Question about Vacuums
How to remove brushes? - Vacuums
  • 1,830 Answers
What brand of vacuum is it?
Posted on May 17, 2017
How to remove brush roller
There are many different ways depending on your model but most vacuums have a bottom plate holding the brush roll in. Remove it to gain access to the brush roll. On some models you have to remove the top of the nozzle housing to get the brush roll out.
Jan 29, 2017 | Vacuums
Bissell Proheat 1383 removing brush motor to replace it with a new one.
May be a burned out collector of the armaturebetween the brush holder and armature ballbearings are maybe poor change the motor , and replace allways 2 brushes if its possible because 1 fieldcoil stator of the motor should have a problem if 1 brush is shorter than the other brush there is a disbalans with 1 long and a short brush , in the early years 50 60 or the more expensive vaccuums like Kirby 600 W motors
it is useful to change brushes buit in 60% of the cases you lost the brushes again in 1 month .
Oct 29, 2015 | Vacuums
Brush not turnning
The brush roller is driven by a belt installed on the motor shaft. The belt could be broken or off the shaft. The brush roller could be clogged inside the end caps with debris which prevents rotation. To solve the debris problem, it will be necessary to remove the belt from the motor shaft, then note the orientation of the end caps and remove the brush roller. Next, remove one end cap and check for clogging material. Remove the material. Slide the brush roller shaft away from the end of the brush roller to check for clogging material at the opposite end. Remove the material. Slide the brush roller shaft back into position and reinstall the end cap. Reinstall the brush roller in the correct position. Reinstall the belt. Check for proper rotation of the brush roller.
Apr 08, 2014 | Electrolux EL8905A Nimble Brushroll Clean...
Brushes will not rotate
I can't tell for sure from the pictures, but there are two possibilities - the drive belt to the brushes broke, or the brush can't turn due to excessive hair wrapped around the shaft. If the belt is OK but the brush does not turn, you should smell burning rubber.
If the belt is broken, you have to remove the bottom plate to expose the brush, remove the brush and the broken belt, and replace the belt, and put it back to gether. While you have the brush out, now would be a good time to clean it - remove the hair, etc from the brush and around the shaft. Good Luck!
Dec 19, 2012 | Hoover F7210-900 SteamVac V2 Upright...
How do you change a belt on a dyson DC07
Turn vacuum over so you can see the brush.
Using a standard screwdriver, undo the three fasteners just behind the brush.
Remove the base plate.
Remove the belt.
Remove roller brush.
Place new belt on roller brush and center it in position.
Feed belt through the hole, and return brush to position.
Ensure the brush ends are located in the slots correctly.
Pull the belt over the motor shaft.
Rotate the brush a few times to ensure belt is centered and secure.
Replace the base plate, tighten fasteners, and rotate the brush a few more times to make sure it turns properly and the belt isn't caught.
Mar 04, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Just purchased this Dyson dc24 today. brush doesn't spin after gettin tangled in a cord. removed the cord from the brush OK. I have several times: removed the brush and replaced it OK. pushed the red...
When you removed the brush roller dod you examine the end of the actual roller that is opposite from the removal opening. There is a gear that the roller fits over that may have gotten stripped when it became tangled. Check that the gear has not rounded off and look inside the roller bar to see if the area where the gear fits into may have gotten stripped as well. You might try to operate the vacuum without the roller brush installed for a few seconds just to see if the gear turns. When I say gear, it is actually a somall "post" about 1-2" long that the roller brush fits over. Hope this helps!
Dec 17, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
Roomba keeps saying "Clean Brushes"!!
Have you made sure the brushes aren't clogged with thread and hair, and that the brush bearings are still good?
1) remove the brush guard.
2) remove the brushes
3) remove any hair or debris using the cleaning tool
4) replace the Roombas brush bearings
5) replace brushed and brush guards
If this doesn't work then, try the following:
  1. Power off the Roomba.
  2. Remove the dirt bin.
  3. Place the robot upside down on a flat, padded surface.
  4. Check for any dust or dirt obstructing the Cliff Sensors (with Roomba upside down, the sensors are located in the four rectangular areas just inside the edge of the front bumper).
  5. Next, press the front bumper in to make sure it springs back.
  6. Make sure both yellow brush caps are installed correctly
  7. Make sure the main brush and the flapper brush each have a yellow bearing installed correctly.
Mar 26, 2010 | Roomba Robotic Floor Bagless Vacuum
I have a Eureka Altima and not sure how to change the belt?
1) Use handle release to lower handle
flat onto floor
2) Remove 2 screws from the front side of
brush roll cover
3) Lift and remove brush roll cover .
4) Remove brush roll and belt. Thread
new belt around motor shaft and
brush roll
5) Insert left end of brush roll first. Make
sure square on brush roll cap is in
place. Pull right side of brush roll to
stretch belt. Secure right end cap into
6) Rotate brush roll 2 turns to center belt.
7) Replace brush roll cover
8) Replace 2 screws
And you can get the maual here.
Good luck
Sep 27, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
How to clean the power brush on the miele vacuum. Is the brush removable? If so how do you remove it?
Greetings from,
Miele canisters have 2 different types of power brushes. The first, and most popular is the Miele SEB 217, and 213 Power heads. To remove the brush, follow these instructions.
On the bottom of the power head there are 2 yellow (older models it is black) plastic screws. You can remove these screws with a phillips head, or flat head screw driver. Simply unscrew these two screws. You do NOT have to remove these screws, just unscrew them to where they are loose enough to remove the bottom plate.
Once you have unscrewed the plastic screws, simply pull the bottom plate up and off of the power brush. You will notice the belt on the left hand side of the brush. Simply pull the brush up, and un hook the belt from the brush;
Now that you have unhooked the brush from the belt, you may thoroughly clean the brush, and un wrap any hair or thread that is wrapped around the brush. You will notice on the roller brush itself there are two indentions on both sides of the brush that run the entire length of the brush. You can take a knife or scissors and run them down the brush on both indentions, which will help you remove the stubborn debris wrapped around them.
Also you'll notice on both sides of the brush that there is a yellow bearing cap on both sides of the brush. You may pull these bearing caps off, and remove any debris that is around these caps. You may also lubricate these bearings with grease or WD-40, to ensure the brushes spin fluently.
After you have cleaned the brushes and bearings, insert the brush roller back through the belt, and into the power brush. You'll notice that the bearing cap will have two sides. One side of the bearing cap has 1 groove in it, the other side has 2 grooves.
When you reinsert the brush back into the power brush, you may lower the roller brushes if the machine has been used a lot. If the roller brush is older, you will want to re insert the brush with the side that has 2 grooves facing upwards, and the side with 1 groove in it, facing down. In the first picture above, you will see that the side with 1 groove is facing upwards and is visible to the camera. The side with 2 grooves is facing down. This is because this brush is new. If your brush is older, you will want to reverse that, and have the side with 2 grooves facing upwards. When the brush is back into the power head, simply put the bottom plate back on, (IMPORTANT! Make sure that in the front of the machine the bottom plate is completely hooked onto the front of the power brush, there should NOT be any space in the front) Once you have screwed the plastic screws back into the power brush, in the front of the power head, push the bottom plate upwards to make sure there it is fastened tightly in the front.
I hope this helps you. If you have the larger, less popular SEB236 power brush, just send me an email, I'd be happy to walk you through cleaning the brush on this one also. If you have any questions about this repair, please feel free to email with any questions, I really enjoy sharing my knowledge, and passion fixing vacuum cleaners.
Chris Jones
Sep 29, 2008 | Miele Vacuums
Vacuums Logo
32 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
