How do I reset error code 82 without waiting 4 hours
Hi i have put the wrong code in radio for renault megane and it is coming up with error and I have took the battery of left it over night but still say error
For Renault radio codes and instructions on how to enter it, contact this link: https://www.gumtree.com/p/in-car-audio-gps/car-radio-codes./1210678039
Jan 16, 2017 | Renault Megane Cars & Trucks
Bizhub c352 error 3451
If the code comes back do not reset, you are messing with the Fuser the Hot part. Continuing to reset without a technician looking at and or replacing it, the fuser can catch on fire and that would ruin a perfectly good day. ENSURE YOU WAIT THE 10 SECONDS
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 15, 2016 | Konica Minolta bizhub Office Equipment &...
Waiting 4 kdc
You will not unlock it without a code. You need to contact Kenwood directly: 1-800-KENWOOD (536-9663)
Apr 17, 2014 | Car Audio & Video
Rheem RTG53DVP code 82
Before calling service technician, open following link for resources including error codes, Rheem chat and possible manual:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Error codes are considered start-point for troubleshooting, and give service technician direction for isolating problem.
Error 82 appears as 'gas type data failure' > 'Program PC board for proper gas type.'
Gas type is choice between LP gas and NG natural gas.
Gas type programming is controlled with dip switch setting.
I do not have service manual for product, and would not suggest changing dip switches without specific information beforehand.
Aug 16, 2011 | Rheem RTG53DVP Direct Vent Liquid Propane...
How to reset kenwood kcd 5021 car radio
Waiting means you locked it up by using the wrong code too many times if there is a number after waiting 2= 5 minutes
3=1 hour
4=24 hour
That is how long you have to wait until you can try again.
Mar 21, 2010 | Kenwood KDC-5021 CD Player
Error 82 appearing after replacing motherboard
82 means that your programming on the board isn't correct, check for the right altitude chip and fuel type
Jul 30, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Lock code problem
ur security code has been changed by yourself or someone else, wait 4 hours without entering any other code then try 12345 if still fails then take it to repair shop and ask them to do a factory reset with cable and software.
BR
Jun 09, 2009 | Nokia N73 Cellular Phone
WHEN ENTERING THE cODE i MADE A MISTAKE AND THE INSTRUCTION CAME UP WAIT 1 HOUR. THAT WAS TWO DAYS AGO AND IT STILL SHOWS WAIT 1 HOUR Can you please advise on the action to take next. Thank you
have you actually left the ignition on one hour?
if not, do that and see what happens. One full hour without touching it,, key on.. theyre on a timer, it should come back and want you to enter the coder after that hour...
May 08, 2008 | Car Audio & Video
Brother 3240c Error A1 ,A2 and 82
Not sure what 82 code is but A2 and A1 have to do with size of paper possible original to long for size of paper in cassette
Mar 28, 2017 | Brother MFC-3240C All-In-One InkJet...
Pro-82 buttons dead and won't reset!! Yikes!
Hi, If a simple reset will not correct the error, you may need to re-initialize the scanner (but of course this will delete all your stored memories and presets). To Reset - push a pin through a hole at the side of the scanner and press on the recessed button inside; To Initialize - power off, press TUNE button (leftmost third from the bottom), without releasing TUNE button power on and do a RESET again a bit longer. Wait a couple of seconds (till after the LCD display blinked). Release RESET button then release TUNE button. Try the scanner. If buttons don't work, you may need to verify that KEYLOCK is off. A more comprehensive instruction is detailed at http://support.radioshack.com/support_electronics/doc69/69887.pdf If this does not work, you may need to seek the services of a qualified professional as it needs circuit analysis in the logic section. Good luck and kind regards.
Aug 20, 2007 | Radio Shack Pro-82 Scanner
27 people viewed this question
k24674
jasbo
jasbo
