Question about The Health & Beauty
Assembling the blades on my clipper - The Health & Beauty
geokohler
  • 304 Answers
SOURCE: barber clipper blades
Soak them in motor oil the use 400 grit wet sandpaper (The black kind available at the hardware store) and lightly sand off the rust. They will be good as new when you are done.
George
Posted on Jul 25, 2008
  • 22 Answers
SOURCE: Oster clipper blades get red hot and won't cut.
see this link, its for the A5. The A5 is the animal version of the 76.
http://www.peasridge.co.uk/clipper-advice/clippers-products-oster-a5.shtml
I dont know what model you have, but if you need schematics for YOUR model see this link.
http://www.clipperrepair.com/parts.htm?brand=8
Posted on Feb 02, 2009
SOURCE: Andis Ultra Edge Pet Clipper Assembly Help
I took my andis ceramic edge blade apart to clean. Now my clipper will no longer cut my dog's hair
Posted on Aug 23, 2009
SOURCE: andis ag2 clippers sound loud
Check the tension of the hinge assembly which you slot your blades onto the hinge should be stiff (not moving by finger) also check the latch is connecting when the blades are fitted (check the blades wont pull off without depressing the latch. Its possible the blade drive may require replacing again they do not last long if your a busy groomer.
Posted on Nov 19, 2009
SOURCE: I have andis AGC 2 dog clippers. I have having
Ok you need to locate the Latch which holds the blades into place. There should be a black piece of metal at the rear end of the clipper blade whilst on the clippers, simply push this in towards the blade and at the same time pull the front edge of the blade away from the clipper to release this should simply pull off in a forward direction.
Fitting is easier slide a blade onto the tongue of the Hinge Assembly and pull it into the body of the clipper.
Posted on Mar 18, 2010
Testimonial: "Thanks so much for your help. The hinge assembly is what tripped me up. Once you explained that is was really quite easy. Thank you!"
Oster A-5 Golden clipper blade is not flush against the clipper so wont clip you have to hold the blade down tight so it will clip.
see if the blade and hinge have moved away from the body of the clipper, the two screws either side of the hinge assembly may need tightening, or the main body may need replacing,
If its just one blade then there must be a problem with that blade.
Oct 19, 2010 | Oster Golden A5 2-Speed Universal Motor...
Cutting blade doesn't move
could be the spring is faulty on thie hinge assembly or the tip of the latch has brocken off not securing the blades to the clipper, either way check to see if the blade will disconnect from the clipper without depressing the latch. related clipper parts can be found at www.angliaclipperservices.com
Jul 31, 2010 | Oster Golden A5 2-Speed Universal Motor...
Oster clippers blade
John! No Problem!
First put the bigger of the two blades witht the size/number facing down, put the cutter on top. (with the side with the flat side of the teeth facing down) Then put the tongue guide inside the tension spring, make sure the tension spring rail is on the tension rail and place them on top of the cutter. To see which bits these are go to: http://www.sheareaseltd.com/clipper-blade-sharpening/clipper-blades-the-parts
This picture whows the front and back, it differs slightly from your blade, but its same meat different gravy!
Hold all this together with your finger and thumb, flip it over and scre the whole lot together!
Jul 01, 2010 | Oster Golden A5 2-Speed Universal Motor...
Brand new blades #10 in perticular leave stripes
hi, new blades are not the answer try replacing the blade drive assembly which is located at the drive end of the clipper and goes from side to side, as the clippers are used this part will gradually wear in width thus not moving the cutter far enough to complete a cut this will produce snagging in smaller blades and tram lines in larger blades like 7, 5, 4 and 3's. All Clipper Parts are available for these clipper repairs.
May 29, 2010 | Andis 01690 Hair Trimmer
Blades fell off oster dog clippers but can't fit them back on. Please help !!
Assuming that you did not damage anything, the blades should go back on easily.
Slide the blade onto the hinged flat 'post'. Turn the clipper on. Fold closed the blade assembly into position against the clipper body.
If this does not ork, you must have damaged something.
Mar 27, 2010 | Oster Golden A5 2-Speed Universal Motor...
I have andis AGC 2 dog clippers. I have having trouble taking off/removing the blade that came with the clippers. The under portion of the blade assembly seems to be stuck. Also, since I'm having so...
Mar 18, 2010 | Andis AGC2 Hair Trimmer
Can't put on a new blade
start the clippers then slide the blade onto the tongue of the hinge assembly , now push the blade into the clipper don't be afraid sometimes they can be tight from new,
Just make sure the two screws either side of the hinge are tight.
Aug 23, 2009 | Oster Golden A5 2-Speed Universal Motor...
Aug 13, 2009 | Andis Health & Beauty
My andis agc2 clippers will not cut hair now.They are also a little noisy.The blades have been sharpened and are oiled.
Providing the clipper blades have been correctly sharpened try replacing the blade drive assembly which wears in width and can cause numerous problems.
Jul 04, 2009 | Andis 01690 Hair Trimmer
Andis ag2 clippers sound loud
Apr 20, 2008 | Health & Beauty
Health & Beauty Logo
Top The Health & Beauty Experts
Robert
Gene
D. E. Hev
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
