How do i get the child saftey symbol off - Washing Machines
Door not unlocking Fisher Paykel front loader Wh60f60w. The cycle appears to have completed but the door remains locked well beyond normal lock delay. Is there a manual release?
Have switched this on?
Child-proof lock
? You can protect the appliance from being tampered by activating the child-proof lock.
? When activated, no change can be made to the programme running.
To activate the child-proof lock:
1 Press the 1st and 2nd additional function buttons for 3 seconds.
2 The "C ON" (child lock is activated) symbol appears on the screen.
Note: the child lock symbol will also be displayed whenever any button is pressed while the
machine is child-locked.
3 The child-proof lock lamp on the programme follow-up indicator will light up when the childproof lock is activated.
To deactivate the child-proof lock:
2 The "C OFF" (child-proof lock is deactivated) symbol appears on the screen.
3 The child-proof lock lamp on the programme follow-up indicator will go off when the child-proof
lock is deactivated.
Apr 01, 2017 | Fisher Washing Machines
How to disengage the saftey on 06' dodge caravan sxt power sliding door?
disengage the saftey Anon, I believe it is done on the overhead console or if you mean the child prevention lock, it is a small switch by the doors latching assembly. Links below give instruction.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Thread 2011 Grand Caravan Sliding Door Child Safety Lock Engaging on its...
Dodge 2006 Grand Caravan User Manual
How To Install Replace Power Sliding Door Lock Actuator Chrysler Town and...
Apr 03, 2016 | Dodge Cars & Trucks
1997 Camry -rear left door won't open from inside. Linkges and snap on clips appears to be OK. Toggled the child saftey lever many times but the problem remains. What to do next and how?
really sounds like a linkage is off somewhere, could be up at the release inside the door,Sometimes hard to see. Could also be in need of some oil. make sure inside handle is not broke also. hope this helps and good luck.
Aug 12, 2012 | Toyota Camry Cars & Trucks
Green light stays on the child saftey lock, and the operation lamp won't come on either
CL = Child Lock. Press Timer & Min buttons simultaneously for 5 seconds to engage/disengage function.
Jan 18, 2011 | Heating & Cooling
Lost remote can not turn child saftey off
Jul 03, 2010 | Philips DVP721VR DVD Player/VCR
Removing child lock from heater
Press and hold down on the button until you hear a beep.
Aug 18, 2008 | Heating & Cooling
Door lock accent 2000 rear door lock jammed
door handle on the out side has never worked. And my wife moved the child saftey lock to the locked position and closed the door, now we can't open it. How can I move the child saftey lock back to the unlocked position when the door won't open?
Jul 02, 2008 | 2000 Hyundai Accent
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
