Question about Sterling Plumbing 1500D-36S "VISTA PIVOT" SHOWER DOOR
Need shower door replacements parts
I have a frameless pivot shower (doors are 182 x 34 cm each), and pivot hardware needs replaced.
i have part numbers, but do not know the brand name.
30095PPC plastic pivot part
30109PPC plastic pivot part
30100PPC (doors)
can anyone help with where to look -- or maybe can identify brand name by part sequence.
i appreciate your help.
  • 4 Answers
Supplier in the Netherlands, www.novellini.nl
For the 30095PPC are the next parts:
De benodigde artikelnummers zijn:
1 x R02YOB2G-40 (set scharnieren t.b.v. één deur) à € 23,80 incl. btw.
De prijs van de bovenstaande set onderdelen is € 23,80 incl. btw.
Verzendkosten zijn € 7,50 incl. btw.
Posted on Mar 25, 2010
I need 2 showerdoor plastic part number 30095ppc.
Do you have these? Or do you know the brand name, company where I can buy these parts?
I live in the netherlands.
Posted on Nov 26, 2009
    New Friend:
Thanks for the Solution at the
Novellini! We found it there!
All the best from Vienna!
Posted on Apr 08, 2014
Years ago I purchased a Kinkead Vista-Pivot Shower Door, model 1500-31, Silver. For a variety of reasons the shower didn't get built until recently. However the door opening is now 32.5 inches wide so it...
Ace Hardware sells that door and you will need to see if they can order the parts but it looka like they sell the doors 36" size so when you order you will need to order for the Sterling Plumbing 1500D-36S "Vista Pivot" Shower Door Fits Openings 31 -1/4" To 36" H 66" . Now if you have not completely finished the shower you could always make the door opening fit what you have.
Mar 16, 2011 | Sterling Plumbing 1500D-36S "VISTA PIVOT"...
Sterling frameless bypass shower doors inside door wont stay closed even though have it on th best option setting to do so
Some times it's possible to tweak a roller track (barely bend) at the proper spot to prevent the roller from back tracking past that spot.
Sep 17, 2010 | Sterling Plumbing 1500D-31S VISTA PIVOT...
The sterling knob is lost from our bath tub fixture. It is about 3" H by 1" wide at the center. Where can I get a replacement. I live in zip code 17602.
You can call Sterling Customer Care Center at 1-800-STERLING (1-800-783-7546) in the U.S. or 001-877-680-1310 in Mexico. Also some stores stock replacement part kits in the hardware/shower door aisle. Ask a store associate for assistance and depending upon the warranty period of your door, the part may be replaced free of charge.
Feb 03, 2010 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Have a sterling 1500D-42S shower door. Need to
sterling is an inexpensive kohler product,....go to a plumbing supply store with your #s and they'll be able to get what you need.
Jan 02, 2010 | Sterling Plumbing 1500D-36S "VISTA PIVOT"...
I need a plastic pivot part for the door of my shower. 30095PPC Where can I buy this part? I live in Belgium.
I found a supplier in the Netherlands, www.novellini.nl.
The parts are:
You can mail them by:
info@novellini.com
Nov 07, 2009 | Sterling Plumbing 1500D-36S "VISTA PIVOT"...
I have a frameless pivot shower (doors are 182 x 34 cm each), and pivot hardware needs replaced. i have part numbers, but do not know the brand name. 30095PPC plastic pivot part
Finaly a found a supplier, www.novellini.nl
The parts are:
Oct 19, 2009 | Sterling Plumbing 1500D-36S "VISTA PIVOT"...
Frameless shower door sticking to the opposite wall when closing
you can fix this problem by loostening the clamp screw and putting locktite sealer(you can purchase locktite from hd or lowes locktite is not the only product you can call a glass supplier and as for recommendation) Be sure to read the directions on the tube I use it to seal joints on refrigeration threaded parts. Make sure it will adhere to glass and metal also review the clean up solvent when you do this place a wood wedge at the bottom of the glass dooor and the threashold to support he weight until the sealer driese
Steps
1 Place wood wedge/block under door where non hinged side meets wall
2 losten top hinge(inspect bottom hinge to make sure it is snug and the glass dor is all the way into the hinge
3 You may have to remove the top hinge completely to get enough of the locktite on the metal and glass place the locktite on the hinge flat plate and the glass
4 recheck gap where door meets wall( I sometimes use paint stirs(wood) as shims to keep space between door and wall consistent
5 tighten top inge screws( you can put locktite on the screw threas also
6 Clean excess locktite and wait suggested time by instructions on tube
Good Luck!
Dec 31, 2008 | Home
Sterling Plumbing 1500D-36S "VISTA PIVOT" SHOWER DOOR Logo
3,815 people viewed this question
Top Sterling Plumbing Home Experts
john h
Mike
Rabbit Brains
Rabbit Brains
Are you a Sterling Plumbing Home Expert? Answer questions, earn points and help others
