Sinotec Smart TV is stuck on this screen-an android with a warning image and it reads 'operation failed' the remote buttons do noting and have tried to reboot with the remote and tv but nothing works
Shuttle83
  • 1139 Answers
SOURCE: TV dont respond
Hello psp007,
I hate to be the one who tells you this, but you have one of those TV sets that are controlled by a single processor (as most combos have even LCD combos) and that processor may have gone bad. This is why you have so many problems at one time. I would suspect the the main processor board has a problem. You may want to take this to a TV repair shop, because there is so little you can do for this problem since if it is the main processor you will need equipment to troubleshoot this problem and to remove and install the component with the problem. Taking it to a shop is your best bet.
I hope this helps,
Thank you,
Shuttle83.
Posted on Mar 03, 2008
fixyadude1
  • 57 Answers
SOURCE: RCA remote
Could it be possible that the remote needs reconfigured? If none of the buttons work, the it could possibly be that you need to re-enter the TV code back into the remote.
Posted on Sep 24, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Philips TV stuck on the blue language selection screen.
unplug the TV from the wall outlet for two minutes, then try again
Posted on Nov 25, 2008
  • 4090 Answers
SOURCE: Flashing power button tv won't turn on
yes call the tech and have the power board replaced. In future have the TV plugged into an anti surge board to protect it ( and you from expensive repair.) I suspect you will need a new power supply fitted
Please rate the help to keep us online
Posted on Aug 17, 2009
SOURCE: my tv stuck in the photo menu and i dont have a remote, side buttons stoped working how to rest tv to main screen
Turn it on while holding the menu button on the side at the same time and hold it
Posted on Apr 29, 2012
My sinotec LCD TV model st-32a3fnb,does not respond to remote.The screen is blue on HDMI settingwhich works perfectly but no other button seems to work. A grey block not available appears.
Hi Tanya,
I know it sounds silly, but before doing anything else, change the batteries. If this fails I would suggest that you contact sinotec customer support. Otherwise, think about getting a universal remote. Bear in mind that it may not support all functions.
Jul 17, 2015 | Televison & Video
How do I get a Picture on settings?
Your question is confusing. Is this a TV or a cell phone?
Oct 28, 2014 | sinoteck N9572 Dual Core MTK6572 Android...
The universal remote wont work on the sinotec tv. It seems to be stuck om the media
Try using the SAMSUNG code to program it. Sometimes it works as the Samsung and Sinotec have similar frequencies on the remote instructions
Dec 02, 2013 | Televison & Video
How do i get out of usb mode on my sinotec tv without a remote
You do not need a remote control. I used my smart phone with IR. Down load tv remote apps and wala its sorted.dont buy universal remote it did not work for me could not find the Sinotec that i have so wasted R400.00
Apr 20, 2012 | Televison & Video
My Sinotec 54c IS LOCKED, the screen is blue, and it also has a lock on the top righ hand corner, what do i do to unlock it ?
Helo
Assumes that you have its orginal remote control handset with your now, and posts this solution to your Lock Probelm. If you haven't it now with you, just try to buy a new one, or borrow it from any of your friends or relatives, who own the same model of TV, just for ulock it. After unlock, you can use any other universal remote control to control your TV.
Sinotec:
If you have the original remote (RC-A07) for Sinotec tv, then press and hold down the Music button for about 10 seconds. The tV will be unlocked. After unlock, you have ot set a new password. OK.
Sep 06, 2011 | Televison & Video
Sinotec lcd model Rc-N38,it does not have picture,but there is
I have a sinotec 32" LCD TV.when i put my tv on its shows me LCD TV in the center of my tv. and ofter screen is black
Jul 09, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
INSTRUCTIONS NEEDED FOR THE SHARPER IMAGE - JUMBO UNIVERSAL REMOTE
Hello kls1996... programming your remote is rather easy. The easiest way (thanks to The Sharper Image Jumbo Remote being a LEARNING SMART remote) is to do the following:
1 - Point the head of your Sharper Image remote at the head of your Sanyo TV remote (nose to nose so the clear bulbs on each remote are facing each other).
2 - Press the "TV" button on your Sharper Image remote (located in the upper left-hand corner).
3 - Hold the "LEARN" button on your Sharper Image remote (located in the left edge under the volume buttons) until the red light flashes.
4 - Press the key on your Sharper Image remote (e.g. Volume Up or +VOL)... the red light will go solid (indicating that it is waiting for a signal from the other (in your case Sanyo) remote.
5 - Press the key on your other remote (in your case the Sanyo remote) that you want programmed in your new Sharper Image remote... the red light will flash rapidly again.
6 - Repeat step #4 until you have programmed each key.
7 - When done... press the "LEARN" key on your Sharper Image remote. Your Sharper Image remote should be programmed to operate your device (in this case, your Sanyo TV).
NOTE: You can program other devices such as your VCR, DVD, VHS, SAT, CABLE, etc. and not just one device.
Dec 27, 2008 | Televison & Video
Sinotec 37cm tv
If you have the original remote (RC-A07) for Sinotec tv, then press and hold down the music button for about 10 seconds. This worked for me.
Oct 05, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
