I have the following hard drive HITACHI HTS541040G9SA00 40G sata 5400rpm which is defunct and I want to replace it with a compatible upgrade of 80G? The hard drive is from a Toshiba Equim M70-337 Please can you advise
  • 21 Answers
It's just a 2.5 SATA drive so any drive will more than likely do.....don't lock yourselft ito 80GB when there are 320, 500, etc out there. What is most important is the largest drive your system BIOS will recognize....which most ROMs can be flashed for compatability with newer larger drives.
Check with your Laptop Manufacturer Support Site to see the largest drive supported by your BIOS and if there are any updates.
If you have your hear set on the 80GB Hitachi take a look at the Spec sheet (more like a book)from Hitachi at the link below which provides specs on the 20, 40, 60, 80, and 100GB drives: http://www.hitachigst.com/tech/techlib.nsf/techdocs/28DCCB17E0EEC5A086256F4E006E2F5B/$file/5K100_SATA_sp1.2.pdf
Replacing a hard drive in a Laptop is probably easier than replacing a light bulb, IMO.
Posted on Jul 25, 2009
What replacement soiled state hard drive for WD1200BEVS-22LATO
Examine the interface specifications for the what the HD is connected to. Most 120 MD SSD's are backwards compatible with SATA-150. Usually the specification with say SATA-II (3MB transfer speed) or SATA-III (6MB transfer speed). A SATA-III SSD will work on a SATA-II connecction.
Jul 08, 2014 | Western Digital WD1200BEVS-22LATO Scorpio...
Cant access HITACHI TRAVELSTAR 5K250 HTS542516K9SA00 160GB drive
If the drive cannot be accessed then the logic board on the hard drive is toast. U can remove the sata drive and install it into a working desktop with sata connections and see if the desktop recognizes it.
When installing on another computer, make sure that you are still booting up from the working sata drive originally there. If you change the bootup sequence to the allegedly non working drive and it does work you may corrupt the operating system in the bootup process. Just put it in there and see if the other computer boots up and recognizes it. Often if a hard drive is really bad the defective unit will prevent a good working computer from booting up at all.
Nov 22, 2013 | Fujitsu "HITACHI TRAVELSTAR 5K250...
I want to upgrade the hard drive on my Advent 6001 laptop to a 250gb one. How do I then copy Windows onto the new hard drive as the laptop doesn`t recognise the CDROM as a boot device, not even in the
Running under the assumption that the CD is actually working, have you checked the BIOS settings to indicate that you want the CD to be the first boot device?
Alternatively, some if not most systems will accept an F12 during boot up to query the user where to boot from.
Jan 06, 2018 | Hitachi Travelstar 5K100 HTS541040G9SA00...
Sata drivers for win xp
If you use a XP SP3 install CD it should include the sata driver.
Sep 14, 2012 | Hitachi Travelstar 5K100 HTS541060G9SA00...
Is there a jumper setting to run my hitachi 250 gb sata laptop hdd as a slave ?
There should be, look on the rear of the drive, close to the SATA and power connectors, you should see the jumper connections as well.
It varies from drive to drive, but the jumper setting could be engraved near the connector, look of SL for a slave setting.
If no, look on the label on the top of the drive, there should be the jumper settings listed there.
Some may be ambiguous, my last one offered the option of Master on / off. (Jumper in position 1 for on, no jumper for off) The off in this case was of course slave.
The result being, no jumpers - Slave.
Mar 26, 2011 | Hitachi 250GB Hitachi 2.5" SATA Hard Disk...
Which of Hitachi Hard discs could be a better replacement for model HTS541080G9SA00???
Just choose Hitachi Travelstar 320 GB, 5400 RPM, SATA , 2.5'' for convenience files storage.
Dec 19, 2010 | Hitachi Travelstar 5K100 HTS541080G9SA00...
How to download the driver of Hitachi Travelstar 5K100 HTS541060G9SA00 ? plz plz help me
I am not familiar with Linux but have you checked your Bios to see if Sata Hard Drive is recognized in there??? Most of the time you have to set the bios to recognize a Sata drive because 90% of Hard Drives are still IDE and most bios software is still recognizing the IDE drives. I know I had to reset everything on my Motherboard and Bios when I changed over from an IDE to SATA Hard Drive.
Nov 01, 2010 | Hitachi Travelstar 5K100 HTS541060G9SA00...
I am replacing a Hitachi Travelstar 5K100 HTS541080G9SA00 80GB with a Western Digital 500GB SATA 3Gb/s Hard Drive 8MB 5400RPM 2.5IN Scorpio Blue. A tech told me to use a cloning software to switch the...
You would need to use a "usb" to hard drive cable. It looks like this: http://gizmodo.com/168149/brando-sataeide-to-usb-20-cable
Then, it is simply a matter of "cloning." The other alternative is to find a pc repair shop with a hard drive duplicator. It will copy much faster.
Please rate if you find this helpful.
Sep 20, 2010 | Hitachi Travelstar 5K100 HTS541080G9SA00...
Upgrade hard disk :SATA compatible with SATA2 ?
Dear,
Yes, You can install a SATA-II hard disk in it. There is no problem.
Regards,
Rakesh Kumar
Apr 06, 2009 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
Computers & Internet Logo
114 people viewed this question
David Payne
David Payne
