Question about The Office Equipment & Supplies
A metal plate is 1 m square at 283k.it has a hole 600 mm in diameter in the centre.the linear coefficient of expansion of the metal is 12.5*10 power nagative six /k
SOURCE: how to calculate the Linear correlation coefficient
go to [2nd] [0] then select [diagnosticon] and click [ENTER] then it atomatically adds it to the LinReg(ax+b)
Posted on Jan 21, 2008
  • 398 Answers
SOURCE: need Dimentions to make a box for this subwoofer
build a box with at 8"hole in it out of particle board, dont need to worry bout displacement
or check out this page for the formula, i aint doin the math
http://www.bcae1.com/spboxnew2.htm
Posted on Mar 07, 2009
SOURCE: PS2 Metal square loose inside?
its nothing it goes on the inside on the left side its just there so you can buy a stand to stand your ps2 up
Posted on Jun 26, 2009
  • 6 Answers
SOURCE: where do I get a gear to turn the shredder
Her
Date: Thu, 9 Jul 2009 11:16:33 -0400
Subject: TS4500 from Winsource Ind.
To:
Rick,
This TS4500 shredder had been discontinued for more than 5 years. The factory did not make any spare parts for this model.
Thanks,
Victor
Customer service
e is my response
Posted on Jul 11, 2009
SOURCE: I have a Techsolutions paper shredder TS4500. The plastic gear th
I have the plastic gear(s). You may have bought a new shredder by now but you can let me know. Juan
Posted on Feb 27, 2010
51 inches tall and 12 inches wide. What is that in linear ft.
A total of 63 linear inches is 5 ft 3 in, or 5.25 linear ft.
Dec 03, 2015 | Office Equipment & Supplies
How do i calculate 600 square feet of 5/4" x 6" decking into linear feet
2 Linear feet of 6" Material would make 1 Sq Ft.
so 1200 linear feet should do it.
Sep 16, 2014 | Pavilion Wood Decking Exotic Cumaru /...
How did a guage become a measurement?
" the thickness, size, or capacity of something, especially as a standard measure, in particular." In its utilitarian sense , the term gauge refers to a standard of measurement. A 12 gauge wire has a defined diameter, and it is standardized, so if you buy 12 gauge wire in various places across the country, the wire will have the same diameter , wherever it's purchased. The same applies to gauges of metal, or the thickness of the metal. Standard measures such as linear measures , inches, mm, feet, cm, are all standardized measurements. Standardization creates consistency and the ability to replicate something.
May 16, 2014 | Computers & Internet
The belt has come off, how do you unscrew the 4 white screws ( white disc front about 1 inch in diameter with a 2 mm hole at centre to get the back off ? The Rubber belt was loose at the bottom of the...
There is no need to split the case simply turn it upside down be careful there are concrete blocks in there and they make it heavy. You can then work on the belt and the drum bearing which if you cant turn the drum sounds jammed if so you will need new drum bearings and to replace them you will have to split the case, but having seen it from the bottom it should be easier
Dec 03, 2012 | Zanussi ZWF1430W Front Load Washer
Computer case fan for Gateway Performance, mid-tower case
Case fan size is typically measured in mm. Common sizes include 40, 60, 80, 92, 120 and 140 mm. OEM cases can have proprietary fan sizes as well.
Jun 12, 2012 | Gateway Computers & Internet
Am trying to calculate corelation on a Casio fx-9750GII,
Press Menu.
Use arrows to highlight STAT icon and press EXE.
Enter your data in two lists (x-values in L1, Y-values in L2)
Press F2 to activate the CALC Tab at the bottom of screen.
This is what you see.
Press F3 to activate the REGression tab.
This is what you will see: the TABs at the bottom of screen.
Each tab corresponds to a regression model: X-linear, X2 quadratic, etc.
If you press F3:X^2, you get the following
You see the parameters of the regression equation, the coefficient of determination r^2, and the Mean Square error. No correlation coefficient is defined for this regression model.
For other models like linear, logarithmic, power and exponential regressions, the correlation coefficient is defined and is thus displayed with the regression equation. It is the r-value.
Jul 31, 2011 | Casio FX-9750GPlus Calculator
Cap on gas tank leaks. leaf blower stops after using for 5 minutes and then it doesn't start until it cools off
sounds like the breather on cap is faulty , replace cap
the stopping is most likly a coil going open circuit when hot
and is not producing spark
best way to test is to place a home made tester in line with the h t cap and the spark plug and re run and see if spark fails when hot - then retry cold if spark returned - faulty coil is confirmed
to make a tester
cut a hole of 20 - 30 mm in diameter in a 2 " square piece of wood - drill a hole ( using 3.5 mm drill bit ) in opposite sides all the way through to the centre - then fit a nail that has been sharpened to a point into each hole you drilled
now push the nail points together in the centre of the large hole you cut so that the pointed ends are no closer than 5.00 mm
apart ( you may need to cut the nail heads off )
fit this in between the ht lead and the plug tip
and you might need to tape the unit up so that it stays in place
while you test
try making tester because you can use it on other things as well
cheers
Sep 03, 2010 | Garden
21 people viewed this question
Top The Office Equipment & Supplies Experts
James Cagle
James Cagle
Gareth Cockram
Gareth Cockram
Peter March
Peter March
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
