Televison & Video Logo
A
Anonymous Posted on May 08, 2017
I bought a go.video 3930 for $30 and got it to work with a universal remote but the setup button doesn't work.
5 Related Answers
Anonymous
  • Posted on Mar 01, 2008
SOURCE: sanyo stuck on video mode
Yippie, I figured out a solution that worked!!! I have a univeral remote from comcast, on that remote near the bottom left is a small button that says (input) tv/vcr, press that one time and whala!! the tv video screen was gone, I had to manually change the channel from the tv channel button on the unit. once I changed the channel to 3, my universal remote worked... the button is the second one from the bottom left... I was on hold with sanyo for a long time and just kept trying on my own, so good luck!!!!
Anonymous
  • Posted on Sep 04, 2008
ok i have a sanyo tv that was set to imput my remote messed up but now it is fixed i cant figure out how to get it off. in order for me to reprogram my Universal remote i have it has to scan channles right wut do i do??? plzzz help me!
frank_crab
  • 233 Answers
  • Posted on Jun 06, 2009
SOURCE: initial setup using universal remote
Sorry,
You might have to use the menu button on the T.V. itself (if it has one). I have issues also with my Comcast remote in that they will do just very basic functions. The only other option I can provide as a solution would be to try an electronics retailer such as your local radio shack, best buy, frys, etc. Not much else can be done with the Comcast remote unfortunately.
Anonymous
  • 9 Answers
  • Posted on Sep 08, 2009
SOURCE: I bought a vizio 42
A universal remote will work as long as vizio is listed as one of the brands on the back of the box for the remote. Most of them are easy to program as long as you follow the directions. You can pick one up for less than ten bucks just about anywhere.
Anonymous
  • Posted on Nov 02, 2009
SOURCE: Universal Remote
i have a tv dvd combo emerson brand i have the tv working but i need the code for the dvd can anyone help
Model LED32B30RQ need 4 digit code to program universal remote. RCA TV
The 4-digit code to program a universal remote to work with a RCA LED32B30RQ TV model is likely to be one of the following:
11447 11758 11442
To program the universal remote to work with the RCA LED32B30RQ TV:
  1. Turn on the TV
  2. Press and hold the "Setup" button on the universal remote until the "TV" button blinks twice.
  3. Press the "TV" button on the remote.
  4. Enter the 4-digit code for your TV using the number buttons on the remote.
  5. Press the "Power" button on the remote. The TV should turn off.
  6. Press the "Setup" button again to lock in the code.
If the TV does not turn off after entering the code, please try the other codes listed above. If none of the codes work, you may need to refer to the universal remote manual or contact the manufacturer for further assistance.
Note: The method to program the universal remote may vary depending on the remote brand and model
2answers
My remote was working fine until i moved. I have Direct Tv and the remote from Direct Tv works on guide. I bought a new remote from Magnavox but it doesn't work my tv. what should I try? '
You have to program the remote control to synchronize with TV. If you wish to get moredetails; codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
I have an older Emerson 13 inch color TV/VCR The remote wore out so I bought a Universal remote. It doesn't work
0045,0026,0069,0038,0024. These are the setup codes to check with Emerson TV/VCR combos. If you wish to get more codes and other details, check this link.
12helpful
2answers
Tv cable and dvd lights keep flashing and tv doesn't get signal
The remote is in safe mode, remove batteries and reinsert batteries while keeping the button 2 pressed.
4helpful
2answers
Need code for my vizio tv i bought a ihip remote control for my tv
The instructions on letting the Hipi remote to seach for the code that came with my remote are not correct. I used the instructions from HOWTO.COM and printed below. There are two changes from the printed instructions. The first is to push the <TV> button after the <Code Search> button. The second is that the <Enter> button saved the code not the <MUTE> button.
Instructions
Turn on the Vizio TV.
Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
Press the "TV" button at the top of the Jumbo Universal Remote.
Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. (This took only a few tries for my Vizio TV)
5
Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6
Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
19helpful
5answers
Trouble programming Universal Remote to a DTV Converter Box...
Not a complete solution, but, around the last page (pg. 14) of your converter box manual there are codes listed for universal remotes. I happen to have a Philips remote that is listed. My code to control my dtv box is 0354. It appears that they have all codes listed for all Radioshack model universal remotes. I would suggest getting a Radioshack remote for Your "Digital Stream" (Radioshack) dtv box...
I found a haier tv. problem is no remote. if i bought a universal remote wat r the codes to program the universal remote to the tv or is there a way to select video 1 or video 2 with out it?
I own a One-for-All universal remote (model URC-4220) which works with Haier TVs. The remote comes with a booklet with a list of setup codes.
In order to determine if you can change things manually, you would need to push any buttons on the TV, and see if VIDEO 1 or VIDEO 2 appears on the screen. If nothing like this happens, then you need to buy a universal remote.
I purchased my remote at Walmart, for less than 10 dollars.
Top Universal Televison & Video Experts
vince
Jennifer Rock
Jennifer Rock
Are you an Universal Televison and Video Expert? Answer questions, earn points and help others
