Question about Garden
How to remove bushing from Roper rototiller
Replace main drive bushing on driven side of 8hp belt driven Roper rototiller
SOURCE: Roper Dryer
i have the same dryer it runs but doesnt heat and the timer wont move. its only 3 yrs old
Posted on Jul 10, 2008
MNTECH
  • 1543 Answers
SOURCE: replace bearing and bushing g.e. profile dryer
Yes, but you will have to swing the top open, remove the dryer front, and pull the drum forward about 4 inches (leaving belt on drum) to gain access to the bushing. Normally that is all you have to replace, but also check for wear on the front drum slides at the same time.
Posted on Jan 21, 2009
pippall
  • 1486 Answers
SOURCE: roper rally rototiller wont till
Check belts
Posted on Jul 06, 2009
  • 61 Answers
SOURCE: Roper 16 hp Lawn Tractor: belt replacement
you need to remove the mower deck there you will see the pullys.
Posted on Sep 06, 2009
  • 277 Answers
SOURCE: need belt and bushing seals for (tiller)
try looking for tiller model 410 or 420
#215-410-019
the 135202 number is the b&s motor number
Posted on Feb 20, 2011
Hp designjet 500plus ,first time i change carriage belt ,but now it shown allignment error..
Two thing you need to check:
1. Are you replaced genuine carriage belt?.. Original belt having two type of inner tracks.. Right side horizontal & left side vertical tracks. Are you fixed it properly or not..
2. Check carriage assembly play.If it is over play(carriage bushes may be warn out) alignment won't complete, If bushes are available in your country replace them & do the calibration..If not go down how to alter bush. see the snap shot
3. While carriage movement pl check trailing cable flexibility.
Carriage Bush:
Note:This modification only professional not for users:
Un screw screws both sides as shown in fig, take out bushes estimate how much warn out happened.
Thing needed:
Fevi quik(glue),small peace of miler sheet,scissor & tweezers.
Cut miler sheet in to small peace & insert warn out place of bush(between bush & rail) & apply glue, fix it permanently,do it both sides & check for the carriage play.. once its finished try for alignment.. For this activity no need to remove carriage assembly from the rail. Main aim is alter bush warn out..
May 30, 2012 | HP DESIGNJET 500 InkJet Plotter Printer
My machine is not spinning what may be the problem
depends on what brand and type of unit... is this a front loader a top loader and what brand.. is it direct drive or belt driven.... if it is belt driven could be a bad belt or pulley...if it is direct drive such as a top load whirlpool ,kenmore,roper, you could have a bad drive coupling which is located between the motor and transmission under unit.... if this is a front loader there are numerous items it could be example a motor controller board, main pcb board.
if everything is working but the spin mode and this is a top loader unit may want to check the lid swich that will cause the unit to not spin.... hope this helps kinda a vague description of your probelm....good luck and give me a vote i need them....
Jan 03, 2011 | Washing Machines
Changing a belt on a washing machine
There is no belt on this machine.
It uses a direct drive coupling between the motor and transmission.
Ope the control console,then remove the cabinet clips to remove the cabinet for access to the motor.
Remove the motor then remove the broken drive coupling(3 parts).
Replace the part and re-assemble the washer.
Jul 25, 2010 | Roper RTW4100SQ Top Load Washer
Jul 31, 2009 | Garden
We require help with a broken belt on the rototiller
bring the broken belt to napa auto parts or kragen ,,or go to www.managemyhome.com they can tell you where to buy or get it
May 20, 2009 | Garden
Sears rear tine rototiller 32-29978 manual
If you find one please let me know as I have the same tiller and no manual.
May 02, 2009 | Craftsman Garden
Roper top load washing machine problem. Please see details...
probibly a coupled drive. motor coupling runs everything, pump,aggitator, spin. if none of these thrree, coupling is two plastic parts with rubber between directly on the shaft of the motor , see if there are two screws at the bottom of front of case., if so remove aathen look for clips at top rrear this should be an easy fix
Mar 27, 2009 | Roper RTW4100SQ Top Load Washer
How to replace dryer belt
Remove the filter from the top>
Remove the 2 phillips screws from the top (filter housing)
Use a putty knife to pop the top by compressing the clips
on either side of the top between the front and top.
NOTE: Once the top is up remove the screws inside
to get the front off and LIFT the front up
before pulling towards you so the bottom clips
won't break.Get the lid switch disconnected and set the front aside.
Oil the rollers and idler, vacuum out the lint.
The new belt goes rib side down on the tub. The idler mounts like the one pictured
on bottom right of these dryer belt routing pics:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 16, 2008 | Roper REX4634KQ Electric Dryer
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
