Pcp60st60 won't do anything no standby light got a rebuilt p board and still nothing
I have a double elec. whirlpool self cleaning oven with accu bake system It will not turn on at all. everything is just off.
This is often due to a control board failure. The board may be NLA (no longer available). It can be rebuilt with a 2 yr warranty. See:
Aug 29, 2015 | Whirlpool GBD307PD Electric Double Oven
Polaroid 3700 tv won't turn on no standby lights or anything
Check for any loose contact with any of the connection sockets at the power board, to main board. Re-seat them all once and check. Contact any service technician. Gopakumar Gopalan Google
Feb 19, 2014 | Televison & Video
Vizio vw37l hdtv20a standby light on but wont turn on
you either have a faulty power supply or faulty main board. Vizio power supplies on the older sets are pretty decent. It's usually the main boards that go. These older main boards tend to be pricey so it may be better to buy a new set.
Mar 27, 2013 | Vizio VW37L 37 in. LCD HDTV
I have a Sony Bravia LCD tv an it won't turn on at all the standby light is not even there I've tried turning on an off and leaving unplugged for an hour still nothing.? Help,
You either have a problem with your power supply board or main board. I would start with having the power supply fuse checked as well as the power supply board!
Jan 26, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
LG 42CS560 42 Class LCD HDTV won't come out of standby mode.
Could be an open internal fuse or power supply failure
Jan 05, 2018 | LG 42CS560 42 Class LCD HDTV
RC-3910 Toshiba television won't turn on, has flashing standby light?
Missing power supply rails from the main power regulator board to sub boards is the fault. Contact any experienced service technician to get this set repaired, since the work is skilled one.
Jul 11, 2012 | Toshiba Televison & Video
My Kenmark 19" tv won't
The power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like, to buy a whole refurbish power supply board for the replacement.
Hope this will help in solving the problem, do take in handling the fault, because it contains high voltage..
Good luck
Jun 07, 2011 | Televison & Video
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
