Question about Refrigerators
Igloo ice maker won't freeze. What is wrong. The ice forms then it melts quickly. Do I need to replace it
Rotu
  • 175 Answers
SOURCE: Sub-Zero 685 Ice Maker Problems
There are 2 important things to be aware of with these icemakers. One is that they need to be completly level, both side to side and front to back. Second, the fill on these icemakers should be right about 100 milliliters. Get a measuring cup with Ml markings and pull out the icemaker. Fast forward the icemaker by jumpering the little test terminals behind the square cover. You need to connect the terminals labeled T for thermostat and H for heater together with a piece of wire. Be careful, as there is 110 volts to these terminals. Keep the wire there for about fifteen seconds,then pul it out or the icemaker will get really hot. Just as a note, for all this to work the icemaker must be plugged in, turned on , and you must hold down the switch that is pushed by the bucket. If there are no test terminals on the icemaker, then you can just fast forward it by pushing the fingers around in a clockwise direction looking at it from the square end. Anyways, once you get it moving, put your measuring cup under the fill tube and wait for the fill cycle. the water should be very close to 100 ml (range is 90-120ml). If your fill is correct, and the icemaker is PERFECTLY level, then make sure the fill tube is inserted all the way into the icemaker. Hope you can wade through all this for an answer. Good Luck!
Posted on Jun 27, 2007
allabouttile
  • 11 Answers
SOURCE: I need Oster ice cream maker instructions
http://kitchen.manualsonline.com check out this website for your instructions.
Homemade Vanilla Ice Cream
3 cans fat free evaporated milk
1 quart fat free half and half
1 quart whipping cream
1 cup Splenda
vanilla to taste
Mix all together. Follow directions for electric ice cream maker. Makes 1 gallon. To make chocolate ice cream, add sugar free chocolate syrup in recipe.
Posted on Jul 31, 2009
SOURCE: GE Monogram refrigerator/freezer problem/ice dam in ice maker
I have had the same problem with ice forming. I found the problem is from the ice maker. The water fill tube delivers water to a plastic piece that acts like a funnel. The water goes through this plastic piece into the ice maker. Ice forms in the plastic funnel piece causing the water to overflow into the ice bin and freezer.
Posted on Oct 22, 2009
SOURCE: the ice melts from the ice maker forming icicles
Just had this same issue repaired yesterday, the defrost element was out allowing the freezer to freeze up stopping the fan which moves the air and in turn causing the upper part of the frezzer to become warm and melt the ice. This is a common problem for the GE profile and I recommend finding a service company cheaper than GE and quit letting GE make more money off their CRAPPY appliances.
Posted on Oct 28, 2009
nine11c4s
SOURCE: Melting ice
The bin has most likely failed. Apparently the bin insulation on the DCE33 eventually gets saturated with water and loses it's insulation ability. Consequently the ice melts prematurely. Condensation starts to build up inside the bin because it's not cold enough adding to the problem as the water drips on the new ice inside the bin.
Mine is 5-yrs old and I was told that it's all the life I'll get out of it.
If everything else is workng properly, harvest time, cube size, cold water spray, then a new bin is the unfortunate solution.
Posted on May 11, 2012
I got an Igloo ice maker for Christmas, now it won’t make ice. It cycles but doesn’t freeze. I have tried the reset and unplugging. Nothing works.
I SUGGEST YOU CONTACT THE MAKER, AS ANY TIME YOU MESS WITH IT, THE WARRANY IS VOID.
IT IS TOO NEW TO DO YOUR OWN REPAIRS.
HAVE THEM GIVE YOU A SHIPPING LABLE TO SEND IT BACK TO THE MANUFACTURER FOR A REPLACEMENT.
Jan 14, 2018 | Refrigerators
My ice maker cycles and stops with ice full light on with no ice made
If ice is in the tray it could be that the heating element designed to slightly melt the ice so it can be pushed out, is open and needs replacement. But you might find that the cost of element is more than a new icemaker. Be careful
Go to attached site for details. parts, prices, etc. Search Over 2 1 Million Appliance Parts
Aug 25, 2017 | Freezers
Won't pump water to tray.
How a Portable Ice Maker Works - NewAir
www.newair.com/articles/how-a-portable-ice-maker-works/
Look inside to find out how a portable ice maker works, and get some tips about ...Just fill a tray with water, stick it in the freezer, wait 30 minutes or so and, bam, ice! ...Power supply - if the unit won't turn on, make sure if it is plugged into an ... Leakingwater - If the pump is operating but no water is reaching the freeze tray, ...
Customer Reviews: Igloo Portable Countertop Ice Maker ...
https://www.walmart.com/reviews/product/15162429
WalmartIgloo Portable Countertop Ice Maker ... My wife is lazy and never refills the ice traysto put back in the freezer. ... Great ice maker for camping trips and parties. ... even though the thing is completely empty so it won't make anymore ice, and 1/3 of .... My satisfaction was quickly marred by the sheer volume of the water pump in ...
Igloo Portable Countertop Ice Maker - Walmart.com
www.walmart.com/.../Igloo-Portable-Countertop-Ice-Maker/151...
Walmart
Rating: 4 - ‎350 votes - ‎In stock
Buy Igloo Portable Countertop Ice Maker at Walmart.com. ... It features a 3.1L capacity water reservoir that can make up to 26lbs of ice in 24 hours. You need not drain the melted ice ..... A. yes, the ice tray that hold the finished made ice is right about the water reservoir. .... A. Jogie: No, it won't make crushed ice, only cubes.
EdgeStar Portable Ice Maker - Troubleshooting Help ...
blog.edgestar.com/.../edgestar-portable-ice-maker-troubleshooting-help/
Jan 31, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
How do I clean my igloo ice maker
Igloo Ice Maker ICE102-WHITE - Kitchen Appliances Manuals
kitchen.manualsonline.com > ... > Igloo Ice Maker
Igloo ICE102-WHITE Ice Maker User Manual. Page 1. Page 2. Page 3. Page 4. Page 5. Page 6. Page 7. Page 8. Page 9. Page 10. Page 11. Page 12. Page 13.
Igloo Portable Ice Maker Review - YouTube
? 4:02
https://www.youtube.com/watch?v=893Cs66veK0
Jan 3, 2014 - Uploaded by TheVirginiaStew
The Igloo Portable Ice Maker, Model is the ICE 102C Silver and it is great. It can go ... Main thing is to use good ...
Jan 19, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
Scotsman icemaker dce33 is making ice, but it is melting
Yes it could and also check dump valve it should not let water through during freeze cycle.
Oct 03, 2012 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Refrigerators Logo
44 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
