Question about Saeco Coffee Makers & Espresso Machines
Saeco incanto sirius s-class display "ventilate" message, making beeping noise and doesn't go to main menu.
mirran
  • 515 Answers
SOURCE: saeco incanto sirius
It can be the touch board or the "water turbine" in the machine
Posted on Jul 11, 2008
EsWorld
  • 1618 Answers
SOURCE: my saeco s-class incanto sirius
Sounds to me that water is not getting to the pump. Try charging the water filter before using by letting it sit in some water for about 5 mins.
Posted on Jul 25, 2009
EsWorld
  • 1618 Answers
SOURCE: Does not come off ventilate mode. Re: S-Class incanto sirius mode
Try this push in steam knob when it calls for ventilate, especially if you are steaming or drawing hot water, if that works the the steam valve or the tap rod needs to be replaced.
Posted on Oct 07, 2009
EsWorld
  • 1618 Answers
SOURCE: i have saeco incanto deluxe coffee machine,ventilate msg appears
Check the end of the steam nozzle, make sure it is not blocked. If not then with the knob open for hot water cycle push in on the knob if that works then the tap rod assemble or the steam valve needs to be replaced.
Posted on Feb 21, 2010
rickead1
  • 1998 Answers
SOURCE: Hi I have a Saeco
on some of the saeco models i have found people generaly forget to clean the tip of the nozzle where the water comes out by using a small pin or a needle it gives you the ability to clean this area allowing for the water to flow out of the machine. This situation is sometimes cuased by to fine of a grind going through the machine. And when the grind reaches the nozzle tip it binds together causing a blockage. The setting for how fine the grind is usually in these machines goes to about 8 but at no time are you supposed to use this setting or it would cause issues in the future with your machine the manufacturer actually suggests 5 for the setting and to slowly move the setting forward to 6 or 7 depending on the strength of the brew you are makeing. Clean the tip of the nozzle head with the pin or needle and message me back on how you made out I await your reply Thanks again Rick
Posted on May 04, 2011
I have a Saeco Incanto S-class sirius machine. Message displayed, "Brew Group Blocked", so I purchased a new Brew Group Unit, when I installed it, got the same message. when turned on, I can...
Brew group blocked is normally displayed when there is no water flowing through the brew unit. Remove the brew unit and use a small screwdriver(make sure machine is off and cooled), then gently lift up on cross section fitting on white plastic valve inside the machine, if water flows out it works, now we will plug in machine keep brew unit out and turn it on and press fitting in again, if water flows and pump kicks in and water flows out from valve and not under machine you are good, The coffee grind might be too fine and needs to be adjusted to coarser.
Jun 28, 2011 | Saeco Incanto Sirius Fully Automatic...
I have saeco incanto deluxe coffee machine,ventilate msg appears
Feb 20, 2010 | Saeco INCANTO DELUXE Espresso Machine
Saeco S-class Incanto Sirius brew unit stuck
Try running the clean cycle again, that sometimes will help the machine to reset.
Sep 15, 2009 | Saeco Incanto Sirius Fully Automatic...
My saeco s-class incanto sirius machine keeps say replace water filter & ventilate even after I replaced filter
Jul 23, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
Dec 28, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
Saeco Incanto Sirius S-Class
Contact this Service Center, they can help you in Norway.
Nesodden tv-service
Evenstuveien 15
1450 Nesoddtangen
tlf.: 90 79 77 75
fax.:66 91 56 25
kaffeservice@hotmail.com
Best regards
/Mirran
Oct 18, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
May 25, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
Coffee Makers & Espresso Machines Logo
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
