Question about KitchenAid Dishwashers
Dishes not cleaned after full cycle
Kitchenaid dishwasher model KUDS01FLSS6 RUNS FULL CYCLE AND WHEN COMPLETE THE DISHES ARE NOT CLEAN. Water is hot.
  • 677 Answers
SOURCE: HElp Dishes not coming clean
www.dishwasherfilter.com has a great new product out that filters the water going into your dishwasher. it reduces minerals that cause that white build up or residue. it goes under the sink and doesnt take up much room at all. my dishes looked terrible until i put this filter in. it is very affordable and works great.
Posted on Apr 03, 2008
  • 366 Answers
SOURCE: Dishwasher is running but dishes aren't clean
sounds like the top or middle spray arm isn't rotating, most likely a clogged spray arm, try and remove sprayer arm and clean it
Posted on Aug 22, 2009
  • 400 Answers
SOURCE: The dishes don't come out clean after complete cycle.
Has it always been okay in the past? Do you have the manual, and if so, are you loading it properly. I am not familiar with this particular machine, however there are a few things you can check. Make certain all the spray arms are spinning freely. If there is a "tower" that comes up from the bottom, be certain nothing is blocking the center portion of the bottom rack. Run a load as normal, but stop it after a few minutes. Is there water in the tub and are the dishes wet? If not, determine if the water source is on, and the "fill" solenoid is working. If there is water, and all dishes appear to be getting wet, be certain you are getting a lot of "water action" during the wash. If you listen closely, you should hear a sloshing sound as the machine runs. If not, your not getting enough water circulating. The pump may be clogged, or perhaps there is not enough water coming in. Is your water pressure high enough to fill it completely? I hope I have given you enough things to check in order to lead you to the problem. Let me know.
Posted on Oct 31, 2009
Testimonial: "This is very helpful! Thanks."
  • 901 Answers
SOURCE: dishes not clean?
Check all the water jet orfices in the moving arm. Try cleaning without loading the top rack.
If cleans well, mostly the upper rack dishes not arranged properly.
I hope you are using the main wash detergents. Rinse aid is just to remove the stains after the main wash rinse.
Posted on Apr 02, 2010
heatman101
  • 43501 Answers
SOURCE: Particles of food on clean dishes
Here is a tip that I wrote about your problem...
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Posted on Apr 15, 2010
Dishes not cleaning after full cycle running
Your screens are plugged with food residue in the bottom of the unit. clean it out. You can use 1 gallon of white vinegar for your wash after you clean the screens. Start your washer to fill with water but after the water starts, open your door and pore all of the gallon in the unit. Let it now run for 4 minutes and stop it by opening the door. Leave the door slightly open for 1 hour. close the door and let the cycle continue for 4 more minutes. open the door and repeat it a couple of more times. Let it sit all night with the vinegar in it and in the morning - close the door and let the cycle continue to the end. This should help soften and clean out the food particles in the unit. You can repeat the process and get a better cleaning then too. All the scale should be off your dishes now.
Jan 08, 2014 | Frigidaire Professional Series 24 in....
Dishes not coming out clean
Hello
There are some things you can try, however, if your Maytag dishwasher is not getting your dishes as clean as you would like. Maytag recommends several processes for fixing this issue with your dishwasher.
Do not run your Maytag dishwasher while hot water is being used in other parts of your home, such as washing clothes or showering. Hot water is needed for your Maytag dishwasher to properly clean dishes.
Run water in the sink in your kitchen until it gets very hot. Then, turn on your Maytag dishwasher. This will ensure that the water cleaning your dishes is the hottest possible temperature.
Clean your Maytag dishwasher to improve the cleaning results for dishes. Run your dishwasher on a short wash cycle and wait for it to fill up with water. Stop the cycle and add about 1/3 of a cup of rust remover to the dishwasher and finish the cycle. Run your Maytag dishwasher through one normal cycle with regular detergent to finish the cleaning process.
Check your detergent. Old detergent or those that have been exposed to moisture can be clumpy. This detergent will not clean your dishes as well when loaded into your Maytag dishwasher. Purchase fresh detergent.
Use extra detergent when washing dishes that have a lot of built-up grease or food particles. The extra amount of detergent is needed to get your dishes clean. Choose a long cleaning cycle to clean these dishes.
Fill your Maytag dishwasher properly. Dishes should not be stacked on top of each other or excessively crammed into your dishwasher. This will keep the dishwasher from adequately cleaning all areas of your dishes and from rinsing them thoroughly.
Sep 13, 2011 | Maytag Dishwashers
The dishes have a gritty residue on them after the wash cycle is complete.
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter.
