Question about Whirlpool Dryers
Push start button and nothing happens. Whirlpool #WTW4800XQ. Checked all connections.
    Problem Solver:
  • 26 Answers
1st off, you said all connections, but are you sure outlet is good? If so, I would next get a new panel for the start button. Sounds to me like a loose wire or shorted out.....
Posted on May 18, 2017
SOURCE: dryer will not start.. Here clicking sound when i push start button but nothing happens
Did you clean the lint screen and replace? Also - all lint should be cleaned from back of dryer and the duct...many dryer manufacturer have safety sensors that will not light dryer due to there being too much lint, not enough air flow...(safety feature) ...
Posted on Oct 09, 2008
SOURCE: Whirlpool dryer model LEQ8800JQ won't start when push start butto
I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
Posted on Jan 03, 2009
SOURCE: Nothing happens when I push the start button on my Gas Dryer
Three things you can check the door switch is it clicking? The thermal fuse you want to make sure there is continuity or worse case would be your motor.
Posted on Apr 02, 2009
Mohamed Nabi
  • 100 Answers
SOURCE: nothing nhappens when i push scan start button
dear sir good day to make this button functions you must install the printer setup cd and it'll make the computer undrstand the push of the buttons of your printer thank you
Posted on Jan 07, 2010
  • 3072 Answers
SOURCE: my whirlpool cabrio dryer start
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Posted on Jan 09, 2011
Wirlpool wtw4800xq washer frequent out of balance
Check the spring rods on each corner make sure not broken or came off pull basket make sure nothing in between silly question is it level also check the balance ring to make sure it is not loose
Feb 17, 2015 | Whirlpool WTW4800XQ Top Load Washer...
Model WTW4800XQ Whirlpool top load washer will not fill. Only hums when on button is pushed. what is the problem?
Does it do it on hot and cold water. Check the water filters where the hose screws on to the washer.
Oct 06, 2014 | Whirlpool WTW4800XQ Top Load Washer...
Brand new Whirlpool WTW4800XQ out of box . Set up plugged in , loaded load pushed start lid locked hummed lid lock started flashing. waited till lid lock went off Still nothing
Before you attempt to do anything please check if the drum lock is removed, check the power plug, connect the water line inlet. and finally check the settings of the program.
Read through the manual and DO NOT ATTEMPT TO DO ANY REPAIR AS BEING A NEW SET you have warranty.
Call your dealer if the set hums even after the initial checks were done.
Aug 04, 2011 | Whirlpool WTW4800XQ Washer
The model number of my Whirlpool dryer is LER4634JQ0. When I push the start button nothing happens. I have checked the fuses, the door latches and the plugs. I had been using the dryer on the day this...
Lift top up, it is hinged, and check if belt that is supposed to be around the drum and motor is broken. If it is broken it's a fairly easy fix.
Feb 23, 2011 | Whirlpool Dryers
When I push the start button, nothing happens. I have checked the breaker and the plug, both are OK. I just completed drying a load of clothes.
When I push the start button, nothing happens. I have checked the breaker and the plug, both are OK. I just completed drying a load of clothes. Kennmore 96590140.
Jan 01, 2011 | Kenmore 62602 Electric Dryer
Push the start button but nothing happens
check thermal fuse inside back of dryer usually little white fuse unplug and ohm out should ge a reading if good
Aug 09, 2009 | Whirlpool Dryers
Apr 02, 2009 | Whirlpool LGV4634JQ Gas Dryer
No start
e3 fault??? sounds like an open sensor, located right nest to the thermaal fuse.
May 08, 2008 | Whirlpool GEW9200L Electric Dryer
Wont start
try turning the drum by hand...is it jammed? if not, then: the motor will not turn due to a number of reasons: 1.) simply burned out copper windings 2.) switch not turning on motor or not turning on motor starting circuit-depending on design ...if jammed, then try to find the interference to turning
May 31, 2007 | Estate TEDX640JQ Electric Dryer
Dryers Logo
42 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
