rate as "Fixya"
May 15, 2009 | Frigidaire 30 in. Electric Gallery Series...
-F9- Clean Frididaire Gallery Series
F9 code means Control has detected a problem with the motor door latch assembly Soultion: Check wiring, replace the motor door latch assembly if necessary
May 06, 2009 | Frigidaire 30 in. Electric Gallery Series...
Ovens Logo
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
