Question about Refrigerators
I have an MT23 fridge, the fan runs 24/7 is that an issue?
Hotpoint FF72P Fridge Freezer, fridge not cooling
Before changing my the thermistor. Is the Evan fan running? Is their anything blocking the vent? Check those things before replacing the thermistor. If the fan isn't running you have a bad fan or bad control. If something is blocking the vent then you have a clogged drain or need to remove buildup from vent
Aug 25, 2016 | Hotpoint Refrigerators
Fridge side too warm, loads of water underneath
replacing evap fan motor, or how to disassemble and troubleshoot ge refrigerator.
Aug 20, 2015 | GE Profile 21.6 cu. ft. Side-by-Side...
Should fan run constant on indesit ban12fn fridge freezer?
It should shut off when it reaches the correct temperature. If you have the temp set to low it could cause it to continue to run or if there is an issue with the fridge that could also cause this issue. Keep in mind after a defrost it will take some time for everything to get back to the correct temp so it may run constant for a long time.
Jun 09, 2015 | Indesit Refrigerators
Mini Fridge is on but doesn't get cold
Good Afternoon Corey - When any refrigerator is tilted or on its side it needs to be in an upright standing position for approximately 24 hours before being plug in. The freon has to travel down in the lines and it will not function properly until it does so. Locate the unit in a room temperature environment and once the unit is plugged in, it is recommended to wait another 24 hours to place food inside for the temperature to stabilize. Once the compact refrigerator is in operating mode, both the fan and compressor should be running. If it does not, then the unit may possibly have a faulty compressor, relay or sealed system issue. Because it is a smaller appliance, repairs are often more costly than the actual unit replacement because they may or may not have parts available.
May 17, 2013 | Refrigerators
Fridge not cooling, compressor running constantly
is the evaporator fan running ? good luck APPLIANCES R EN
Mar 15, 2013 | Candy CPC220 Bottom Freezer Refrigerator
My sub zero service light and EC 24 are flashing, fridge is getting warmer...suggestions?
The ec 24 alarm is from a sensor that is located behind the freezer wall and connects to the control board in the ref. When the temp gets to a certain point the sensor will trip giving the alarm. If the temperature in the freezer is gone up but is around the 20 -30 degree F range, I would remove the grate that covers the compressor and check to see if the fan is running and if the coils are dirty. Either one of those can cause temps to go up. If the fan is running and the coils are clean, Call a service company because you possibly have a sealed system issue
May 06, 2012 | Sub-Zero 632 / S
Freezer works, fridge does not. Also the sides of the fridge are really hot but not up the top near freezer section. Fridge has recently been moved. Thanks
Warm sides are usually caused by the condenser fan which is underneath around back not running. If it's not running when the compressor runs it will cause the problem you describe. You will need to remove the cardboard backing on the back of the fridge to access the fan.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
When it was moved, was it laid down? If it was it should be stood upright for 24 hours before being plugged back in.
Feb 13, 2010 | Refrigerators
Freezer very cold fridge warm.
does the fan come on if not then the fan delay is bad
May 25, 2009 | Refrigerators
I have an Amanda side by side, the fridge temp
Look in the freezer side for a ice buildup on the back wall.
Ice= defrost parts issue.
Check the fan in the freezer. Is it running?
Not running? Could be a defrost thermostat issue or a bad fan motor.
Mar 03, 2009 | Amana ASB 2623 Side by Side Refrigerator
Frgidaire side by side fridge not cold freezer is good
Fan needs to be replaced. Common issue and easily done. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Nov 30, 2008 | Frigidaire FRS26ZSG
Refrigerators Logo
19 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
