Question about GE Kitchen Ranges
The lower Baking Drawer of My GE Cafe Range with Baking Drawer Model CGS980SEM6SS. does not turn on. The knob turns and clicks but the light does not light up and the drawer doesn't heat up.
SOURCE: removing freezer drawer
my son fixed it - thx. problem solved
Posted on Nov 24, 2008
RescueTech
  • 145 Answers
SOURCE: f2 flashing on lower drawer
F2 means "motor not sensed to be rotating"
You said "very rarely used" also. The two go hand-in-hand in most cases. If you leave the drawer sit unused for months and months, this can ruin the motor rotor. The rotor comes out with no tools. Remove the dishrack, the wash arm (both simply lift off) and then the stainless steel filer/cover. This is removed by rotating the collar counter-clockwise and lifting it up. Now rotate the collar for the rotor counter-clockwise and lift the motor rotor out of the pump base. See if it spins freely. it;s probably frozen. You also can try swapping the rotor from the upper drawer into the bottom and see if that will work for you. if the rotor is bad, it is a part number 525884P and you can get them here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=231
If you find this info to be accurate and correct, please rate my answer as a FIXYA.
Thanks...
Posted on Feb 08, 2009
SOURCE: Unable to close the bottom oven drawer (Kenmore)
Pull the unit away from the wall and in most cases you can reach in the oven pan from then rear. If not.....pull the unit away from the wall and then lift the front about 3 inches away from the floor and let if drop....thus shifting the items in the drawer....If I can help further, I am here
Eric Campion
Posted on Feb 23, 2009
  • 19 Answers
SOURCE: Fisher Paykel DD603 Problem. Top drawer shows F1
Yup, definately the bottom drawer controller, for some reason you can run a DD603 with no board in the top, so long as you have a board in the bottom, but not the other way around. This is the fault you get, constant F1 from the top drawer. If you are stuck try removing the display cable from the bottom controller, this may help, so long as you leave the chassis harness in.
Posted on Dec 09, 2009
SOURCE: Oven shuts off while baking. No error code, it
I have the same problem. GE repair man replaced the electronic control panel. If anything, the problem is worse. Does anyone know what ACTUALLY makes this range shut off as it gets up to temperature while baking? I don't really want to pay the repair man to fumble around debugging this.
Posted on Jan 03, 2011
I need to know the btu input for a ge cooktop (gas) model gejgp975sekss
I see if I can find a diagram, ensure you posted right model number here.
Aug 29, 2008 | GE Kitchen Ranges
Oven shuts off while baking. No error code, it just shuts off and none of the buttons work on the GE Cafe range.
Aug 24, 2010 | GE Cafe CGS980S Kitchen Range
I need a thorough description of this kitchen range GEC2S980S; number of burners, size, available colors, price, etc.
Visit the ge appliance web site and Key in your model number C2S980SEMSS and you will get a complete breakdown of all specs and features as well as the ability to look at specific dimensions and product installation the guide.
Try this link:
http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=C2S980SEMSS
Aug 18, 2010 | GE Cafe C2S980S Kitchen Range
Knob goes around but does not stop. have to be careful when turning stove off? What is the fix
Depending on which switch. Either the stop is broken or return spring is not functioning needs new switch in either case
Feb 08, 2010 | GE Cafe CGS980S Kitchen Range
GE electric stove problems, our stove has 3 small burners and one big burner. When we use the big burner at medium heat it does fine then all of a sudden it starts glowing bright red and burns whatever is...
Replace the infinite heat control switch for that burner. (the burner switch that you turn with the knob to select the temp setting) If you list a full model number (usually behind the lower drawer panel on the frame of the range) I can look up the part number for you. It is not a very difficult repair.
Oct 11, 2009 | Kenmore 95592 / 95594 / 95595 / 95599...
GE spectra xl44 - Oven not working, broiler & stove-top burners fine
replace the ignitor for the oven. it's the lower one and not the one on top.
Oct 28, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven fire
wrong call ge@ 100-851-6200 and they will help you have the model number handy before you call
Apr 21, 2008 | GE Profile 30" Free-Standing 5 Burner Self...
Baking Element Caught fire
this a common complaint when the element burns out it is scary to see but all you need to do is replace element
Burner will not turn off
I will need the complete model #. There should be a sticker near the bottom front behind the drawer. Can't use the # that is on the owners manual.
Oct 08, 2007 | GE Spectra JBP78 Electric Kitchen Range
Kitchen Ranges Logo
41 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
