Question about Sony Computers & Internet
My Sony a200 will no longer connect to my Macbook Pro- when I plug it in, it says 'initialising USB connection' but my laptop doesn't pick anything up?
I know the camera is a fairly old model by now, but until recently it was still working fine with my Macbook Pro, even working with Photos since it replaced iPhoto.
myjosh007
  • 530 Answers
SOURCE: USB flash drive not recognized by Macbook Pro
hi im josh in cebu phils. if that happened that the usb port don't detect your usb drive then there maybe some problem in your pc. friend all you have to do is check first the usb connections of your pc.you can browse the my computer device manager then click the usb icons and see if marked + or 2nd you reboot your pc then go to bios setup utility then go to peripherals then check wether it is enable.if disable usb on board you enable it. and don't forget to save the changes you made before you exit. then reboot your pc. then problem will be solved. good luck please vote me so that i will know if i helped you.thnks
Posted on Feb 23, 2009
  • 4044 Answers
SOURCE: Have D-link DIR-615 router and Comcast for
Did you set the IP address manually on the other computer? Is your router set to act as DHCP server and assign IP addresses automatically? If everything is set to DHCP then check the router and make sure it is transmitting on channle 10. Most providers set the cahnnel to 6 which has issues with HP laptops on occassion and maybe effecting you as well.
Posted on Aug 24, 2009
  • 38 Answers
SOURCE: MacBook Pro won't recognize canon powershot SD400
Hello. You need to probably reinstall the drivers. but first you have to remove the drivers that are all ready installed. first unplug your usb cord. then to remove the drivers allready installed,, on your computer, press start, then when the box open's up, then right click on computer. another box will open up. then left click at the bottom of that box on properties. another box will open up, then click on device manager. after you click on device manager another box will open up with all your devices. look for the previous camera you had installed. it might be under imaging devices. once you locate that, then right click on it. then choose uninstall. Make sure you have your new software loaded in your cd/dvd rom drive. after it is done uninstalling, just restart your computer. at the bottom right of your screen, it should say, found new device, it will ask you from where do you want to load the new drivers for it. click on the drive that contains the software. it then will load your new drivers up. It then should communicate with your camera. Hope this helps. Ron
Posted on Sep 08, 2009
leepania
  • 1099 Answers
SOURCE: Kodak EasyShare C653 Camera, cannot connect to my macbook
Try a dig. USB plug,
Try a dif. cable.
Try with a cardreader.
If your cable is faulty it is covered under the same 1 year warranty as the cam.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Nov 03, 2009
  • 11967 Answers
SOURCE: Canon Powershot S2 IS is not recognized on my iMac
Simple fix...use a separate card reader to download to a folder you create on your desktop. Once there, you can move them to iphoto.
Posted on Jan 05, 2010
Sumvision egem external hdd
more often hardware compatibility issue, try using different usb cable first,
Mar 18, 2014 | Apple Computers & Internet
Ms9535 won't connect to macbook pro
Apple don't allow anything to link to Macbook's via bluetooth. I can't even connect my iPhone 4 to my Macbook Pro unless I connect it with a USB cable.
Nov 11, 2012 | Metrologic MS9535 Voyager BT Accessories...
Connecting a EVI-D100 to a Macbook Pro Laptop Help.
Hi, I have a Sony EVI D100 that works. I have a Visca USB Cable and an s-Video cable and video cable. I will be connecting it to my MacBook Pro. What else do I need to use this Cam with my Mac to feed video to the mac? I also have a Mini Display Port To AV/CVBS/RCA/S-Video Converter Mac
Jul 29, 2012 | Sony EVI-D100 Webcam
My mac book and epson projector doesn't show the signal
To my knowledge there are no video drivers to output video on a Mac USB port in the Mac OS system. There are however, devices that connect to the USB port that will give video out on Conventional (VGA, DVI, HDMI, etc) connectors.e.g. http://www.newertech.com/products/viddu2dvia.phpMost projectors connect via VGA - what Projector are you using?
Jan 19, 2012 | Apple MacBook Pro Notebook
I have macbook pro version 10.6.6 and i have reliance netconnect usb connection. but i am having problem after few mins using internet my laptop shows a message that i need to shut down the compter and...
I too have macbook pro version 10.6.6 and i have reliance netconnect usb connection. but i am having problem after few mins using internet my laptop shows a message that i need to shut down the compter and restart again. its happening all the time.
please advise what i need to fix this problem. i think some drivers compatible with macbook pro
Apr 17, 2011 | Computers & Internet
Is these a driver to get USB connection to macbook
Are you asking if there is an adapter? There actually is an adapter (USB to S-Video) that will work between the two. However, with my MacBook C2D 2.4 GHZ, I use mini DVI to VGA adapter. This allows instant laptop to projector picture and sound. You can use it for anything from powerpoint to movies or even as a giant monitor. The mini-DVI to VGA adapter can be purchased at Best Buy for less than $20. Look for it in the accessory aisle near the Apple machines. IMO, this is a priceless addition to your MacBook. I hope this helps! Please remember to vote if it does.
Jan 27, 2010 | Apple MacBook Pro Laptop Computer with...
I have a new Macbook, but it doesn't have a
Buy a USB card reader, this will show your card (which you used in the camera) as a normal disk in finder
Jul 02, 2009 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
Frozen Network Preference pane on MacBook Pro
Although this is hard to diagnose with the information given I hope this may help.First we need to do a permissions repair. Open the Hard drive icon on your desktop> Applications> Utility Folder (near the bottom)> Disk utility> Select your Disk (the one under the main drive description)> click "Verify Permissions" when that is complete> Click "Repair Permissions" if it finds permission issues.
Next: Open System Preferences> select Network> Select Airport> Select the Drop down menu> Select Edit locations> Name location> If DHCP is not automatic then select DHCP. Click apply then restart.
If unable to connect then reset Airport by unplugging from back and waiting 30 seconds for memory to clear and replugging back in. Wait for all lights to become steady, then attempt to connect again.
Feb 02, 2009 | Apple MacBook Pro Laptop Computer with...
MacBook Internet connection
ok call me or I can post for you. I know what your problem is. But i need to know what model netopia router you have. Kepp in touch
Thank you
Jason
Feb 09, 2008 | Apple MacBook Pro Laptop Computer with...
Computers & Internet Logo
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
