When plugged into gen everything works but not charging battery
  • Mike curry
    Mike curry May 08, 2017
    I have unit out now and fuses are fine
2 Suggested Answers
naruto64
  • 9 Answers
SOURCE: Nano 3rd Gen 4gb Battery issue
try pluging it into your coumputer.
Posted on Apr 28, 2008
HAVE 110 WHEN PLUGGED IN OR ON GEN BUT HAVE LOST 12V WHEN UNPLUGGED OR GEN OFF.
Do you have 12v when plugged in or on generator? If you do, then it's likely 1) a fuse or breaker for the converter, or 2) the converter is dead. Is your battery good? Try using taking the battery out and using to crank your car or truck. If that works, look at the fuse or breaker for your converter or your converter may be dead. If the batter doesn't work, do the opposite and put your car/truck battery in your RV and see if your 12v works -- if it doesn't, then check your converter fuse/breaker or it may be dead; if it does, then your battery is terminally (pun) dead.
Nov 09, 2015 | Heartland 2013 Cyclone CY 3010
I have a 1985 RV Ford Econoline w/ a 460 eng.,but my problem is electrical,possibly the solenoid,which we replaced.I deduce that the solenoid could be bad,or the wrong one,because the Onan generator will...
check and make sure all batterys are good make sure alt. out put is 12.9 to 14 volts make sure charging cable from front to generator battery is working if it has a seperate charging system for generator battery or batterys,check and make sure charger is working properly if not replace charger or run no. 8 wire from front charging system to gen. battery make sure main engine is running while you start gen. after gen starts turn engine off
Aug 16, 2013 | 1988 Ford Econoline
I have a iPod shuffle 2nd gen. But haven't used for a long time. Now its not switching on. What to do?? :(
Batteries--especially rechargeable ones--do not hold their charge forever. The batteries power naturally drains, even if you don't use them. Just recharge your ipod, and it should work fine.
Dec 16, 2012 | Apple iPod Shuffle Second Gen.1 GB MP3...
I recently bought a used 2004 Fleetwood Discovery 39L with a Xantrex Freedom 458 system in it. The system worked (sort of) for the first few months I owned it, but now fails to charge the house batteries....
It sounds as if your inverter has failed altogether. This failure could also be caused by power management having issues.
So far, I know that you have a 2004 Fleetwood Discovery 39L. If memory serves, this is a *30AMP* chassis, with 2 air conditioners, using an intellitec power management panel located above the driver position. If I am incorrect, please advise.
Aug 18, 2010 | Xantrex Technology Xantrex Freedom Xmic...
Dell jukebox not working, want to transfer music
Mine has also ceased to charge. For awhile it would charge if I manipulated the charging plug in the socket but now doesn't respond to anything. It does make a nice paper weight now. I suspect mine has a bad connection in the charging circuit somewhere, perhaps just the socket has gone bad. Who knows? --- GB
Aug 22, 2009 | Dell DJ MP3 Player
Problems with the inside lights get dimm
Ether your battery is weak /and or your alternator/generator is not charging the battery
when you rev up your engine do the lights brighten ? if so alt/gen is working
another wa to find out if your alt/gen is working it to disconnected the positive RED
battery cable when the car is running, if it dies then you need a new alt/gen
Hope that was helpful.
Jul 01, 2009 | Hyundai Santa Fe Cars & Trucks
Ipod shuffle (2nd gen) completely dead
you are still under warranty...take it to the sony apple store...they will fix it /replace it or tell you there is cost if it not the battery (note do not tell them you charged overnight, and for the future do chage any gadgets more than 3-4 hrs) when you do charge over night you are actually shorten the battery life span or overcharge....so as soon as you come home from school,work,whatever cell/ipod or any other device needs to be charge...charge it now and unplug before you go to bed....
Jun 26, 2009 | Apple iPod shuffle Second Gen. Silver (1...
Settings/content pane in itunes for adding songs does not show up
had the same problem. Just reinstalled Itunes. As of July 30th 7.7.1.11 Version. Fixed the problem right up.. I was able to register and get my songs to show up.. Good luck and happy listening...
Jul 21, 2008 | Apple iPod shuffle Second Gen. Silver (1...
29 people viewed this question
 Grubhead
Grubhead
