Question about Radio Communications
I have the smokin buds 2 bluetooth headset and it won't turn on. I charged it and now it's blinking red and blue. Then a steady blue. It still wont turn on. How do I fix this?
SOURCE: bluetooth wont turnon new unit out of box
Pardon me if you have already tried this but with my em236c I had to hold the Answer/End button for about 15 sec before it flashed red/blue. The manual doesn't say how long to hold it. It took a couple of tries for me. Hope this helps.
Posted on Jan 12, 2009
SOURCE: my mad catz headset wont turn on but it will
Posted on Nov 29, 2009
  • 3 Answers
SOURCE: My H710 headset will not enter pairing mode.
Try this- first,make sure on your phone, that you have checked that bluetooth is on. You do not need to also check the box to make visible with other devices.
Then-try this, (I got mine to work (I had same problem). On headset, close boom, hold center button (and it turns pink). then, while keeping center button depressed, open boom- light remains pink. Then look on phone, and hit Add new device-- and bingo, it should be recognized now!! You'll be asked if u want to pair w/ Motorola-- and led through the process--follow those steps.
I had tried similar earlier, but the trick was to keep the button depressed, and then open the boom. I can't quite remember if I kept button depresed until I also pressed Add new device on phone or just until after opening the boom and the light stayed on ... Sorry I can't be exact; I was too excited. Hope this helps you get yours working!
Posted on Jan 02, 2010
  • 5 Answers
SOURCE: I have a H270 Bluetooth headset. I charged it
I had the same problem. I plugged a USB charger into the headset and turned the power switch off. It worked as normal after that. I think it does not like to be "on" when the USB is disconnected. Anyway it seems the plugging/unplugging kick-started it.
Posted on Feb 12, 2010
  • 5 Answers
SOURCE: headset not going into pairing mode.
Hold down round button on earbud for 5-6 seconds until the lights blink alternating red and blue.....then, enable your phone/device to connect in pairing mode. This will be a "find device" command or something similar. Once they recognize each will send you a screen to enter a code. This will be 0000.....enter that...and once they are good to go.
Posted on Mar 08, 2010
My Skullcandy Smokin Buds 2 won't turn on even while it's charging. Just shows a steady blue light.
Same problem here. It is fully charged but I can't hear the little sound when you turn the headset on or off... It only worked the 1st month of use.....
May 09, 2016 | Radio Communications
How to pair a ROMAN R6250 Mini Wireless Bluetooth Headset Earphone Headphone to an iPhone 5S
1. Charge the headset:Headset is charged via USB cable, the light will be red when charging. When the battery is fully charged (about 2-3 hours), the red light of the headset will turn off automatically or the red light turns blue.
2. Turn on the headset:Press the on / talk button on the headset for about 5 seconds until the blue and red flashes alternately (or blue flashes or the blue lights all the time ), now the headset is ready to be connected to the iPhone.
3. Go to Settings, and tap Bluetooth. Turn on Bluetooth.
iPhone will automatically start searching for Bluetooth devices. Tap the device in the Devices list, then follow the onscreen instructions to connect to it. After matching successfully, the blue light on the headset will flash twice per time.
4. Call: when you finish all the above steps, you are going to talk via the Bluetooth headset. When there is incoming call, press the on / talk button, you can talk with Bluetooth headset, when you want to end the call, press the on / talk button, you can end the call.
5. Turn off the headset: Press the on / talk button for 5 seconds until the red light of the headset flashes quickly for twice, then release the button, the headset will be turned off.
Mar 25, 2014 | Apple iPhone Cell Phones
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
Bluetooth paired but not connected?
There are several kinds of Bluetooth Profiles. If you're only looking to send and receive phone phone calls, A Bluetooth headset only needs a Hands Free Profile or HFP.
The EM227 cannot be used as a stereo headset because a different Bluetooth Profile is required. If this is what you're intending to use it for, You may want to invest in Bluetooth enable Studio Headphones.
Try these steps to Troubleshoot the issue:
1. Make sure that your EM227 has been fully charged. the User Guide suggests that you charge the Headset for at least 5 hours before you use it for the 1st time.
2. Go to your device's Bluetooth Settings and scan for nearby devices.
3. Turn ON your EM227 Bluetooth Headset and place it in pairing mode. The Bluetooth indicator light will flash RED and BLUE.
Don't Forget to keep your Bluetooth Headset and your device within 3 feet of each other.
4. If your device asks for a Pass Code, try entering "0000" ( Four Zeroes)
Once you've paired the device, the LED indicator should now blink as a steady Blue light. Try making a test call.
Remember, The EM227 was only designed for Hands free calling ONLY.
Mar 15, 2013 | Emerson Radio Communications
Cellular Innovations HFBLU-FP1 T2 FP1 wont charge
bluetooth - charging mashine problem bring it to recheck the charger
Apr 15, 2012 | Cellular Innovations HFBLU-CX1 Wireless...
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Mine wont turn on
Hello, did you check the battery? Tu get the full charge, the headset red light must stay steady on. If you get it charged you can pair it: hold power button till the two leds blinks, now scan for bluetooth from PS3 and choose your mic setting. Other than that I'd call madcatz technical support. Good luck, Peter_Rei
Aug 04, 2010 | Mad Catz Bluetooth Headset for PS3
Radio Communications Logo
50 people viewed this question
Top Radio Communications Experts
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
