Question about The Audio Players & Recorders
Have edt312ant antenna. have had for a year. today I get no reception and noticed the red light on the outside antenna is no longer lite up. Not sure what to do. Does the antenna unit have a battery?
  • 99 Answers
SOURCE: 2003 Oldsmobile Silohette - Battery lights keeps coming on
Hi before you go changing the alternator check the alternator belt is tensioned properly if this is slipping it will cause the same thing, Hope this helps
Posted on Dec 11, 2008
  • 121 Answers
SOURCE: Outside unit will not start...while inside unit blows warm air
probably a.c. was left with out a gas,and compressor will not start and there is no cooling.
Posted on Jul 04, 2009
  • 4090 Answers
SOURCE: The gps looses satellite reception. Repositioning
DIY is risky in this situation, besides there is 3 months warranty by Garmin on their interventions I would suggest you get it done by the professionals
Posted on Jul 22, 2009
  • 12 Answers
SOURCE: outside unit do not run.Red light blink 6
That is a trouble code signalling that your unit needs service. It is time to call a professional for help!
Posted on Jul 21, 2010
SOURCE: GPS will not work on my clarion NX500. After a
I got the same problem, Clarion Canada says it is the antenna but I am removing the radio and bringing it to them to check out. Will report back when they let me know.
Posted on Feb 07, 2011
I have had a pioneer X-ray p970 f model.. had it for years. However getting radio reception has always been an issue. I live rurally. I would like ABC AM 720. Any ideas. Thani you Susan
A web search for your model turned up a blank. You aren't kidding about having it for years. I'll give you some generic information about AM radio reception and hope you find something useful.
Generally, AM reception is through a wire coil wrapped around a ferrite (very fast magnetic material) rod. Received signal strength is dependent on the angle between the rod and the radio station's transmitter antenna, so rotating it in a horizontal direction (around an imaginary vertical line through the center of the receiver) is often helpful. The angle of the best direction can be affected by nearby equipment (metal appliances, ductwork, computers, etc.)
Many non-portable audio receivers and a few boom box types have both an AM and and FM antenna terminal on the back. The FM antenna is very much like a TV antenna (you can use a TV antenna) and is generally required to get FM reception except in units with a telescoping antenna mounted to the case. The AM antenna is used to augment the coil signal, and is generally needed only if you are trying to pick up a weak signal. Attaching a wire to the AM terminal may help (make sure you have a good electrical connection between the terminal and the metal of the wire). This wire will also have an optimal angle for best reception. Try arranging it vertically; many AM radio stations transmit vertically polarized signals for the benefit of car radio antennas.The longer the wire is, the better, but it doesn't have to be very large. The physical limit is about 110 yards, the practical limit is how much you can stand to have stretched out behind the stereo. (A thin wire going up the wall to the hook behind a picture will probably not attract much attention.)
Portable radios often use a single telescoping antenna for both AM and FM along with the internal coil previously described. If you have this, experiment with antenna position and radio location. I have been told that some early model LED light bulbs may interfere with AM radio reception, especially if they are within a few feet of the radio.
Feb 26, 2018 | Pioneer Audio Players & Recorders
Really tough to get perfect reception with Rabbit ears. If you can somehow feed the line outside a lot of the times I have found that it helps improve signal reception
Jan 25, 2013 | RCA Ant121 Indoor Passive Antenna
There is no static on the gain knob and no light on ant. i can barely p/u any reception and lose reception quickly.
First try getting a good antenna. I don't know what you have BUT STAY AWAY FROM "RUBBER DUCKY" ANTENNA'S!!!
Check your SWR's!
Make sure the RF Gain is maxed
Make sure the SQUELCH is all the way to the left
Dec 27, 2010 | Cobra 29 LTD CB Radio
Awful AM reception on Sony ICF-CD513 kitchen radio
You may have to use foil or other metal to extend the antenna artificially. I found years ago that even wrapping my hand around the end of it boosted the signal (though I'm sure you're not willing to listen to a radio while holding the antenna the whole time). I once sat a TV antenna on top of a portable CRT with its own internal ferrite antenna, and the video signal was about 80% there, audio 100%. This may be an inconvenient method, but it will guarantee at least most of the audio quality you want.
Jan 30, 2018 | Sony ICF-CD555TV 7 in. Portable Television
FM reception
Assuming the antenna connection is not broken, an old trick is to get a sizeable piece of aluminum foil and twist the center of it making a big bowtie. Wrap (twist) the center of the bowtie around the top of the antenna and see what happens. Try turning it so it points in different directions to see if any particular direction gets better reception.
Mar 31, 2009 | Aiwa CSD-TD901 Cassette/CD Boombox
No antenna lite when transmitting
Antenna light should be a warning indicator for high VSWR..... simple rule of thumb for CB antenna.... the lower the frequency "channel" the longer the antenna length, higher the frequency "channel" the shorter the antenna length. Your vehicle is a ground plane, where you mount the antenna will also affect its operation and tuning. A properly tuned antenna will have lower reflection on the midband channels and gradually rise as you near the upper and lower end of the band. Some base loaded antennas will be noticably narrow in bandwidth, if you have that problem then tune it for the channel you use most!
K40 has always been good for easy tuning and band coverage, center it on the vehicle top for good omni coverage!
PS... always make sure your connectors are secure, a loose shield will ruin your day when adjusting SWR!
Dec 20, 2008 | Cobra 29 LTD CB Radio
Plasma TV Reception
Bro the reception in that area of the house must be poor, as you've said. The walls in that area of the house must be too thick, or some part of the house is blocking the signal that the attena emits. You should consider getting an antenna that can be placed outside the house, like on the roof top. Make sure it isn't being blocked by anything, like trees with large branches or whatever.
Jul 21, 2008 | Televison & Video
SL100 static and bad FM reception
I have noticed various changes in my invehicle FM reception as well. There should be a external antenna that came with your car kit. This is precisely for these types of issues. It is designed to run along the windshield inside the car closest to the Cars radio antenna. It should plugin to the bottom of the cradle. Then tune it into a clean FM station (one that has no local station on it) and position the cradle and/or ext. antenna till you get the best reception in your vehicle. It could very well be that the antenna has come has loose on your car stereo backplane. You would probably notice decreased reception on regular AM/FM stations as well though.
Your wifi reception/functionality is a completely different animal and has no bearing on the FM transmitter in the car cradle. When your on wifi your not receiving signal from a sat. anymore just simply streaming internet audio like your computer.
Good luck.
Apr 08, 2008 | Sirius STILETTO 100 MP3 Player
While in the truck, make sure the antenna is on the outside of the truck. It has magnet so it is easy to stick to the roof. Do not know what to say about the home antenna, mine is not working right now.
Dec 14, 2006 | Delphi MyFi SA10113 XM Radio Receiver with...
No reception
hi YES that will b the problem... if you got a window try puting the system with the ANT outside and see if you recive anything if soo try fixing it there if u it the lazy way...: attach a copper wire (a speaker wire) to the ANT and set its end outside the longer the wire - the inferior signal you will get good luck
Feb 21, 2006 | RCA RS2650 Shelf System
29 people viewed this question
Top The Audio Players & Recorders Experts
Jose Ma DM.
Jose Ma DM.
Level 1 Expert
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
