Question about John Deere Garden
Bought a used Sullair 185 John Deere motor. It runs great but only does 100 psi, I need 125 psi for my blaster...? How do I raise the pressure?
    Master:
  • 923 Answers
You raise the pressure ... by buying a compressor with a higher pressure output!
Posted on May 08, 2017
Testimonial: "Thanks for nothing ......"
  • 1 more comment
  • solver2010 May 09, 2017
    You're welcome ... for nothing! There is no easy but safe way to raise pressure above what such a unit was designed to do, minus wear factors!
  • Butch Baker
    Butch Baker May 15, 2017
    Well they sell regulators I found to raise pressure, Sullair has 100, 125, 150, and 175 psi. You are are wrong.
  • solver2010 May 15, 2017
    I regulator can only REDUCE pressure! A regulator CANNOT INCREASE pressure, unless there is MORE pressure already available, to REDUCE it TO! Can water run uphill? No. And neither can AIR!
    SPECIFICATIONS—125, 130, 49 HP AND 185 JOHN DEERE. 40. 3.4 ...... compressor with an operating pressure range of 100.
My John Deere 175 is hard to start and once it starts it puffs out dark smoke like it was flooded and then runs great
check and be sure spark plug is good clean and set at .030 may check to see it the spark arrester is clean. if this don't help may need to clean the carburetor.
Jun 13, 2016 | John Deere Original 130 160 165 175 180...
What is the correct tyre pressure for
NICE TRACTOR!
Tires
Front Dimensions15x6-6 turf
Air Pressure 110-138 kPa (16-20 psi)
Rear Dimensions26 x 12-12 turf
Air Pressure 96.5-110 kPa (14-16 psi)
Here is a link to the manual - very useful!:
http://manuals.deere.com/cceomview/omtcu29065_j0/Output/Index.html?tM=
Jan 03, 2015 | John Deere Garden
Where is oil cooler
Hi not totally familiar with this compressor but the oil cooler will be in front of the air intake vents with the cooling fan behind it
Mar 07, 2014 | Ingersoll Rand P185WJD Platinum Series Air...
I have a 175 pull behind IR compressor. When trying to set the high Idle I open the valve so that it is reading 100psi, the motor trys to throtle up but it seems under to much of a load. also when it drops...
100 psi is around the pressure that the engine goes back to idle
it should start to go to fast rpm when the pressure drops to around 75 psi
if it is trying to increase rpm at 100 psi , the engine is under load and that is your problem
Dec 19, 2017 | Ingersoll Rand P185WJD Platinum Series Air...
Hi. My company has a Sullair 185 diesel air compressor that will run for approx. 4 hours than shut down. The indicator lamps flash "4" flashes and the unit will start right up. We do not have a...
Take note of page 24 in this PDF
http://www.scribd.com/doc/45811151/Manual-de-Mantenimiento-Sullair-185
It states the 4 flashes indicates low engine speed it is part of the SSAM system.
Jul 19, 2011 | Garden
When it does move it's incredibly slow and only waters about 100 square feet a day. I bought it because I my 9 year old son liked it and I thought that it would motivate him to water the lawn but now he's...
You need higher water pressure...needs to have 40-60 PSI to work well.
Here is a tip about how to get parts for your traveling lawn sprinkler and also a great article about how traveling lawn sprinklers work.
Traveling Lawn Sprinklers
heatman101
Aug 24, 2010 | John Deere Gilmour Traveling Sprinkler -...
John Deere 185 deck height adjustment
having a problem with dive belt being hit by the mower deck 185 john deere suggestions !!
May 08, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Sullair 185 screw compressor
The sullair 185 has a low oil pressure override button that you have to hold in while starting. after the oil pressure builds up(takes about ten seconds) you can release the button and the machine should continue to run.
Feb 19, 2010 | Chicago Pneumatic 1/4" Air Screwdriver
John Deere 3300 PSi pressure washer shutting off while in use.Everything appears fine Oil level,Gal level,Air cleaner ok etc.. May run 2 minutes or 12 minutes then spudders a bit then Bang "Off" as if i...
John Deere will replace the cap for free; they acknowledge the vendor who supplied Briggs & Stratton gas caps provided faulty caps. Call 1-888-228-3068 then 1 (English), 2, 1 and a technician will ask you for model number and Serial Number (which they need to replace the cap). Don't drill a hole in your cap: debris will find a way into the gas tank and end up possibly fouling the engine. Bob from NJ
Nov 03, 2009 | Dewalt 3800 PSI Pressure Washer
Garden Logo
104 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
