Question about Pride Health & Beauty
Where are the serial numbers located on a pride victory 9, looked at seat bottom, frame, battery box, onder carrage part of frame
  • 175 Answers
SOURCE: I have a pride victory xl8. Problem - was running
All scooters have a protection system built in to prevent burning up the motor, and the user, should the scooter overheat. It sounds like yours overheated. If the temp. outside was warm to hot, and your weight is near the weight limit for the scooter, and you are taxing the motors over a hill, or unstable terrain, then the scooter goes into "limp home mode", or just enough to get you a bit aways, and then it will turn off. After a few minutes to cool off, it will go again, but shut down fairly quickly because it takes a spell to let the whole transaxle-motor assembly to get cool.
Check your weight, and anything else you may be carrying with you on the scooter. Check the terrain, and incline you are going against. Throttle down for all these occassions. If you overloaded the system at some point, then you may have overheated the brushes. Remove them (2) with a standard screwdriver and see if the copper coil is still flexible and springy. If not, replace it/them.
The damage may already be done, so it may need a new motor/transaxle assembly. An expensive proposition I'm afraid.
Posted on Jul 09, 2009
SpideRaY
  • 687 Answers
SOURCE: WHERE IS THE SERIAL NUMBER LOCATED ON mp190?
Download THIS its called USBDeview and it has the ability to find out about just about anything you want to know about USB devices.
This screen dump shows that the serial mumber for this Canon iP4200 is B28EE4148245b.jpg
Posted on Sep 28, 2009
  • 355 Answers
SOURCE: i'm looking for adobe 8 serial number i lost the one i had
try to find your serials from these site
1) www.fullversionfinder.com/download-Adobe-READER-keygen-crack-serial-keygen-rapidshare.html
2) www.ddlsite.com/adobe-reader-lite-9.0-crack-serial-keygen-rapidshare-download.html - Cached - Similar
Posted on Oct 02, 2009
  • 177 Answers
SOURCE: Pride Celebrity Deluxe Mobility Scooter - Serial Number
Hi. The serial number will be on a sticker on the upright support that holds up the seat. You will have to lift of the seat, and take the cover off the batteries to see it. It should be on the front of the deat support. Neil.
Posted on May 27, 2010
  • 102 Answers
SOURCE: serial number location on the laptop
Look under the battery or if that does not work you can right click on the computer icon and going through system properties some computers have the serial number and windows key listed.
Posted on Jul 20, 2010
Where is the serial number on my Victory Pride 10 scooter?
Call this number, they will tell you where the serial number is located
1-800-800-8586
Jun 02, 2017 | Pride Health & Beauty
Wiring diagram for a victory pride 9
Hi I found this type in .google search....,victory 9 wiring diagram ..good luck
May 25, 2016 | Pride Mobility Products Victory 9 Scooter...
Scooter is saying error code 8 which is motor does anyone know what this could be please?
Pride Mobility Products Victory 9 Scooter 4 Wheel Error code
www.fixya.com > ... > Pride Mobility Products Victory 9 Scooter 4 Wheel
Pride Mobility Products Victory 9 Scooter 4 Wheel, error code related issues. ... Question about Thermometer Mobility Scooters ... error code is 8 Error code 8 means an internal controller error or problem and requires replacement of the controller. ... Theysay there is no listing for code 9 I have replaced the batteries,checked .
Basic Troubleshooting Instructions - Pride Mobility Productswww.pridemobility.com > Resource CenterPride MobilityScooters. INFINFB2040 Sonic Troubleshooting ... Chargers. INFINFB2586 Charger Indicator Codes ... Disclosure Statement Pursuant to Cal. Civ. Code 1714.43(a)[PDF]Legend Owner's Manual - Pride Mobility Products
Nov 28, 2015 | Pride Health & Beauty
What year is my pride victory scooter
hi , i suggest you call Pride and give them the serial number ...
What's your location and i get you a phone number...
Regards
Rob.
www.facebook.com/gewizrepairs
Apr 01, 2014 | Pride Victory 4 Wheel Mid-Size Electric...
What year is my scooter
Neil is right, the serial number is on the seat support. From that the year can be determined. It's mostly moot, as Pride only has a 1 year warranty, and after that, it Parts and Labor. Why are you asking?
I have a PRIDE scooter. It is a Victory model but I don't have any serial number or exact model #. It turns on, goes a little and then "bucks" ir stops completely. When I take out the key and...
1)Make sure the battery's fully charged..
2)Your brake lock and unlock leaver under your seat..be sure its totally engaged in the locked position in other words ''all the way pushed down''.
3)Take the shroud off the back, this can be done by removing the seat, hold the seat leaver up towards you ,Now you should be able to rotate the seat when you have lifted that leaver when it does rotate lift up the seat it will come off.now that the seat,the shroud are off. you will be able to see the battery's make sure the connections are good and tight...
4)Tilt the scooter over on its side there is a grayish white cable this is your front-to-rear cable follow it from the front to the back ,make sure there is no cut or broken spots'which would be a spot on the cable that looks as if its been scraped against the ground .If there is a brake in that cable it will need replacement.
* Put the shroud and the seat back on the scooter if everything checks out ,Get on the scooter turn the key make sure that needle goes all the way to fully charged mark go slow tap the top of the console if it stops faster than it did before or doesn't at all your looking at a new key switch.
hope i was helpful good luck.
Jan 16, 2011 | Pride Mobility Victory 3 Wheel Electric...
Trying to replace a faulty part with a newer version of that part. its the electrical box that sends the power from the batteries to the controls. the old part has 8 connectors and new one only has 6. DOES...
For the Victory XL 4 there is a Penny and Giles Egis 70 Amp controller. Looking from the back of the scooter the 4 vertical plugs on the left going from bottom to top are for the following:
bottom plug to charger
plug for lighting package with 7 connectors
plug to battery connector
top plug to motor
My count is 4 connectors unless we are talking about individual connections.
Are you talking about the accessory lighting plug and harness with several connectors to lights, turn signals, etc.
If you clarify your model and description I can send you the illustrated parts breakdown as a pdf.
There is a chance you have the wrong part if you did not order from the manufacturer by model and serial number. What is your part source?
Oct 26, 2010 | Pride Victory 4 Wheel Mid-Size Electric...
I HAVE BOUGHT A SECOND HAND ROMA SCOOTER. MODEL: STRIDER MIDI 4 YEAR: 2008.SPEED: 4/8MPH.I CANT FIND THE SERIAL NUMBER TO GET IT INSURED. I HAVE LOOKED AT THE BACK, BUT AS IAM LIMITED IN MOVEMENT I CANT...
Hi. MostPride scooters have the serial number on the front of the seat support colomn. You will have to remove the seat and the cover over the batteries to see it. Good luck. Neil.
May 15, 2010 | Pride Victory 4 Wheel Mid-Size Electric...
Health & Beauty Logo
85 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
