Question about Refrigerators
Refridgerator not cooling compressor is running but not cooling
    Top Expert:
  • Refrigerators Master
  • 12,962 Answers
If compressor running but not cooling it is very likely that you have no or little refrigerant in system. U can confirm this by using an ammeter and taking a measurement of current consumption. It will be less than spec since the compressor is not compressing or doing any work.
Posted on May 08, 2017
Refrigerator not cooling properly
There are several things that can cause cooling problem with your refridgerator. The first and most common is dirt dust and lint clogging the condenser coils. These coils are usually located underneath the refridgerator and have a small fan that blows air across them. If they are clogged, the refridgerator cannot get rid of the heat to allow it to cool properly. To check and clean these coils you must first pull out the refridgerator and unplug it. Remove the lower panel ( usually made of a cardboard material) this will give you access to the compressor and fan and coils. Check the coils for dust,dirt and lint. Clean out carefully with a vacuum cleaner or brush( you can get a brush specially made for this ) check the fan motor to see if it spins freely( some units may not have a fan) plug unit in to see if fan runs (make sure to temporarily turn thermostat down colder to turn on compressor and fan). If fan does not come on with compressor you may need to replace it. Put unit back in place and see if that solves the problem. If this does not help, you will probably have to have a appliance repairman check out unit.Hope this helps.
Dec 15, 2013 | Maytag Refrigerators
It is a frost free refridgerator, but it frosts up and the refridgerator part doesn't cool as well. I end up having to "defrost" the freezer by turning it of or running a hair dryer in it to rid...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 16, 2011 | Refrigerators
GE refridgerator won't cool
First of all check and see if the compressor is running and if not is it very hot to the touch. If the compressor is not running but hot then the compressor is either locked up or is cycling on its internal thermal overload. If this is the case then either the condenser fan motor is not running and/or the condenser coil is very dirty. If the condenser coil is dirty you need to blow it out with compressed air(watch out for all the blowing dust). If the compressor has been cycling alot on its internal thermal it will eventually lock up permanently and you will need a new compressor. I hope I was of some assistance to you!
Nov 12, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
The refridgerator runs but does not cool or freeze anything. There is a clicking noise everytime it tries to cool.
sounds like the compressor has seized and the click is the relay starter to get it going. if it is running and getting very hot the likelyhood is that there is a refridgerant leak.
Mar 13, 2009 | Whirlpool 21.7 cu. ft. Side-by-Side...
Maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Jun 20, 2008 | Maytag MSD2651 HE Side by Side...
MY refrigerator is running but is not getting cold.
This has several issues you might need to look into.
First, your refridgerator you selected shows it is a front load washer. I know that can't be right.
Second. Your temp setting. It should be set in a manner that allows the humidity to exhaust out.
Third, Your refridgerator compressor is about to go out.
Fourth, you are placing alot of warm food into refridgerator, and holding the door open too long. This sometimes shuts the compressor off.
Also peer behind your refridgerator. Is there alot of debris, dirt, brooms, etc behind there. If so clear it out completely.
On the front of some refridgerators there is a grill that can be removed carefully. You will see cooling fins on the inside of this.
Very very gently remove the dirt and debris off of this. The fins bend very easily, so becareful.
At the same time check drip pan, and empty if needed.
If none of these things seem to do the trick, contact a service technician, something tells me it is your defrost sensor, or compressor.
May 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Refridgerator does not cool
It has a bad relay on the compressor. Looks like your model is a 50552 Kenmore. If so the part # you need is a 8201799 (start device) cost is $45.96 and you can get it at http://www3.sears.com/ or any local appliance parts house. It is # 16 on this diagram http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0165000&brandID=0582&modelDesc=SIDE-BY-SIDE%20REFRIGERATOR&modelNumber=10650552000&documentID=P0070128&documentTypeID=PLDM&documentClassCode=PM&titleType=UNIT&titleID=00011&
Nov 07, 2007 | Kenmore 50522 / 50524 Side by Side...
I have a ed5fhgxkq00 side by side Whirlpool refridgerator that stopped cooling. It worked fine up until last night when we noticed that the ice was melting. Now it gets a little cool but not cool enough....
If the compressor has a fan next to it, be sure it is running. if the relay is clicking every few minutes it may need to be replced. contact local parts distributor.
Nov 04, 2007 | Whirlpool ED2FHSS Side by Side...
How to troubleshoot amana refridgerator
the evap fan, fan by compressor and the compressor should all be running. if they are then more than likely a bad compressor, so junk it
Oct 30, 2007 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
