Question about Garden
Belt replacement south land reartine 196 tiller
5 Suggested Answers
  • 8 Answers
SOURCE: MTD reartine tiller, wheels won't turn in or out of gear
broken drive blet or chain, check accordiningly
Posted on Nov 16, 2008
  • 221 Answers
SOURCE: how to put gearbox back together on mtd reartine
If you will go to the link below you should be able to find a parts diagram for your gearbox. It is about the only way to see how it all goes back together. It would be too difficult to try to walk you through it here.
http://www.milacalawn.net/mtdparts.html
Posted on May 05, 2010
john224
  • 1378 Answers
SOURCE: Bought a 6.5 reartine tiller
V belts should be available at any local power tranmission supply store or even most auto parts stores. Take the old one with you or if it is missing you'll need to know the diameter of both pulleys, the distance between the two shafts, center to center, for the shafts the pulleys mount on and the width at the top of either pulley to know belt width.
John
Posted on Mar 21, 2011
latinoboytx
  • 46 Answers
SOURCE: I have an old Montgomery Ward reartine
Below is the link to the owner manual should have everything you need. Glad you help you out.
http://lawnandgarden.manualsonline.com/manuals/mfg/wards_natural_science_establishment_llc/rotary_rear_tine_tiller_gil39012b.html?idRes=4067557
Posted on Sep 20, 2011
Bought a 6.5 reartine tiller on ebay but cannot get new v belts for thyis machine original supplier doesn't want to knowTimberman1
John
Mar 21, 2011 | Garden
What kind of oil does it use .reartine
If you are asking about motor oil, straight 30 weight (SAE 30) . For the gearbox use SAE 140 gear oil.
Jan 27, 2011 | Garden
Ihave a craftsman 5hp(briggs&stratton) reartine tiller that won't
Hi.....I am assuming that you have a bowl type carberator on that tiller. If so, the bolt on the bottom of the bowl, is the main jet. If you remove it, you SHOULD, see a hole drilled from the top down to a hole cross drilled thru, near the bottom. Run a small wire thru these to be sure they are clean. Other then this, I'd install a new needle and seat. You can purchase just a needle and seat set, no need for a complete rebuile kit. You will also need a bowl gasket, and if you have a primer bulb, you will also need a new intake gasket or the primer will not work worth a darn. Hope this is of some help, good luck
May 29, 2010 | Craftsman Garden
How to put gearbox back together on mtd reartine tiller . its apart in a box and haveing troublle with the forward and reverse gears
Mar 13, 2010 | Mtd Garden
I need a forwward cable for an earthquake reartine rototiller #5020dm how to order. thanks
I googled Earthquake 5020DM tiller and show a site that has a technical manual. It has the diagrams and parts numbers. It looks like the forward and reverse cable are the same. You may have to call ARDISAM direct to get the cable.
Oct 02, 2009 | Ardisam 5.5 Hp Rear Tine Rototiller
Nov 05, 2008 | Garden
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
