Question about Sewing Machines
Hem 751 Is there a battery and where is it? - Sewing Machines
How do i create a rolled hem using my Platinum 750?? Do i need a special presser foot?
by rolled hem I imagine that you are trying to put something like rope in the hem to make a round edge
You can buy a 1/2 foot that allows the needle to get close to what ever is making the roll
see your local sewing machine shop
Jul 07, 2016 | Platinum Sewing Machines
I need to know how to do the blind stitch hem
here is a link to great info on sewing.about.com which explains this technique with images, http://sewing.about.com/od/techniques/ss/machineblindsti.htm
In brief, you need to fold the fabric to be hemmed into a Z shape with the wrong side hem edge at the bottom of the Z.
The Blind stitch is either three straight stitches then a wide zig zag which swings to the left and catches a little bit of the folded edge, or three small zig zags, then one wide zig zag to the left to catch one stitch into the folded edge. The zig zag style has a little more stretch in it so works good on jerseys and knits.
tally_girl_0.gif You need to use the blind hemming foot which helps you to line up the folded edge and keep it at a constant distance from the needle. It will look like this.
tally_girl_53.jpg Turn the little silver screw to move the white plastic guide left or right until you've got just a smidgen of fabric being stitched by the left wide stitch. Always do a practice sample first to get the stitching and guide set right. On most machines you can vary the width of the big zig by adjusting the stitch width dial a little.
You need to adjust the blind hemming foot guide so that the needle is just catching a tiny amount of your folded fabric because this is the stitch which shows on the right side of the fabric when you unfold the Z. So forget trying to hem satin or expensive fabrics this way, a hand sewn stitch will give a much better finish.
Blind hemming works best on a hem which is continuously straight on the same grain line, its not great for a curved hem. So if you've got a tiered skirt or the frill on a bed valance, it is fine as the fabric edge to be hemmed will be a continuous straight length. You can use it on a slightly curved hem for jerseys as the fabric has more give, and patterns will help to disguise the stitching too.
I hope that this helps you to sew your blind hem, 4 thumbs up if so.
Jul 19, 2011 | Brother LS2020 Sewing Machine
I've got an Elna 634 overlocker, and want to turn
Just trim the fabric to the desired hem length plus one inch, then overlock around this raw edge with thread close colour match to the fabric.
You then have the choice of either stitching around with a stretch stitch on your sewing machine, or hand sewing.
Being lycra shouldn't change how you hem them unless the trouser leg is extremely close fitting and the hem seam is going to be under tension.
My first choice would be using a twin needle in straight stitch from top side but this finish can pop/break if the hem is under tension. But perfect for most knit hems.
If you hand sew then you can turn up hem allowance and put a length of fusible hemming web inside the hem allowance and press it to hold. Then do a back stitch hand sew around to hold hem in place.
If you sew with the regular sewing machine, then use either the stretch stitch or a very small zig zag, and a ball point or stretch needle.
On ready to wear you would see a coverstitch hem but your overlocker doens't have this stitch.
Jun 12, 2011 | Elna Sewing Machines
Which food sood i use to make an invisible hem
blind hem foot is good if you want to machine stitch a hem but not have a seam showing. it will have an adjustable piece you can move left or right with a screw. but blind hemming works best on straight grain and not on a curve like a skirt hem unless its a knit fabric that gives. to make a blind hem press the hem allowance up then turn the main garment piece back to form a Z shape. you then stitch along the hem side with your blind hem foot guidr running along the top fold and use the blind hem stitch which looks like three little zigzags then one big zig far to the left onto your folded piece taking a little 'bite' - this stitch shows on the right side when you press the top of the Z back flat. so you need to adjust the foot position and how wide the needle swings to minimise this stitch showing. hope this makes sense and helps you with your sewing.
Dec 19, 2010 | Elna 2007 Mechanical Sewing Machine
I need help with hemming and placing button holes in daygown.
Hi:
You can easily trim a hem down a bit before actually hemming it up. Many patterns allow for a lot longer hem than you will ever use, but that also allows for people both for adult and childrens patterns that may need the extra length. Often if you know the length you will need before you cut the pattern you can make the adjustments before you cut the pattern. As to putting a button hole in a hem, I have done so, especially on an adults outfit where the hem will never likely need to be let down. Sometimes on a childs pattern, putting the button hole in a hem means you can not let the hem down, and as I learned with my youngest two kids, who went through growth spirts twice a year and could easily grow 3 inches in less than 3 weeks during this time, I did not want to limit my options so I never put a button home or any trim through a hem line that might limit my ability to lengthen a newly made outfit.
Hope that was helpful to you.
Patchz
Apr 05, 2009 | Simplicity Performer S110 Mechanical...
What is a Narrow double hem with hand slip
You can find some instructions on a narrow double hem at http://www.sewjanetmoville.co.uk/content/learning/viewArticle.asp?lcArticleCategoryID=0&lcArticleID=3&pgid=learningCentre. Instead of machine sewing it, use a hand slip stitch as seen here: http://www.hutchal.clara.net/curtains/sewguide.htm.
You can find more info on these techniques at http://www.repair-home.com/how_to_sew_repairs.html
Hope this helps! Let me know if you need more info.
Mar 18, 2009 | Janome MyLock 634D Mechanical Sewing...
How do I change the stiches?
The brother website has a users manual for it that can be downloaded. Use this link to get it:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hf_ls2125eus&type2=5&flang=English&dlid=
Jul 09, 2008 | Brother LS-2125 Mechanical Sewing Machine
Cant hem unable to workout what length to start with to end up with the correct length required looking at the manual it says to take the hem and fold it over etc. but its very confusing
Sorry, I don't understand just what you mean by "length to start". Length of what - stitch? hem turn-up?
Let us assume you are taking up a hem of a pair of pants. Try them on and put a pin where you want the hem to finish i.e. this will be the bottom of the pants. Take pants off, turn them inside out (careful that your pin does not fall out!) and fold the excess pants on that pin mark. The excess fabric should be on the outside, not tucked inside the leg tunnel. Measure how much it is from the existing hem to where you folded it over, let us say for the purposes of this exercise it is 4 inches. Your hem is to be 1 inch and you need 1/2 inch to turn under for a neat finish, total 1 1/2 inches, so you need to cut off 2 1/2 inches from the bottom of each pants leg. Fold 1/2inch at new leg bottom (wrong side of fabric to wrong side), press, fold 1 inch hem same way and press. Place pins every 2inches or so at a right angle to the hem edge. Pins should come out 1/4inch from edge of hem where the 1/2inch neatening fold was made (this is where I wish I could draw a picture!). Fold the hem back inside the leg tunnel. The pins should make the fabric fold under only enough so that 1/4inch of the hem sticks out beyond the pants leg. You will sew on this bit using the blind hem stitch (04 on my 7550). You might need to adjust the stitch width - not length - so that the straight part of the stitch goes along the hem bit and the zig-zag JUST bites into the pants leg fabric.
I do hope this lengthy explanation is of some use to you!
Jul 01, 2008 | PfaFF Creative 7570
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
