Question about The Kitchen Appliances - Others
Pitco commlink failuer cleaning rod stuck in drainer how can i enter the programing its allways commlink faliuer
How do i turn up the temperature on my pitco frilator
Hi there!
You can download owner's manual with programming guide for Pitco Frialator at
Feb 02, 2013 | Pitco Frialator SG18S Deep Fryer
How do you clean the Pitco Friatlator deep fryer?
Visit pitco web at, there are manuals which will help you in cleaning fryers.
Jan 08, 2011 | Pitco Frialator SG14 Deep Fryer
I need to adjust the timer on the right side fryer basket
Hi there.
If your fryer is PITCO, you can download programming manual at
Nov 18, 2010 | Pitco Frialator SG14 Deep Fryer
I had a failed tail light which I replaced but ever since then the glo plug warning light is constantly on but the glo plugs are fine and the car starts easily even on cold mornings on my 2002 C 270. How...
Dear Sir Glow plug light is on it didn't mean that glow plug faliuer, it mean the power supply is continusly on to glow plug, car will start good even incold condition,please check glow plug timer or show it technician ,but it can cause glow plug failuer in future. Thanks.
Oct 17, 2010 | 2002 Mercedes-Benz C-Class
Pitco ssh75 doesnt run yellow (right) light for melt/cook blinking 7 times tried reseting by unplugging but doesnt reset
7 flashes on ignition module's diagnostic led indicates that the flame rod is shorted to ground. Check the igniter tip's clearance to the pilot assembly and adjust if necessary. Also check the igniter cable for damaged insulation.
Oct 12, 2010 | Pitco Frialator SG14 Deep Fryer
My pitco frialator chips fryer diplaying CFG error
CFG error on controller board can be cleared by resetting the controller back to factory setting and by doing this, all program added after the factory setting will be erased so you have to reprogram them again.
Programming guides are downloadable at PITCO site on
Jul 29, 2010 | Pitco Frialator SG14 Deep Fryer
Pitco Frialator Model 14S
Excellent reason to use Dormont flex lines.
If water gets to your combination valve (the thing with the on-off knob,) it should be replaced. Can you hear gas hissing? If there is gas at the orifice, it should light. check to see that all of the air is purged. Can you smell gas?
Sep 13, 2008 | Pitco Frialator Kitchen Appliances -...
Kitchen Appliances - Others Logo
35 people viewed this question
Top Kitchen Appliances - Others Experts
Level 1 Expert
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
