Where do I attach source water hose to washer
3 Suggested Answers
  • 523 Answers
SOURCE: Washing Machine Not Filling With Water Suddenly
make sure ya have power going to valve
Posted on Jun 23, 2010
  • 2694 Answers
SOURCE: I have a basic front
you must of cross threaded the plastic on the water valve,most likely you'll need to replace the valve
Posted on Jan 29, 2011
Hy, I have a washmasine bosch WAE28267SN that sow me an error E02 that's the error. Somebody can help me with some tips Thanks
The E02 error means that the washer is slow to fill. This can be caused by a problem with the incoming water hoses, the water valves or the washer draining as it fills.
The first thing to check is the incoming water if you have very little water in the washer. Make sure that the shut-off valves have been opened fully. If they were fully open, close them. If they were closed, check if that solves your E02 problem. Next remove the water hoses. A damaged anti-flood hose can reduce the water flow to a trickle. Clean the filters at both the shut-off valves and the intake valve on the washer. Replace the hoses at the shut-off valves. With a bucket below the hoses, turn on the shut-off valves and check that you are getting good flow. Now, attach the hoses to the washer. Check if the washer fills properly.
Check that the drain hose is positioned so that the outlet is above the water line of the washer. If your E02 issue continues and no water gets into the machine, then the inlet valve could be stuck in the closed position. If the washer is filling and the E02 error persists, then the water flow sensor may be a problem. This sensor has air tubes that can become clogged. Make sure that they have no dirt. There are other parts in this sensor that could be damaged.
Unfortunately, I don't have a source for parts for this washer. Some Bosch water inlet valves are available here: . If your washer is under warranty, contact Bosch.
I hope this helps.
Jun 15, 2016 | Bosch Washing Machines
Why doesn't it work when the water hose is attached?
Pressure washers can only be started/run with water attached. No water burned out pump in 5 seconds! If pump puts out high pressure water without wand/hose attached, bad wand or hose, if not bad pump. Replace pump.
Apr 05, 2016 | Garden
The black hose that drains the water out has come off and draining water straight out as it fills. I cannot for the life of me figure out where it connects to. Any help would be great!
The black discharge hose (the J shaped one) is connected to the output side of the discharge pump inside the washer. It's likely the hose has come off.
  • first, unplug the washer.
  • Shut off the hot and cold water faucets to the washer.
  • Pull the washer away so you have access to the back.
  • Remove screws holding the back panel in place.
  • Remove panel.
  • Examine the hose where it attaches to the pump. Look for cracks, holes or broken ends.
  • Examine the clamp attaching the hose. Is it broken or worn?
  • Replace any of the above hoses and/or clamps if faulty with hardware comparable with your model. Re-assemble in reverse sequence of dis-assembly.
  • Attach hot/cold water lines.
  • Ensure ALL excess water has been removed before plugging washer in. Ensure ground wire is attached!
  • Plug washer in and start cycle. Examine for leaks.
Feb 01, 2016 | Washing Machines
Washer leaks water on floor
its possibly the door seal if its a front loader, or a hose, you can easily remove the back cover panel re attach any cords or hoses needed to remove the panel then operate it while looking for the source
Jun 07, 2013 | Washing Machines
Washer fills extremely slow. Hoses are fine water
Hi, check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve.
Jun 19, 2011 | Maytag PAV2300 Top Load Washer
I will have low water pressure supply from source. how do i adjust for this? model GX200 with model Annovi Reverberi xtv 3g.22 pump
Low water pressure from source is generally not a problem unless water hose to washer collapses when use. You only need to supply the pump just 3 to 5 gallons of water per minute. Easy to check. Just open water supply to hose and capture water flowing out of hose into 5 gallon bucket (capture water in bucket for 1 min., should pretty much fill it ). Just use as normal. Good luck
Sep 06, 2010 | Honda Pressure Washer PSI 3000
Whirlpool ultimate 2 model#lsw9750pw3 ser.ct1941128 leaking in front. appears to leak from a bow with 2 hose connected.
Your water pump is attached to the motor and is probably the source of your water leak.
Replace the pump.
Use the attached video to show how to access the cabinet and pump.
May 03, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
Top Washing Machines Experts
