Question about Coffee Makers & Espresso Machines
My Kerrigan will only put out on the large cup button but it puts out more that 2 cups of watter
It doesn't do anything on the two smaller sizes of servings.
SOURCE: My machine only brews 1/2 cup of coffee. I have
I had some coffee grounds stuck up in the cone shaped hole that the water comes from at the top. I had to use a very long toothpick but it broke up some of the grounds that happened to get caught up inside. Before doing this, I went through 24 oz of vinager ;) .. the toothpick worked!
Posted on Sep 30, 2009
SOURCE: When I use or attempt to have the Keurig serve a
I had the same problem and my Keurig is only two months old. I read advice from another user and called Keurig this morning. They are replacing the unit for me within 3 to 10 days. All they asked for was the serial number, which is very easy to find. Good luck!
Posted on Mar 03, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: after many uses, the cups
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Posted on Dec 22, 2010
Testimonial: "thanks"
joeguest2
  • 2080 Answers
SOURCE: When pressing the bigger cup
Maybe the big cup button has to be held down the whole time while filling as a safety measure to avoid accidentally overfilling a small glass uncontrollably with hot liquid.
Other than that I can't think of anything unless the machine just needs to be diassembled and thoroughly washed out clean.
If this was at all helpful please click on the 4 Thumbs Up helpfulness rating icon you see on this page.
Good luck and thank you very much.
Joe.
Posted on Feb 19, 2011
heatman101
  • 43501 Answers
SOURCE: My Keurig has three settings
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Posted on Mar 01, 2011
How to reset keurig b40
1. There is some confusion over models. I've seen "B40" models and instructions with only one size cup button, both labeled B40. I own one stamped "B40" on the bottom, and it has two buttons -- small and large. FWIW, small = 8 oz, large = 10 oz.
2. These reset instructions from another site seemed to do something
What to Do If Your Keurig Won Brew Cup Barista
So.. this is what I did that worked for mine: 1) Hold down Auto-Off and LARGE cup at same time. (all lights should hold steady ON) 2) press SMALL cup while still holding Auto-Off and LARGE cup 3) Release all three, press LARGE cup again.. all lights should go off. 4) Unplug for about 5 - 10 second, plug back in. SHOULD WORK!
3. On *_my_* B40, remove the K-cup, close the door, fill the reservoir. Unplug and replug the B40. All lights should be off.
Pressing "Auto Off" and "Large Cup" together will turn on 3 lights (Heating, Add Water, Power) for about 3 seconds. Doesn't matter how long the buttons are pressed or what order they are released.
I tried lots of add-on combinations: e.g. press button x, press x multiple times, press x while lights are still on, press x after lights are off, press buttons x and y together, press x then y, press x and/or y while still holding Auto and Large, release Auto but not Large and press x, etc.
Nothing gave any confirmation that a reset was accepted. All lights always turned off after 3 seconds. Maybe Reset is only 1 step, i.e. Auto+Large together?
Jan 04, 2013 | Keurig Elite B40 Coffee Maker
My Kerig will not fill the cup.
are you using the "large" cup button? The Kerig coffee maker (i believe) makes either an 8 or 12 ounce cup of coffee, which may be smaller than your mug.
Mar 29, 2011 | Keurig B66 3-Cup Coffee Maker
Hi. When I try to make a large cup of coffee, the machine makes more like a medium size cup. What can I do to fix that and get a true large cup? Thanks.
Hi!
When making a cup of coffee hold the button in until the coffee reaches the height you want then release button. You can set the 3 sizes in this manner
Ray AU
Feb 09, 2011 | Saeco Royal Professional Espresso Machine
I press the large cup but it brews a small cup. What should I do to fix this?
I have have the same problem first thing in the morning. My first cup, I press large but with no K-cup; it comes out small or medium. I put the water aside (pour it back into the reservoir after it cools.) Then I brew a large cup using a K-cup, and it comes out the right size. I still want to know how to fix the problem, but at least this works for now.
Aug 11, 2010 | Keurig B60 Coffee Maker
I am interested in purchasing this 6 cup brew station, but all pics I see use travel mugs. Can it be used with regular 10 -12 oz ceramic mugs for home use? How about 6 oz cups that match Corelle...
How does the coffee get into the cup? If it brews directly into the cup then the amount can be controlled by how much water you put into the maker. If it is a 6 cup then it must hold the coffee in a reservoir. Do you have to push and hold a button to dispense the coffee or do you push and wait for it to fill your cup? If it is the latter then it will need to know how large or small the cup size is. Is there a setting for that? If it is a push and hold method then you control the coffee flow so size is up to you. As far as it being a travel mug or ceramic mug as long as the mug will fit in the maker and sit securely under the nozzle then it shouldn't matter what kind of mug it is.
Feb 20, 2010 | Hamilton Beach 48274 BrewStation 6-Cup...
I lost power and now I get blinking lights on my le Cube 185
I had a similar problem where both Small and Large cup buttons on mine blinked intermittently. I did a reset of the large and small cup flow levels based on the following and it seems to work fine now:
1. Switch off power 2. Press and hold Large cup button 3. Switch on power while still holding down large cup button
See if that solves your problem.
Aug 24, 2009 | Nespresso Essenza C100 Espresso...
Slow coffee stream and smaller brew size with B70
I had the same problem, contacted Keurig and they suggested the descale procedure, which did nothing. The brew size was very small, the display would not let me select the size, and water was being pushed back into the reservoir. I was able to resolve the problem however.
First I went through a gallon of white vinegar, without results. Then I did the following:
Went to Walmart and bought "Brew Rite". Tried 8 cup mixture (8 cups of water, two tablespoons of mix), did not work. Being persistant, put in another 8 cups, and when the reservoir was empty of the solution let sit 2 hours while unplugged and then put in clear water. By the time I got half way through with the clear water, the device started working properly, no problems since. This may work for you...
May 29, 2009 | Keurig B70 Coffee Maker
Coffee Makers & Espresso Machines Logo
35 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
