Question about Building Materials
How do I go about having my broken gliderol garage door locking system replaced?
4 Suggested Answers
SOURCE: Replacement for Garage Door Remote
The red button is the "learn" button. No resets.
Posted on Mar 25, 2009
  • 40734 Answers
SOURCE: How to lower automatic gliderol gts 2000 garage door
check that the controls are not reversed by pressing the opposite button to the direction you want
Posted on Apr 05, 2015
danlecours
  • 61 Answers
SOURCE: How to tighten chain after garage door closes gliderol gts 2000
go on this web page and do what is on the page 8 !!
Thermaglide electric garage door.Had a problem with door stopping whilst going up but would carry on moving with assistance eg lifting it whilst moving.
Check the big spring at the top. sounds like it could be broken or has come un wound. if this spring is working you should be able to push the door up without the opener. Unlock the opener and see if you can push it up. If you can then your opener could be the problem.
Apr 03, 2016 | Building Materials
Apr 05, 2015 | Motorcycles
Apr 05, 2015 | Garden
My garage door will not open. I pulled on the emergency rope to see if that would help but it did not.
Your torsion spring is probably broken. After you pull on the emergency rope, press the remote, that should move the chain and emergency lock out of the way, then you and 1 or 2 other people may be able to lift the door up if you really need to get the vehicle out. It depends if it is a single or double door or wood or metal, how heavy it will be. This can be dangerous and it could fall down on you. Check your torsion spring above the top of the door when closed, if there are two pieces then it is broken (on a single door.) A double door will have two springs, one on each side. One may be broken. You will need to get all the springs replaced, it counterbalances the door. If you have a garage door with arms on it, then the compression/extension spring is probably broken. If you are mechanically inclined, you can replace them, it is dangerous, be sure to watch a UTUBE video on it.
Dec 21, 2014 | Building Materials
My garage door will not open but approx. 8" , no cable broken , chain on track. Today I found that one spring is broken. how hard is it to replace.
I have built many garage doors and installed many door openers. The typical garage door spring is not that hard to replace. I have to have 2 steel rods 1/2 inch in diameter to slowly tighten the spring.
Oct 17, 2013 | Stanley Hardware 730610 110 Lb Garage Door...
Central locking on citroen xsara 2003
it sounds to me as it is a mechanical problem with one of the locks.make sure the doors are closed properly also when locking car.best of luck.
Oct 16, 2008 | Vehicle Parts & Accessories
Central locking keeps locking the car. Unable to open drivers side door
Hello, we have a 2003 Kia Rio- problem as above- unlocking and then locking- only way in and out through passenger door.
This is what I have done and everything is back to normal- I hope it works for you.
1 Remove 25AMP fuse that controls door central locking from main box under the bonnet.
(AT this stage my passenger door opens- drivers side does not, the mechanism won't fully rotate)
2, Spray key with WD40 (or similar moisture repellent lubricant). Gently turn key to loosen mechanism- Partly remove key and spray lubricant into lock, have fun locking and unlocking!
3, Replace 25 amp fuse
4, Write yourself a cheque for garage labour and parts and wife brownie points!
Aug 09, 2008 | Kia Rio Cars & Trucks
Building Materials Logo
43 people viewed this question
Top Building Materials Experts
hpgwva
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
