Question about Panasonic Computers & Internet
What is the difference between CF-19KJRAGAM and cf-19KHRAGAM panasonic toughbook
SOURCE: Panasonic CF-51 Toughbook Fn keys don't work at all
The following website contains the needed drivers:
Select your model of CF-51 Toughbook, but you MUST be specific. There are about nine variations of the CF-51 so you must use the right drivers.
Download the hkeyapp, hkeyset, and hotkey files and unpack all files. Use the default unpack locations. If you download the files for a laptop version that is not your own, when you try to run any of these files the computer will tell you that the file is not for your model. If the files successfully unpack then you know you have the right files.
For hkeyset and hkeyapp you must run the set-up applications in the unpacked folders.
Go to Control Panel>System>Hardware>Device Manager and go to Other Devices.
The Hotkeys will appear as an "Unknown Devices" so if there is more than one, right click and choose "Update Driver".
Select "Install driver from specific location" and direct it to "C:\util2\drivers\hotkey" folder.
The computer will find the file and install the driver after which point you must restart the computer.
Hope this helps. It took me a while to figure this stuff out on my own so hope it speeds up somebody else's attempt.
Posted on Dec 25, 2008
  • 144 Answers
SOURCE: keyboard installation for CF-52 toughbook
Here you , this is a step by step disassembly guide with pictures
Its for a Toughbook CF-50 but it should be similar as theres not too much difference in the model number
Posted on Jan 04, 2009
  • 4806 Answers
SOURCE: panasonic toughbook model number
Hi there
Download drivers for both if you are unsure, one way to tell if its a MK1, look underneath the laptop at the model number, if is says neither MK's its MK1 as it will say if its a MK2.
Saying that the drivers should work on both machine models
Good luck and kind regards
Posted on Jan 19, 2009
  • 565 Answers
SOURCE: drivers:Audo,Network,Video of panasonic toughbook CF-51 RCVDNBE
Posted on Apr 10, 2009
  • 484 Answers
SOURCE: upgrade hard drive in panasonic toughbook cf-50
1 - Using a stack of DVD RW blank disks, or a large capacity USB Flash/Jump Drive, back up your Laptop computer completely. If necessary, Use WinZIP to ensue that everything has been compressed into the smallest capacity possible.
2 - When you are certain that you have backed up the drive completely, remove the older drive
3 - Line up the new drive and the old drive and ensure the jumpers are set to the same settings as they were set on the older HDD.
4 - Once you are sure, you then restore everything from the back-up drive for the old hdd to the new disk drive.
5 - Test to ensure that everything from the old drive has been backed up from the old drive to the new drive.
6 - If you are comfortable that your backup has been completly restored from the backup meda to the new, larger hard drive, then be certain that you have restored from the older drive to the new drive, tighten all screws and cables, then close all ports and ensure that everything has been done properly by and for you.
7 - Be certain that you have created the same user accounts in the new drive as you had on the older drive.
8 - Now, power off the new drive while in the laptop. Wait about 30 seconds to one minute, then restart the new hard disk drive.
9 Test everything, to be sure that everything works properly. Go through everything from the top of the menu to the bottom of the menu. Try all accessories, try all applications. Ensure that all works right and that the applications work as they used to work, when it was on the old drive.
10 - Remember, you have a warranty on the new HDD, so be sure that you have tested everything to ensure that it all works properly, before you sign off on this new drive.
11 - Once you are certain that it all works correctly, you can then be sure that it is working properly and competely, because only you know if things are working correctly as they should be.
12 - Then you can sign off and you can be sure that things work properly.
13 - As carpenters say ... measure twice; cut once. You can only do this one time, so if you measure it more than one tim, you can be certain that you will get it done correctly and be happy that you did it right. from beginning to end.
Have fun. Don't be too serious about it, but do be careful, and get it right. Remember, get it right the first time, and you will be pleased with the results at the end.
Posted on Jun 22, 2009
Remove bios password for a panasonic toughbook cf-30k
  • Press "F2" on your keyboard when you see the Panasonic logo appear on the screen. You will immediately be prompted to enter your Panasonic Toughbook Cf-29 BIOS password. Type the word "Biostar" into the password prompt. This is your Panasonic Toughbook Cf-29 backdoor BIOS password. Press the "Enter" key to unlock your Panasonic Toughbook Cf-29 BIOS.
  • Mar 10, 2014 | Panasonic Toughbook CF-30K (CF-30K3PAQAM)...
    No sound cf-52
    Drivers for the CF-27 do not seem to be available but drivers for the CF-52 are available from the Official Panasonic Toughbook Support Website which you can find here:
    Official Support Download Center of the Drivers Manuals and FAQs TOUGHBOOK...
    Good Luck to you and Best Regards from:
    Richard, Montreal Based Panasonic Canada Toughbook
    Authorized Dealer since 1989.
    Feb 01, 2014 | Panasonic Toughbook CF-27 Notebook
    I want panasonic cf-m34 manuals
    Jan 15, 2011 | Panasonic Toughbook 34 High Bright...
    All drivers of toughbook cf-51 are with differently specied
    Please be more specific, not sure what type of drivers you're reffering to .
    Apr 10, 2009 | Panasonic Toughbook CF-51 Notebook
    Manual for Panasonic CF-27 Toughbook
    Web Site
    Donot enter model# in first slot.
    Enter Computers in second
    Enter Toughbook in third
    Select CF-27E
    Everythink is there, two pages.
    Manual isn't much use.
    Jan 13, 2009 | Panasonic Toughbook CF-27 Notebook
    Keyboard installation for CF-52 toughbook
    Jan 04, 2009 | Panasonic ToughBook 52 Notebook
    Computers & Internet Logo
    69 people viewed this question
    Top Panasonic Computers & Internet Experts
    Oloyede Monsuru
    micky dee
    Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
