Configure camera setup - Computers & Internet
Dlinkap
http://support.dlink.com/emulators/wbr2310/lan.htm
Aug 06, 2014 | D-Link DAP1360 IEEE 80211n (draft)...
Configuring display language, Date and Time Settings.
Perform the reset operation to initialize the camera’s setup (page 136). After that, configure each setting. If the language selection screen does not re-appear when you turn the camera on, it means that the camera’s built-in memory management area has been restored. If the same message appears after you turn power back on, contact your retailer or a CASIO service center.
Main support number800-962-2746
http://www.fixya.com/support/p504372-casio_exilim_ex_z1000_digital_camera/manual-19919
Jan 29, 2008 | Casio EXILIM EX-Z1000 Digital Camera
I can't get this website to work. 192.168.0.253. It's supposed to be the website to configure my BL-131 Network Camera. I got the camera a couple of years ago and just now replaced my router. ...
Replacing the router will not have changed any settings in the camera. The IP address 192.168.0.253 is the factory default for the camera, unless you assigned a new one when you set the camera up.
This is a wired/wireless camera, and if you're trying to connect wirelessly you probably have a router setup issue. Like any wireless device, the camera needs to provide the right key to connect. If you haven't set up your new router's wireless security yet, or set it up with a different key than the old one, the camera won't be able to connect. If the camera's not on your network, you won't reach it and you'll have the problem you described.
The simplest thing to do is to start fresh. Reset the camera to factory defaults with its rear-panel reset button. The button is recessed and you'll need a pen or other object to press it for a couple of seconds. Connect the camera to the router using a cable, and you'll be able to reach it again on 192.168.0.253. Set up the wireless network in your router (assign network name, security key, etc.). Then go through the camera wireless setup steps so it can connect to your network and you'll be back in business.
If you need a copy, you can download the manual and find other information here from Panasonic.
May 28, 2011 | Panasonic BL-C131 Network Camera
Doesnt work wirelessly...
see my other posts on this.
1) remove security such as WEP/WPA and see if that fixs it.
2) ping the device to verify you are talking to it wirelessly. Linksys setup software has major bugs
3) move camera super close to wireless AP as setup software uses different wireless protocol than video record software does. After it is setup you can move camera further away.
However, it won't keep connection for more than 24 hours.
May 23, 2009 | Linksys Wireless-G WVC54GC Network Camera
Need BL-C30 installation exe file.pls hlp
Thank you for contacting Panasonic. We apologize for the delay in our response.
The CD can obtained through our parts department at 1-800-332-5368 or through the link below:
http://www.pasc.panasonic.com/epartr/
It can also be downloaded at http://netcamdealer.com/resources/file/82/103
The CD-ROM is not needed for setup. To setup the camera, type in the local IP address of the camera. If you do not know the IP address of the camera, press the reset button on the back of the camera to reset the IP address. This will default the IP address to http://192.168.XXX.253, with the XXX being replaced by the 3rd octet of your router IP address. For example, if your router IP address is 192.168.0.1, you will type
http://192.168.0.253 into your internet browser and you will be able to configure the camera. Another example is if your router IP address is 192.168.1.1, you will type http://192.168.1.253 into your internet browser and you will be able to configure the camera.
To obtain additional assistance for your product, please contact our Panasonic Customer Call Center at 800-272-7033. The hours of operation are Mon. - Fri. 9A.M to 9PM and Sat. - Sun. 10A.M to 7PM Eastern Standard Time. A representative will be available to assist you. Please have your case number 26813996 available at the time of the call.
Thank You,
Panasonic Consumer Support
Apr 13, 2009 | Panasonic BL-C30A Network Camera
I nd to configure dynamic host for my dvr camera through router
You need to assign static IP on your dvr camera, then open the port(port forwarding) for your camera using the router's setup page.
Jan 18, 2009 | Linksys Wireless-G WRT54G Router
Moultrie I450 Game Spy
Before installing a sd card, internal memory MUST be erased. From setup,use the up/down buttons near the select button until the display reads "ERASE ALL PICS(MEMORY)? NO" toggle up or down button to get"YES", press the select button and wait until until it says "DONE".
Go to setup screen, power off, intall sd card...should be good to go.
Oct 05, 2008 | Moultrie MFH-DGS-200 Digital Camera
Configure webcam in wan
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video shoud work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Jul 03, 2008 | D-Link Express DCS-900 Network Camera
Inability access from other computers
You need to check with your router vendor on how to setup DMZ or Port Forwarding for your DCS-5220 in your router. (For Port Forwarding, please open BOTH HTTP Port and RTSP Port and select the Protocol as TCP for HTTP Port and select the Protocol as TCP/UDP(Both) for RTSP Port.
Nov 14, 2007 | D-Link DCS-5220 Network Camera
No Wireless Camera Not Found
While you had it plugged in the serial port you should have set the SSID name for the camera? You may have to enter this manually to find the camera. If it is not set to broadcast this SSID, it will work but you must put it in the wireless connection settings.
Aug 08, 2007 | Veo Wireless Observer Network Camera
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
