Question about Samsung Televison & Video
  • 240 Answers
SOURCE: half screen showing
keep tv off.
it will only get wors
if sumon dosent work on it soon
the problem you are having in the vertical section of the tv
hav a repairman resolider all conection on the vertical IC and check the serounding componets for falts.
regards daniel.
PS the repair takes me about 15 min.
Posted on Jan 13, 2009
  • 118 Answers
SOURCE: Samsung Plasma TV - picture has 6 sections of horizontal lines
All I can say is when you watch T.V. the plasmas run off of plasma gas and when you leave something on for so long it burns in the screen. I have the same T.V. and when watching like the weather channel it leaves lines but they go away. If yours are permanent then you can't do anything, but it may help if you go on your remote and go to "menu" then look for "setup" and scroll down with the arrows on your remote. Look for "screen burn protection" and select "white screen". This will make your whole screen white and it may take out the lines. If you let it sit white it won't hurt it. All one color won't hurt, the only thing that hurts is like bright white lines in front of a dark background. Just give your T.V. a break from time to time ESPECIALLY ON VIDEO GAMES. T.V. shows that are HD usually have their channel icons that move or are very dim and they won't hurt. Just go to what I told you and let it sit about 20 minutes, if that doesn't help, then the T.V. you have i believe comes with a 2-year standard warranty and if it's under warranty take it back if you have the reciept. If no reciept then call 1-800-SAMSUNG.
Posted on Jan 30, 2009
  • 42 Answers
SOURCE: hitachi projection tv.7years old.can i clean or change the bulb,w
Remove the front screen
Carefully Remove it
Pull the bottom off
Then remove the screws on the bottom of the screen
when you have them off lift the screen assembly up
be careful of the wire going to the panel
you can move the screen to the side and gain acces with out unplugging the wire but again be careful
clean the mirror and the projection bulbs
with glass cleaner and spray only on to the rag not the mirror or projection bulbs
Put it all back together and your picture should be bright as before
Posted on Feb 10, 2009
SOURCE: When I turned the tv on only vertical lines appeared
I talked to a Samsung support helpline and it needs to be taken to a service center for repair.
Posted on Mar 03, 2009
  • 1689 Answers
SOURCE: Samsung hpn5039 worked for 6 years, now VERY dim.
The back plane lamps, and or the power lamp power supplies are failing. When considering 6 years of use, most likely both the lamps and the lamp supplies much be changed.
In many of these sets the back plane lamps are not replaceable. You will have to call the service rep in your area to find out if your set is serviceable.
From experience with these sets, after about 2 to 3 years proprietary parts become very difficult to have.
Jerry G.
Posted on Jan 19, 2010
Testimonial: "Seems about right. Thanks for your help! :-) "
My samsung led tv is getting dark
With a DLP TV, getting a darker picture means it is time to change the bulb.
Feb 16, 2015 | Samsung Televison & Video
How long u have this RCA analoge tv?Around 10 years or more and used it like about 5 or 6 hrs everydays?Yes,than ur tv it is losing CRT tube radiation cohetion.As times go bye years in years out the tv CRT-(tv tube) radiation will slowly dying out,Tv actual pictures will lost some of it luster and it brightnesses to the tv auctual pictures.Brightnesses of CRT tube will get darker and darker until the tv actual pictures barely it is watchable anymore.Contrast,Brightness and Colors adjusting more will help some.But u have to take this tv aparts and take a Flat scerw driver turn up a little bit more of the tv HV-(high voltage) SCREEN button on the FBT-(flyback transformer) to make any big differences of the CRT tube brightnesses.The FBT-(flyback tranformer) is the big block of plastic with a red wire with a black cap hook up to the tv CRT-(tv tube).This adjustment on of the FBT,HV-SCREEN button will help the tv CRT-(tv tube) last another year or two.
Aug 16, 2011 | RCA TruFlat 27F520T 27" TV
My HLP5063W tv comes on and works for 3 to 5 min then the pictures gets dark and the colors are distorted. The remote no longer operates the set and I can not turn it off using the front or side switch. ...
It sounds like your lamp is about to die out,this tv lamps are good for 6000-8000 life hours which is a average time of 2-4 years old and with time the picture starts to get darker and darker until one day black screen. Try Encompass .com ;
Jun 11, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung dlp has dark picture?
It sounds like your lamp is about to die out,this tv lamps are good for 6000-8000 life hours witch is a average time of 2-4 years old and with time the picture starts to get darker and darker until one day black screen here is a link with the lamp you need
Sep 03, 2010 | Samsung DLP HL-P5663W 56" TV
Tv is about 4 years old. Suddenly developed two
Your plasma screen is made up of 1080 verticle lines and now a few of these lines are not working. This is the screen itself and needs replacing.
May 22, 2010 | Samsung HP-T4254 42 in. Plasma Television
TV screen became a lot darker than normal.
yeah, opened the front flap of the TV>menu> brightness> increase. Sorted. No problem.
ain't gonna bother asking any more questions on this help at all .
cheers, Pat
Mar 30, 2009 | Toshiba Televison & Video
I have a JVC tv only 1 year old and the picture is getting dark.
have you tryed adjusting the picture in the menu section! this may help!! or on back of tv is adjusters those may help as well.
Mar 24, 2009 | JVC AV-27920 27" TV
Darker picture
Clean the lenes inside of the TV and the mirror and screen (a little dust build up on these three things adds up quick!) also if you smoke that can build up too! these tvs have too be cleaned inside
Nov 28, 2008 | Hitachi 57F500 57" Rear Projection...
Picture seems to be alot darker than before. toshiba 62hm95
I just replaced a lamp in a Sony LCD projection that was just over a year old and it was bad. It was a VERY dim picture. You have a DLP but, in either case a dim or dark picture is almost always caused by the lamp.
Feb 23, 2007 | Toshiba 62HM95 62" HDTV
Right 2 inches on edge of screen are darker than the rest of the screen
What is the model of the TV? Samsung DLP TV's start with HLS,HLP,HLW.....
Feb 06, 2007 | Samsung TX-R3080WH 30" TV
Televison & Video Logo
32 people viewed this question
Jerry Greenberg
Jerry Greenberg
