Question about Watches
Iff I get a message or whattsapp in it does not come throughon my bracelet
Link removal from bracelet?
    1. Use the steps below to remove your band. You must separate the Link Bracelet into two pieces before removing the band from your Apple Watch. While removing the band, don't force the band or twist it. Use the steps below to avoid damaging the band or clasp.Jun 19, 2015
      Remove the Link Bracelet on your Apple Watch - Apple ...
      https://support.apple.com/en-us/HT204831 Apple Inc.
    Feedback
  1. How to resize or remove links from your Magnetic Bracelet ...
Jan 01, 2016 | Watches
I need to buy new bracelet
mcdevito75 here, BEST BET for your Ebel watch, look for a small watch repair shop in your area, to order a new bracelet.
Jul 13, 2010 | Ebel Type E Stainless Steel Rubber Strap...
After buying this model watch bracelet links are rusted and torn with one year of purchasing. When i took that watch to the show room where i purchased. They kept it for 40 days saying that they has to...
mcdevito75 here, Many watches built today are not comming out with replacement Bands (straps, Bracelets) from the factory, the cost of makeing and keeping extra bands on hand is too high, they should at least have a few extra links to replace worn ones. Chances are your warantee is over on the watch and in that case, you"ll have to find another band, Bracelet on your own. Best Bet, visit a small watch repair shop in your area for another bracelet, band, Strap.
Jun 29, 2010 | Watches
How do you remove the end link?
take it to a repairer is my advice. but if you want to try you need a very lite hammer a very fine nail and a block to place the bracelet on its side. see what i mean..you do need the correct tools for this job as you may scratch the watch or damage the pins and barrels in the bracelet..place the watch on the side place and you should see the pin thats holding the bracelet section hit the pin on top with the very fine nail and it should push the pin through the bracelet you have to do this twice also there will be either 1 or 2 barrels inside the bracelet when you knock through dont loose these ..but you will be in tears by now as you have prob damaged your bracelet repair could be 200.oo .....instead of 20.oo to remove links....
Mar 26, 2010 | Omega Seamaster Planet Ocean Chronograph...
How to adjust expandable bracelet pleaseI would like to remove links to make it smaller.
If you are ready to take that risk, here is how you can do that.
First- get watch on your wrist and by squeezing the bracelet count how many links you have to take out to make it tight enough (say 4 for example).
Check the sides of a bracelet. You will notice that the upper band metal is flipped over the bracelet side. Take tweezers or small pliers and unbend one of these. Try to do as little damage as possible.
When it's done, you will see two metal staples inserted into the bracelet. You have to pull them out. While pulling out, remember how they where positioned, as you will need to drive them back in the same manner.
So, when the staples are out, do the same on the other side of bracelet. Now you have bracelet in two halves.
Count off 4 links and undo the staples in joint of 4th and 5th link in the same manner as previously.
When links are out, take the staples and drive them back into the bracelet joining two ends together. You have to do that exactly the same way and position as you took them out.
When all staples are in place, bend the metal back over the bracelet sides.
BE WARNED: as you gonna do it first time, be ready that you can damage the bracelet or can not put it back together.
Good luck.
Jul 29, 2009 | Casio Watches
Self-adjustable bracelet watch
Check the sides of a bracelet. You will notice that the upper bands metal is flipped over the bracelets side. Take tweezers or small pliers and unbend one of these. Try to do as little damage as possible.
When links are out, take the staples and drive them back into the bracelet koining two ends together. You have to do that exactly the same way and position as you took them out.
When all staples are in place, bend the metal back over to the bracelet sides.
Good luck.
Rate me, please.
Mar 19, 2009 | Timex 2J611 Watch
I have a bracelet link bracelet expansion bracelet watch I need to remove some links
Good luck
Dec 21, 2008 | Timex 2J611 Watch
Watch strap to loose
Good luck.
Dec 18, 2008 | Watches
I want to adjust the steel bracelet on my new GMT II
You can do it yourself but proper watchmakers screwdriver is needed.
Check the sides of your bracelet and you will see screw ends with grooves. Unscrew them and adjust your bracelet (take the links out). Then screw them back in.
Regards
Arthur
Dec 13, 2008 | Rolex Watches
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