Jul 02, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Leaving a white residue on dishes after its full cycle. Have tried different soaps,rinsing agents, and ran it through a cycle with a cup vinegar in it.Is there something I can do to repair this problem ?...
As you have already done the vinegar cycle and all now it must an technical reason.
Mar 17, 2011 | Frigidaire Dishwashers
Dishes have residue after complete cycle
Mar 08, 2011 | KitchenAid 24 in. KUDS02FRSS Stainless...
Have bosch SHE45 EVOLUTION PUSH BUTTON ON RIGHT FRONT PANEL. MY WASHER WILL NOT RINSE ALL THE SUDS OFF THE DISHES OR DOWN THE DRAIN AND HAD BAD SOAP RESIDUE BUILD UP. i HAVE USED LEMISHINE ONE TIME AND...
I started running the Hot water faucet till I got really Hot water then I started the dishwasher with No dishes in it and let it fill with hot water till it was almost full then I added a half a gallon of white vineagar to the water and let the dishwasher go through its cycle. It cleaned up the inside of my dishwasher then I put the dishes that didn't get clean and that had a soap film on and rewashed them with plain hot water and poured the other half a gallon of vineagar in the dishwasher and let them wash the complete cycle. It cleaned the dishes very well. I don't know if you will have the same results but it worked for me..... Hope this helps, your welcome to give it a try vineagar is pretty cheap... and it won't hurt anything inside the dishwasher or dishes.
Feb 12, 2011 | Dishwashers
Soap residue on glasses, dishes & flatware...what can I do..I use Cascade & JetDry
Instructions Things You'll Need:
  • Vinegar or lemon juice
  • Gel dishwasher detergent
  1. dishwashers have a rinse aid dispenser. If your dishwasher has this dispenser, fill it up periodically and it will release the appropriate amount of rinse aid automatically at the right time during the wash cycle. This will help your dishes rinse more cleanly.
  2. Rinse aid in solid form
    Some older dishwashers or basic models do not have an automatic rinse aid dispenser. In this case, you can buy rinse aid in solid form that attaches to your dishwasher rack. Solid rinse aid can be hard to find in stores because it is not commonly used, but it can be purchased online.
  3. Vinegar or lemon juice
    Appliance repairmen will tell you that one of the common problems they see with dishwashers is the buildup of excess detergent. If there is too much detergent in your dishwasher, your dishes will not rinse cleanly, no matter how good the dishwasher is or how much rinse aid you use. To clean the excess detergent that has built up inside your dishwasher, put 3 tablespoons of vinegar or lemon juice (concentrate is fine) in the empty dishwasher and run the dishwasher through a complete cycle with no dishes. Do this twice, for two complete cycles of the empty dishwasher with only vinegar or lemon juice added. The acid in the vinegar or lemon juice will break up the detergent that has built up in your dishwasher's interior.
    After you have cleaned the detergent buildup from the inside of your dishwasher, follow the steps below to keep the buildup from happening again and to help your dishes rinse cleanly and prevent residue from accumulating on the dishes.
  4. Gel dishwasher detergent
    Switch to a liquid or gel dishwasher detergent. Any brand will do.
  5. Fill one compartment half full Dishwashers will effectively clean dishes with much less detergent than manufacturers often recommend. The bleach in the detergent, combined with the extremely hot water used in the dishwasher wash cycle, will clean and sanitize your dishes completely, even in small amounts, and using less detergent helps prevent buildup and residue from accumulating on your clean dishes.
    Fill only one detergent compartment(the one that snaps closed) half full with gel detergent. Snap the opening closed and run your dishwasher as you normally would. Your dishes will come out sparkling clean with no buildup or residue, plus you'll save money by using less detergent!
Feb 02, 2011 | Dishwashers
I have a Maytag dishwasher Model PDB3600A. the dishes are left with a strong soap residue after a full cycle of wash. I use a powder detergent and Jet Dry. What should I check to solve the problem?
When you open up the dishwasher is there still water in the bottom of the dishwasher????? The screen around the bottom could be dirty. Or the drain line could be restricted, if it drains back to the Garbage disposal make sure it is draining. Are you using hot water??? Check to see if the Arms are turning and the ports are not plugged with debrie.... If the drains are OK and the screen is clean...... I put in about a half gallon of white Vinegar in the wash cycle after it filled with water and used no soap and rewashed the dishes. I ran the Hot water faucet at the Kitchen sink till the water was good and Hot and then on the dishwasher used the heat water feature. It cleaned up the dishes and the dishwasher. I did this on a Whirlpool dishwasher but it should work for any make of dishwasher. Hope this helps... I had to do this several time to get all the dishes back clean
Jan 02, 2011 | Maytag Dishwashers
Dishwashers Logo
35 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
