Question about BaByliss Health & Beauty
I cant assemble the blades on my babyliss clippers
geokohler
  • 304 Answers
SOURCE: barber clipper blades
Soak them in motor oil the use 400 grit wet sandpaper (The black kind available at the hardware store) and lightly sand off the rust. They will be good as new when you are done.
George
Posted on Jul 25, 2008
SOURCE: Andis Ultra Edge Pet Clipper Assembly Help
I took my andis ceramic edge blade apart to clean. Now my clipper will no longer cut my dog's hair
Posted on Aug 23, 2009
SOURCE: andis ag2 clippers sound loud
Check the tension of the hinge assembly which you slot your blades onto the hinge should be stiff (not moving by finger) also check the latch is connecting when the blades are fitted (check the blades wont pull off without depressing the latch. Its possible the blade drive may require replacing again they do not last long if your a busy groomer.
Posted on Nov 19, 2009
SOURCE: I have andis AGC 2 dog clippers. I have having
Ok you need to locate the Latch which holds the blades into place. There should be a black piece of metal at the rear end of the clipper blade whilst on the clippers, simply push this in towards the blade and at the same time pull the front edge of the blade away from the clipper to release this should simply pull off in a forward direction.
Fitting is easier slide a blade onto the tongue of the Hinge Assembly and pull it into the body of the clipper.
Posted on Mar 18, 2010
Testimonial: "Thanks so much for your help. The hinge assembly is what tripped me up. Once you explained that is was really quite easy. Thank you!"
  • 10 Answers
SOURCE: oster clippers blade
John! No Problem!
First put the bigger of the two blades witht the size/number facing down, put the cutter on top. (with the side with the flat side of the teeth facing down) Then put the tongue guide inside the tension spring, make sure the tension spring rail is on the tension rail and place them on top of the cutter. To see which bits these are go to: http://www.sheareaseltd.com/clipper-blade-sharpening/clipper-blades-the-parts
This picture whows the front and back, it differs slightly from your blade, but its same meat different gravy!
Hold all this together with your finger and thumb, flip it over and scre the whole lot together!
Posted on Aug 03, 2010
I need a charger for a babylissprecision definer ntrimmer FX77OU
Buy a "for parts or not working" model on eBay that comes with a working charger.
Jun 16, 2014 | Forfex BABYLISS Pro Clipper/Trimmer Combo...
I think my clippers need oiling but there does not seem to be an oiling point
You just need to put a few drops of light oil on the cuttung blades.
Apr 08, 2011 | BaByliss 733A Hair Trimmer
I have andis AGC 2 dog clippers. I have having trouble taking off/removing the blade that came with the clippers. The under portion of the blade assembly seems to be stuck. Also, since I'm having so...
Mar 18, 2010 | Andis AGC2 Hair Trimmer
Forfex blade reinstall
I have the Forfex babyliss 720 and I can't get new blades installed in it. I have tried 8 times and someone else has tried 5times. Do you have any instructions on this model.
Thanks
lchardt@embarqmail.com
Dec 16, 2009 | Forfex BABYLISS Pro Clipper/Trimmer Combo...
How do you remove the blade to get the hair out?
there's 2 screws on the blade, unscrew and clean replace blade
Oct 24, 2009 | Forfex BABYLISS Pro Clipper/Trimmer Combo...
My forfex clippers won't hold a charge
How old are the clippers? Babyliss have a one year warranty on all their electrical goods. It sounds as though you may need a new battery. Have you checked the charger itself to make sure it is working properly?
Jun 10, 2009 | Forfex BABYLISS Pro Clipper/Trimmer Combo...
Wahl designer clipper
Have you been oiling the blades? If you ran out of oil you can use any light machine oil available at any hardware store. If you feel comfortable opening the unit you will be able to see the electromagnet inside and watch what is going on. If all else fails Buy a new set (the exact kind) and keep the receipt. Swap them out and return it from the store where you purchased it. You paid good money for them and they should not have died so quickly. The store will get full credit for it when they return it to the manufacturer so it is not that morally bad. The manufacturer should bare the burden because of the poor quality control that allowed your clipper to die in such a short period of time. Hope you find this solution helpful and the last option is a surefire fix...
George
Jul 21, 2008 | Wahl Designer 6 (8355100)
Andis ag2 clippers sound loud
Apr 20, 2008 | Health & Beauty
Health & Beauty Logo
Top BaByliss Health & Beauty Experts
NOEL
NOEL
ray gallant
Tom Chichester
Are you a BaByliss Health and Beauty Expert? Answer questions, earn points and help others
