How do I get the phone number for manufacturer for parts
My wind sensor no longer works the cups do not spin freely I need to replace wind sensor
  • 1116 Answers
SOURCE: The endless bobbin winding no longer works
Why not use the manual wind or a prewound bobbin and not use the endless wind feature?
Posted on Mar 05, 2010
SOURCE: I have a WD200 wind vane unit. I need a cup
Unfortunately I don't have a solution, but I've got exactly the same problem! Did you find it from somewhere eventually? If you did, where? Or if you found a replacement cup assembly, what it was? Would be very grateful of the reply!
Posted on Mar 23, 2010
cmccune04
  • 213 Answers
SOURCE: Looking for the cup insert part that the
If you’re looking for Keurig Parts, you can find them on this website.
http://www.igotsweetdeals.com or http://stores.ebay.com/Igotsweetdeals
They have every Part for Keurig b30, b40, b60, b70, and b77. If it’s not listed currently and they can have it posted the same day! Even K-cup holder assemblies and water reservoirs!
Posted on Apr 18, 2010
SOURCE: Need part for an old whirlpool cooktop model number SC8900EXB1
SC8900EXB1 Whirlpool purchased 1999 when house was built. Electric wires to start the burners, started smoking, burnt? Shoud I replace the entire cooktop, if so need comparable system purchase and installed ASAP.
Posted on Aug 16, 2010
Ironfist109
  • 3018 Answers
SOURCE: My Anemometer has stopped working,
I am a trained storm spotter as well as a storm chaser. So I use Anemometers all the time during the warmer weather when severe storms occur. You may not need a new module but rather a calibration of your system. Something like this would do you http://www.tsi.com/en-1033/products/3734/thermal_anemometry_system/3752/automatic_velocity_calibrator_with_pressure_transducer.aspx However if you don't want to go through all of that then many Anemometers have a model that can be replaced. If the bearings are worn you will not get proper wind readings either. Depending on the the overall condition of your current Anemometer you may want to weight your options, pros and cons of repair vrs a new Anemometer.
Regards, Tony
Posted on Apr 08, 2011
Error code E58
If you have a front-load washer that was manufactured by Frigidaire, the E58 error indicates high current on the motor. This could mean that the motor is bad, the bearings that the tub spins on are bad, or a problem with the speed control board. To test this, you'll need to access the motor and tub area of the washer. Unplug the power before opening the washer. Take the belt off the motor pulley and check if it spins freely. If it doesn't, then replace the drive motor. If it does spin freely, check if the large pulley on the tub spins freely. If that doesn't rotate, you'll need to replace the outer tub and spin basket in order to replace the failed bearings. If the pulley rotates easily, you'll need to check the motor windings. If the resistance is between 4-6 Ohms, the speed control board is probably faulty. If the resistance is not in the correct range, the motor is bad and needs to be replaced.
A Frigidaire washer technical data sheet is available here: http://manuals.frigidaire.com/prodinfo_pdf/webster/134542000.pdf .
If your washer is under warranty, contact the manufacturer. If you add a comment with the model number of your washer, I may be able to provide a source for the parts.
I hope this helps.
Apr 27, 2016 | Washing Machines
My Ryobi router is not working at all. It spins
It can be any number of things that cause this:
1. Broken power cord
2. Failed on off switch
3. Failed trigger switch
4, Brush or brush tube assy failure (Most common failures)
5. Open armature winding
6. Open field winding
If you can not get continuity across the power cord with the switch on and trigger switch depressed yhe only option for further troubleshooting is to open the unit.
You can go to this page then click on go to power tools store and under model number use R161
http://www.ryobitools.com/support/parts_batteries
The manual lists all 50 parts in your unit.
Item 16: Brush assy part # 968304-026
Feb 04, 2010 | Ryobi ROUTER KIT P163K
My ac blower does not work I tried the heat but the blower still does not work
Shut the power off to the unit, spin the blower wheel to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
Aug 18, 2009 | Heating & Cooling
Unit only used one year (for 3 months) and stored in basement 2 years. When plugged in it sounds like the cooling part wants to work but the fan will not come on.
Shut the power off to the unit, spin the fan blade to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
Aug 16, 2009 | Heating & Cooling
The blower on our unit works intermitently, so the AC is only cooling part of the time.
Fan does not work
Aug 16, 2009 | LG Goldstar LD65EL Dehumidifier
Duo Therm kicking on the compressor, getting cold, but no fan!
Aug 12, 2009 | Dometic Rooftop RV Air Conditioner
Fan not working
Jul 31, 2009 | Fedders A7DH65B2A Dehumidifier
A/c unit runs but only blows into the house for about 30 seconds
Jul 28, 2009 | Goodman GMS90703BXA Heater
We have a kitchenaid model kaws850gq0 dont wash
dont reeally undserstand question, you can freely turn the agitator freely, in both directions??? with no resistance??? if so you need to replsce the agitator dogs, part number 80040, probly under $20, to replace youll need to remove the agitator form the tub( 7/16 bolt under the fabric softener cup "pop" it off with the palm of your hand!
Dec 08, 2008 | KitchenAid KAWS850L Top Load Washer
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
