Question about Sewing Machines
How to do the airel stitch - Sewing Machines
New project call for stitch length of 12. Is that about a number 2 on my 153 machine
The 12 probably refers to the number of stitches to an inch, so probably a 2.2 to 2.4 may be sufficient. A setting of 2.5 is probably closer to 10 stitches per inch. Twelve stitches per inch is good for most garment stitching. The stitches are not too far apart to allow popped stitches under stress and gapping between stitches nor too close together that would make it difficult to remove stitching when correcting a mistake.
https://www.quiltingcompany.com/understanding-stitch-length-quilty-pleasures-blog/
https://www.google.com/search?q=sewing+machine+stitch+length+gauge&ie=utf-8&oe=utf-8&client=firefox-b-1
Feb 27, 2018 | Sewing Machines
Need to do a satin stitch on Bernini 1630
Just set it for a short stitch length and a wide zig-zag. Test it and keep adjusting the stitch length so the thread will not overlap from stitch to stitch but also that the stitches are close enough so no fabric shows between the stitches.
Sewing Perfect Satin Stitch Wildly Wonderful Wearables Patterns Notions...
How to Sew Satin Stitch
Nov 28, 2017 | Sewing Machines
I have a Elna air electronic 68, I am not able to use different function. Like thr preprogrammed.
Your AE 68 will have three dials across the front, from L-R, stitch selector, stitch width and stitch length. To sew any stitch with a sidewise needle movement, you will need to turn the stitch selector to that stitch on the selector, then turn the stitch width to between 3 and 4 and the stitch length to a similar setting, adjusting to get the stitch formation you need. To sew with the discs, set all the dials to zero, then insert a cam into the Elnagraph on top of the machine. Then turn the selector to the disc icon, and the stitch length around to the "S" and stitch width to 4.
Don't use reverse if using the elnagraph stitches.
Jul 01, 2017 | Elna Sewing Machines
The User Manual does not have a complete stitch guide. Does my Huskystar 207 have a stretch stich?
FWIW, a stretch stitch is simply a stitch that stitches forward a few stitches and then reverses for a couple and then stitches forward again. Having had a machine with a stretch stitch, I found that using a zig-zag is just as effective and uses much less thread as well as less time at the machine. If the fabric is very stretchy, you can merely decrease the stitch length and increase the stitch width to give the stitch enough space to expand with the fabric without popping.
Viking Huskystar 207 Manuals
Jun 22, 2017 | Sewing Machines
How do I correct stitch length mechanism to produce 6 stitches per inch?
the stitch length is governed by the cam action connected to the walking foot
that means that the stitch length is governed by the amount of material that is pulled through in the period of time that the needle comes up and goes down
normally the cam action is set by the stitch length lever/ reverse lever
if there is a necessity for a longer stitch, the cam would have to be changed on the drive shaft underneath
That will require a discussion with a sewing machine mechanic to determine if there are cams or other linkages that can be fitted to alter the stitch length for the manufactured maximum
Oct 09, 2016 | Sewing Machines
What does C4 mean in knitting
I believe it means a 4 stitch cable or a stitch made with 4 threads. I found this on a knitting website and it might help:
"A 4-stitch cable will be made with 4 stitches, a 6-stitch cable with 6 stitches and so on. Most of the time these sets of stitches are divided equally.
For the 4-stitch cable the first 2 stitches are slipped purlwise onto a cable needle or double pointed needle whichever you prefer. You will knit the next two stitches on your left needle, and then knit the two stitches from the cable needle. The knitting stitches are crossed over each other and you have created a nice little cable stitch."
Here is a YouTube video for the stitch: How to Knit The 4 Stitch Cable
Mar 05, 2015 | Sewing Machines
Stitch width knob
What's the model? Do you have the stitch selector set on straight stitch, or on a stitch with a width component, like a blind hem stitch?
Some machines consider straight stitch to be a zigzag stitch of width=0, while others have separate settings for a straight stitch and a zigzag (or other) stitch.
Feb 11, 2014 | Elna Sewing Machines
Why straight stitch will not work but zigzag and herringbone stitches work on my machine.
it sounds like the machine needs to be checked at a sewing
machine shop to see what's wrong with the cam's or gear
that makes the stitches
Aug 01, 2012 | Sewing Machines
Trouble sewing lycra fabric using a zig zag stitch
You have the machine set for blind hem stitching. Change the stitch selector to stretch stitch, which is a single, in line stitching zig zag stitch.
Cheers,
Embroidery Services
San Diego, CA
Sep 13, 2017 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
