Question about Sony Office Equipment & Supplies
Projector with black traces
I have a SONY projector and when there are movements in the image, they are left with black traces, as if it were cracks in the image.
Marrie
  • 563 Answers
SOURCE: ELMO Projector image not working
Hi schmidtkm
All the sympoms mentioned above is that of a faulty Mainboard that will have to be either repaired or replaced.
Trust me on this one , I work on Projectors every single day of my life.
Posted on May 13, 2008
SOURCE: Computer used to work with projector, and now doesn't?
Have you tried pressing Fn F5? On my system (HP), by computer monitor goes dark when I connect the projector. Pressing (Function) FN F5 toggles the video between Computer Monitor, Projector, or Both.
Check the function settings for your computer. On my Compaq laptop at home, the video function is F4, so there may be different settings for your computer.
Posted on Jan 12, 2009
  • 5 Answers
SOURCE: Sony VPL-CX6 Projector turns itself off. No image projected.
does the "lamp/cover"-led light up? i had the same thing happening, the lamp either broke or is about to break and the projektor won't turn it on again to protect itself. if its very urgent, open the projector pull the lamp out and put it in again, it might work for 1 or 2 more times, but it is very likely to explode (usually not breaking the projector but for sure not good for it).
good luck!
Posted on Aug 04, 2009
projdoc
  • 2237 Answers
SOURCE: the projector comes on, shows an image, then shuts off
power supply problem. the capacitors are probably drying out. it takes a boost of power to strike the lamp, and if the power supply can't handle it, it shuts down. replace the power supply.
Posted on Aug 18, 2009
projdoc
  • 2237 Answers
SOURCE: projector problem
if it's an lcd, the fly-eye lens might be burnt. return it.
Posted on Dec 23, 2009
Black spot on projector image
Unfortunately, the DLP chip of your projector is defective, and will require to be replaced/repaired.
Mar 25, 2014 | Acer Office Equipment & Supplies
How to write on wall with some image or photo?
If I understand correctly you want to project an image on the wall.
If this is correct, then open following links to Texas Art Supply:
http://www.texasart.com/tools/light-boxes-and-projectors/projectors/artograph-tracer-projector.html
http://www.texasart.com/tools/light-boxes-and-projectors/projectors/artograph-prism-image-projectors.html
http://www.texasart.com/search/index.cfm?searchstring=projector&store=ALL&x=22&y=13
How it works.
Place image on table.
Put projector over top of image.
Turn on projector, and image is projected to wall or piece of paper hanging on wall.
Trace image or paint directly on the surface.
Feb 12, 2011 | Cycling
I have changed the bulb on my Sony VPL-HS50 video projector and the image is now in black and white. I folloewd the instructions in the manual word for word. The bulb is a Sony genuine part
Is the buld u changed right and in working condition.please clean the optic lens and image CRT board which ( Scanner image board) to see if the issue remaisn or nott
Sep 28, 2010 | Sony VPL-HS51A / VPL-HS60 Multimedia...
Uncentered image using projector
reset the settings to factory default. is it cut off evenly, or is it uneven and shadowed? if it is the latter and you have a dlp projector, you have a collapsed light tunnel. if it is cut off evenly, go into the settings and make sure the resolution and screen size matches.
Jan 27, 2010 | Sony Office Equipment & Supplies
Dropped projector
It may HAVE fractured the solder connections to the RGB connector OR worst case may have cracked the circuit board to the connector.
Resolder the connections AND if necessary, bridge jumpers around the board cracked circuit traces.
Nov 23, 2009 | Hitachi Performa CP-RS55 Multimedia...
Red shadow to left of main image InFocus LP750
You have to open the LP750 and check the alignment of your color lenses. You might be needed to adjust, also check your lamp too.
Jul 23, 2009 | InFocus LP 750 Multimedia Projector
Boxlight cp-310t won't display image
loose connection. possible crack on main board. needs to be sent in to have a look at.
Aug 16, 2008 | Boxlight CP 310t Multimedia Projector
Two problems, first the menu appears to be burned into the projection, the bulb has less than 100 hours. Second when black is supposed to be projected it projects blue?
You have a bad lcd, you would probabaly have some blue lite leakage also. Any lcd projector should not be left on the same image for long periods, it wears out the pixels that control the lite thru. The blue lcd is usually the culprit.
Jun 12, 2008 | Sony VPL PX40 Multimedia Projector
IN72 psychedelic traces
have the same problem took mine apart for cleaning and inspected the bulb looks like bubbles in the bulb that will hold disorted images on the screen so im going to replace bulb
Feb 04, 2008 | InFocus IN72 Multimedia Projector
CRACKED
The Stress of impact on the imaging forming unit that is directly behind the projection lens has a flat glass surface. If it is cracked the stress cracks would project with any image because they are on the same plane as the image
Nov 22, 2007 | BenQ MP610 Multimedia Projector
37 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
