Question about Troy Garden
When i engage the lever to turn the blades on nothing happens troy bilt 46 inch hydrostatic 13YX79KT011
    New Friend:
  • 48 Answers
Check your pto switch and make sure you are getting voltage to the clutch
Posted on May 08, 2017
  • 1 more comment
  • David Antone
    David Antone May 09, 2017
    I can hear the power going to the starter with a click only once and then nothing
  • Dmcl May 09, 2017
    So the whole unit isn't starting? If that's what your question is check your seat switch. The click you may be hearing may be a solenoid if the starter and solenoid are separate. But if the pto switch is bad and in the engaged position it usually will not let something start either
  • Dmcl May 11, 2017
  • 450 Answers
Check belt tension, pulleys, and look over linkage.
Posted on May 09, 2017
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 | Troy Garden
Pto won't engage blades
ether switch bad fuse blown behind dash or pto bad if pto 300.00
Sep 12, 2014 | Troy Bilt 25HP VTwin Hydrostatic 50" Cut...
Troy-Bilt Horse XP, Model 13bx79kt011 - Won't Move
You need to check the belt to the hydro units is connected properly and is tentioned and not slipping in the pilleys
May 31, 2013 | Garden
One blade is grinding the dirt when they are engaged
First check for a bent blade Then check for a broken spindle. Then check for broken metal on the deck or a broken/ disconnected deck hanger.
Oct 24, 2012 | Troy Bilt 25HP VTwin Hydrostatic 50" Zero...
I have Troy Hydrostatic 46" when I attempt to
If you lower the blade deck and get down near the mower, you can see the blades belt on top of the deck. If it is intact, with the engine off, have someone try to engage the blades. A tensioner should move into place to tighten the blades. If it is not, follow the engagement lever to under the dash to see if there is a cable broken or a rod detached.
Post back.
Sep 11, 2011 | Troy Bilt 22HP Hydrostatic 46" Riding...
How do i replace drive belt on a gardenway lawn tractor 16.5 hp 42 inch cut hydrostatic drive troy bilt gardenway
how do you install a drive belt on a 46 inch garden way troy bilt riding mower
Jul 26, 2010 | Garden
Troy Bilt ride-on mower will not move in either fwd or reverse
Is the parking brake on? Or if it's a hydrostatic (automatic) there is a release lever to push the unit around when it isn't running. Most of those releases are on the back of the machine, and you just push it in for drive and pull it out to push.
Was this helpful?
Mar 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
56 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
