Question about Garden
I have a 4in riding mower. I took both rear wheels off to put tubes in them, when I put them back on the mower wouldn't move forward or reverse. Any suggestions?
    Top Expert:
  • Garden Master
  • 14,426 Answers
Didnt specify make model age --genetic answer--- check the axle release --check [ drive ] belt
Posted on May 08, 2017
It will run backwards but not forward
If you are able to move in reverse but not forward, you need to adjust the levers. First you will need to elevate the rear wheels and set the neutral. This will then allow you to set the levers for proper forward and reverse movements.
May 03, 2015 | Husqvarna Zero Turn Mower Z5426
When I put in forward or reverse it wont move
Two possibilities. 1. You may have disengaged the free wheeling valve which is usually low on the rear of the machine. It is designed to enable the moving of the machine without the engine running. 2. The wheel that you took off to change the tyre has a key fitted in the keyway in the axle and the wheel hub. These usually have to be slid in after the wheel is on the axle and before the circlip or nut is fitted. Did you check that the axle is not running free in the hub when in gear? You would be able to push the machine without the engine running if this key is absent. Suggest that you jack up the wheel free of the ground and see if it turns free on the axle.
Sep 28, 2014 | Ariens 46 in. 20 HP Hydrostatic Riding...
Why will my Snapper riding mower NOT go into gear? forward or reverse?
what kind of snapper... RER ( rear engine rider ) tractor style, model number will help greatly here because snapper has made mowers since the dawn of time !!!
Aug 23, 2014 | Snapper Garden
Riding mower won't move forward or reverse
WHAT MAKE AND MODEL MOWER? YES...YOU EASILY COULD HAVE BROKEN THE AXLE!
SEE IF EACH WHEEL WILL SPIN INDEPENDENTLY OF ONE ANOTHER IN BOTH DIRECTIONS. ALSO, SOME MOWERS HAVE A ENGAGE/DISENGAGE TRANS LEVER (USUALLY PULLS IN AND OUT AND LOCKS WITH A CLEVIS PIN RETAINER)
Jul 26, 2013 | Garden
Troy-bilt riding mower won't move in forward or reverse
I had a similar problem with my TroyBilt 50 inch zero turn mower. Was cutting grass when it stopped going either forward or backward even though it would start and the PTO would move the cutting blades. Turned out the tensioner spring for the belt that drives the motors near the rear wheels had gone missing. Searched the yard where I had cut and moved the machine but couldn't find it. A new one cost me about $7.50. Put the new one on and it worked fine.
Apr 19, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
Snapper rear riding mower won't move while in gear
yes your looking at the problem easy to change close the vent on the fuel cap remove the battery and lift it up and stand it on the rear bumper tubes (thats what there there for) after replacing you might need to move the links for the cable up near the pedal
Jul 11, 2012 | Garden
Rear end
Remove the center dust caps from the rear axles, start the tractor up and put it in gear and observe the axles, if one of them is spinning freely inside the wheel, you have lost the 1/4" square key that pins the wheel to the axle. Replace the key and you can go back to mowing. This often happens when a flat has been repaired and the wheel pushes the key out the back as you slide it back on the axle. Sometimes it will just barely catch at the edge of the wheel and work for a while then fall out and you not even know it
Sep 14, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Will not move runs great mower blades ingage but does not respond to forward or reverse.
the belt running to the back tires has either slipped off r broken off. to get to it you simply go to the back and remove the plate in between rear wheels.
Jun 14, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Lawnmower will not move in gear with motor running
Hi
Check to see if any oil leaks between rear wheels where the tractor was parked. Also make sure hydrostatic disengage lever, at rear of tractor by hitch, has to be pushed in.
Apr 05, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Hydrostatic mower goes in reverse but not forward. Only 73 hrs on it!
On my hydrostatic there is an adjustment on the forward/back lever which can be made to run all reverse or all forward. Normal setting gives both of course. Look at that adjustment. Maybe something let go.
Oct 14, 2008 | Garden
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
