Question about Ovens
I have error code #138 appearing on my controller shutting off power
I have a Viking Oven and the code F o8 has shown up. What does that mean?
Hall effect sensor in cooling fan issue. Shut down and power up again . Or call tech assist at 888/845-4641. Hope this helps
Oct 20, 2014 | Viking Ovens
Kitchen Aid Superba double oven
f5e1 is a door locking error. try shutting off power for a minimum of 2 minutes to reset the control board. If you still get the error replace the latch. Here is the part to order.
Jun 19, 2013 | KitchenAid Architect Series KEMC308KSS...
Whirlpool TXFE366LVQ. When I turn selfclean after few minutes it shuts itself off and displays code F5E2
An F5 error code indicates that you need to check the oven door or the latching switch. The switch is used when cleaning the oven, for safe closure. If you find that the door or the latch switch do not function, you may need to replace them
F5-E2 means latch during clean error; the door and latch switch need checking and possible replacement.
1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Hope helps.
Jul 14, 2011 | Ovens
I went to do a self clean on my oven and I opened the door right as it was trying to lock. The door was open when it locked so the lock is out and now I can't shut the oven door. I tried turning off...
give this a try:
  1. Disconnect power from unit for a couple of minutes.
  2. Re-apply power.
  3. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
If this does not work, let me know what error code appears on the display. It should have be an F code with 1 or 3 numbers.
May 28, 2011 | Ovens
Microwave oven will not start - no power
The oven may shut off if the control board detects a problem such as a failed temperature sensor. The control will typically display an error code when this happens. Look for an error code in the display when the oven shuts off.
Another chance will be power failure or a weak breaker could be shutting off the oven. An electrician may need to check the breaker to check for proper power.
Hope this helps.
Shane
Apr 25, 2011 | Ovens
I am getting an F0 error code on my GE JTP15. It was working and then just shut-off. Then the error code appeared. I removed power for 30 minutes but the oven control did not reset.
F0
Stuck touch pad Usually means that either the touch pad or the oven control
(also called clock or ERC) is defective and needs to be replaced. If this fault
code cannot be cancelled, replace the oven control (also called clock or ERC),
touch pad, or both.
Jan 30, 2011 | GE JTP15 Electric Single Oven
Oven won't light and the display is flashing E1 F1
HI. This is essentially a board code(EEPROM check-sum error). Use this check procedure to confirm failure.
1. Safely disconnect the power from the affected unit for five minutes.(Shut of the appropriate circuit breaker or unplug from the wall)
2. Re-apply power and observe for at least one minute.
3. If the code re-appears, replace the main control board (also called ERC or clock).
Jul 06, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
E1 F5 Error Code RPD-305-PDS14 Whirlpool Double Oven. Woke up to code. Turn Off/On/Breaker and Appears to re-boot, until you turn the oven on, then 30 seconds later back to E1 F5. I replaced the whole...
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$RTYH
Feb 12, 2010 | Whirlpool GBS307PR Electric Single Oven
My oven is giving me an error of E6 F2, what does that mean
Equipment is Whirlpool double oven RBD305PDS14 built-in. After a very stormy summer 2007, I thought a power surge may have zapped the control board. Problem initially presented on display as error & fault "E6 F2"; simply pressing "Timer Off" would usually clear this error & fault code.
However, some months later, the display would often go completely blank followed by the beep sequence "short-long-short-short-short" (Morse code: dit dah dit dit dit). No error & fault code would appear. Pressing any keypad oven control did not work at all in this condition. When power was cycled at the breaker panel, the usual "PF" with clock display did not appear.
[TURN OVEN POWER OFF AT BREAKER!!!]
After following the excellent information on "how to remove the control panel" posted in this forum, I first tested the "control panel thermal fuse" (refer to the tech sheet that should be behind the control panel once it is removed). It showed a closed circuit.
I turned my attention to the "flexible" keypad connector cable (error & fault code "E6 F2" is a keypad or keypad connector problem; again, refer to tech sheet). The control panel has a board mounted female connector with two tabs that may be gently pulled upward to release the flexible cable.
I cleaned the flexible cable contact area (it seats into the board mounted female connector) carefully with a Q tip and some isopropyl alcohol. I reinserted the flexible cable and gently pressed down on the two tabs (noted above) on the board mounted female connector. VERY GENTLY tug on the flexible cable to insure it is gripped by the connector.
After all of this monkey business, I re-mounted the control panel display panel on the oven and restored power. So far, so good. After applying power, the "PF" with clock display always appears. I am able to set the clock and press "Start". Over functions normally. The clock displays as normal and I no longer observe the problem I described above.
BTW, I noted the incoming 240V has transient suppression (no surge protection, however
RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 19, 2009 | Whirlpool Ovens
The F7 code appears with a beeping noise. How do I turn off the beep for good.... selecting clear/off only works for a few seconds
Well, F7 error code occures due to
A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Thanks
May 27, 2009 | GE Built-In 24" Double Electric Wall Oven
Ovens Logo
35 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
