Question about Dishwashers
Hi, I have a Delonghi DEDW645S dishwasher with an E1 error code. Would this be related to the Aquastop inlet solenoid?
  • 110 Answers
SOURCE: E1 error on LG - LD-4120M
E1 is a common error in the LG Dishwasher range and is usually caused by the failure of the circulation pump and/or the impeller.
The motor and impeller are a complete unit.
Often what happens is the impeller breaks on the motor shaft and doesn't spin, therefore doesn't pump water.
There is a pressure sensor which indicates the lack of pressure and shuts the machine down with the E1 error being displayed.
The lack of pressure can also be from a water leak (as the owners manual suggests) also a controller PCB fault may produce an E1 error, however, the pump problem is extremely common.
Unfortunately, I have had 5 pumps die in 4 years and my dishwasher is only used about 4 times a week.
Posted on Dec 27, 2007
SOURCE: Delonghi dishwasher won't drain.
I have the same machine with the same error message but my machine has drained it self but will not continue the cycle?
Posted on Nov 15, 2008
  • 423 Answers
SOURCE: What is an E1 error code for an LG Dishwasher? Model LD12AW2
Please check at both ends of the drain hose and confirm that you do nit have a leak. Also, please confirm that water is not leaking directly under the dishwasher.
If you are certain that you do not have a real leak, check the impeller (under the mesh filter in the sump area beneath the lower dish rack) is not damaged and is firmly in place.
The E1 error code is a Leakage Error, detected by the motor spinning faster than it should if the unit is filled with water.
Please report back with what you find. Good Luck!
Posted on Mar 30, 2009
SOURCE: how to reset error code e4 on delonghi dishwasher
Remove all dish trays from washer, unscrew and remove lid off salt softner, tip machine on side untill all water drains from the salt softner, replace all trays and softner lid and machine should work again.
Posted on Apr 18, 2010
SOURCE: how to clear a delonghi dishwasher error code 4
Try removing all dish trays and salt softner lid, check if the salt softner compartment is full of water, if so place the machine on its side and allow all the water to drain from the compartment, once this is done your machine should be good to go. This is how i resolved my problem. The salt softner is located next to the water drain filter.
My miele dishwasher keeps taking water as soon as I close front door (even when program has not been started yet) after while it displays F18 fault and starts draining
Find out what the error code F18 represents. Owner's manual troubleshooting section is a good place to look or search for it on the internet.
Mar 07, 2016 | Miele Dishwashers
Delonghi Dishwasher
Can you please tell us the exact model of your dishwasher? What you can try initially is unplug the power cable of your unit for about 10 minutes, then plug it back in. See if that clears the error. Will give you follow up about the E1 error.
Oct 26, 2008 | LG 24 in. LDF 7811 Stainless Steel...
What does the F7 code mean for my whirlpool dishwasher ADG6230
F7 or 7 times flashing
Flow meter failure
Symptom:
Water inlet valve (WV1) is switched on and the water indicator (WI) is on (level reached).
Reason:
  • Water tap closed during water inlet
  • Water inlet hose blocked
  • Water inlet valve (WV1) defective (mesure resistor ca 3,5 kOhm)
  • Flow meter (FM) sends too few / much pulses (less than 10 imp. in 10 seconds). Flow meter counts wrong (or the sump is full in less than 30 second).
Causation: Hose felt down and slipped the disc of the valve. The effect is a displacment of the valve tapped.
  • Aquastop defective
  • Flow meter (FM) defective
Dado
Feb 17, 2015 | Whirlpool Dishwashers
Kenwoodkdw12st3a error e1
Most likely the water inlet pressure is low or the tap under sink is not open fully. If you are not getting any water into dishwasher at all, then the inlet valve might be faulty.
This is what you will need.
http://www.espares.co.uk/product/es1560548/dishwasher-single-solenoid-valve?ModelId=1557445
Apr 07, 2014 | Dishwashers
LG dishwasher error code E1
E1 is a code that the dishwasher displays after detecting a leak. There is a sensor on the pan at the very bottom of the unit. Take the bottom front panel off, look under the unit at the hose coming off the pump and your fill line to be sure no water is dripping. Run the unit in a wash cycle while doing this if possible.
Nov 21, 2017 | LG Dishwashers
When starting wash cycle the dishwasher cda cw447 doesnt appear to be getting enough water in and is making a droning / whirring / electrical ? noise. pipes all connected ok inc aquastop water supply unit,...
Try removing the inlet pipe, and refitting, might fix it, else likely that the
Inlet water soleniod failing/failed or tiny mesh filter (it does come out for cleaning) behind the inlet hose clogged. Temporaily bypass the aquastop water stop unit; it might be the culprit!
A replacement solenoid is usually only about £10 from www.espares.co.uk, or ebay sellers (no connection with these but they are very good), fits in minutes (2 or 3 electrical spades ,and a posidrive or two) and usually fixes all water related problems. the noise you can hear is probably the solenoid trying to actuate, will be droning/buzzing sound.
could simply be stuck with some foreign matter in there that's got through the mesh filter but unlikely. they normally fail and sound terrible.
Don't throw your dishwasher away for the sake of a £10 part.
Good luck
Sep 12, 2009 | Dishwashers
E1 error code on my kenwood dishwasher [kwd243a
Hi
The E1error code indicates a water inlet error.
To access test mode: press and hold Normal+Eco, and press Power. Release buttons. Then press Start(display n:01).Press Start again (display shows water level frequency-not important). Press Start again-(display n:03-motor will be running). Press Start again (display n:04-drain pump will run). Press Start again (display n:05-inlet valve will come on and machine should fill with water). You have now tested major components are working-if you keep pressing start you will scroll thru and test other functions, like heater, dispensor etc, but not needed for your fault.
If Machine didn't fill with water in test mode, you probably have a faulty inlet valve (test resistence should be approx 3.7-4 k ohm).
If inlet valve has tested OK ie machine filled with water in test mode then:
Disconnect from power.
Remove side panels (need to remove top, and bottom front panel to then be able to remove sides)
- Check no water in base of machine-water in base will indicate machine has leaked and activated the safety device which shuts off inlet valve.
- If OK, you probably have a faulty flow meter(measures water intake). Located left hand side of machine, large plastic compartment, which has a sensor at the bottom with 3 wires (red,white,black) that go up to control board. Replace entire flow meter assy-relatively inexpensive part.
- If you still have problem, then control board is faulty, it is much more likely to be flow meter .
Thanks for contacting fixya.com
Sep 10, 2009 | Dishwashers
Meiko dv80.2 error 201
Error code 201 Indicates the incorrect water level...in that the level was not achieved during filling...check the following.
Correct water level was not reached during initial filling.
Check that the water hose is correctly attached and is free of “kinks” or pinching. Also check that the water supply is turned on.
I hope this helps...thanks for rating my effort....the Fang
Jan 30, 2009 | Meiko DV 80.2 Dishwasher
Hoover dishwasher error codes
Hi we have a Hoover DT999 and according to the manual for that machine error E1 is water inlet tap turned off
Dec 18, 2007 | Dishwashers
Dishwashers Logo
71 people viewed this question
Top Dishwashers Experts
