Question about Cell Phones
How do i change my phone back to normal its screen is negative
Black and white or negative screen resolution in Mac OS X
A black and white display, or negative screen resolution, is an issue which can occur within the various Mac OS X system versions ranging from Mac OS X 10.3 to Mac OS X 10.6.
It can appear as an anomaly which can leave a Mac User dumbfounded, not sure what is going on.
At one time your screen is normal like this, but then somehow,
the screen changes into this strange negative, inverted screen.
So how does this occur?
The answer is more simple than you think.
An inverted screen like the one you see in the screen shot above, is not actually an anomaly, or the result of some sudden strange happenstance. What's more, chances are, this occurred because of what you did.
Its an easy fix however, because the only way your Mac OS X desktop screen can turn into a negative or black and white resolution, from its normal color resolution, is if a setting within your Mac OS X system has been modified.
To return your screen back to the normal color resolution, follow these steps:
* Click on the Apple menu icon, located on the upper left corner of your Mac OS X desktop screen.
* From the drop down menu, select System Preferences.
* Within System Preferences, select the pane (in System Preferences, Apple references all icons as "panes") entitled "Universal Access".
Quick Note About Universal Access:
The reason this System Preferences pane is known as"Universal Access", is due to the purposes Apple designed it for. If you notice the image for this pane above, this symbol for this feature, is similar to a placard or sign you would see on a car license plate, parking space, door or building, for an individual who has a disability or is handicapped.
Universal Access was designed to enhance features like Voice-over speech (your Mac talks to you), screen size, display settings, keyboard and mouse settings for those Mac users who are vision impaired, hearing impaired and /or physically disabled.
* For the next steps in the process:
Click on the Universal Access pane.
If you look in the screen shot, under Display, you will see that the current setting is "White on Black".
Click on the radio button entitled "Black on White"
and this is the window you will see:
Back to normal!
That is all it takes, to return your desktop screen resolution back to normal.
This is why you were suggested as the probable cause" for your desktop screen to go into Inverted mode. Chances are you may have been in System Preferences, clicked on the Universal Access pane, and in exploring settings, may have clicked the Display setting and the
White on Black radio button, causing the screen to go into
the inverted mode or change in gray scale.
Another theory could be that you may have accidentally pressed the Ctrl-Alt-Apple Command keys on your keyboard, combined with either < > keys, depending on if you were in process of' increasing or decreasing contrast on your Mac's screen or display.
The true purpose of the inverted screen mode or change in gray scale, is to aid Mac Users who may be sensitive to the bright normal colors, that you and I see on the standard Mac OS X display screen, due to poor or failing vision.
So now that your screen is back to normal, if you should see an inverted display, or screen that resembles a negative resolution, like that of a photo negative, you know how to correct this issue.
For more information on Universal Access, click here.
- Mactechtrainer
on Feb 08, 2010 | Computers & Internet
Screen went into sepia how to fix it back to normal
Click on the Menu button on your monitor and adjust the temperature. Change it upward. A low temp, like 5000K, will have that sepia like color. Increase it to around 9300K, and it'll be more bluish. Post back how it works out .
Jan 04, 2014 | Computers & Internet
LG Viewty - negative screen
Maybe the back light is set to low or the LCD screen is set to low
check the phone settings ...
May 28, 2009 | LG KU990 Viewty
My guess is that this is a contact error between the screen and the actual phone, as it turns back to normal when you put pressure on it.. Same thing happened to me.. I sent it in for reparation though, but i'm guessing the problem is a contact error...
May 13, 2009 | LG KU990 Viewty
JVC AV_48WP30 Screen loses color, everything is in like negative color
Sounds like shading, caused by convergence IC or bad solder connections in convergence circuit. Check the CONVERGENCE GALLERY for shading.
JVC design is generally reliable. It is extremely unlikely that you would have 2 unrelated failures.
If you are in Canada, email me.
Oct 27, 2008 | JVC AV-48WP30 48" Rear Projection...
Desktop negative photo shot
Nobody is using your computer, so you don't have to worry about that. To change your computer back to normal hold down the Control, Option/Alt, Command, and "8" keys. This will change your desktop back to its normal state
Aug 03, 2008 | Apple iMac G5 Desktop
Cell Phones Logo
32 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
