Why is water coming from casing - Washing Machines
Its leaking water
Take it out of case
Connect to hose. Turn on tap & see were the leek is.
Jun 14, 2015 | Karcher 16016080 K2 26 1600 PSI Electric...
How high should water come up before contents pumps out
Depending in the pump model, but most of them, the pump casing usually fills up with water about half way of the casing before it creates enough water pressure to pump the waste out. Once the water is pumped out, the pressure releases off the pump and the unit shuts off.
Oct 09, 2012 | Saniflo & Saniplus& Macerator Pump
Dear Sir,
In this case the seals surrounding the pistons (3 in number)..are faulty.
You can open the cover first ( by using a TORX T15 screw driver). Start machine in this way with all attached...( never run a power washer with out water and never store a power washer with pressure in it). When you start machine with out cover you can more easely see from where water is coming out. Mostly the case will be that water is coming out from between the head and the bottom part of machine. If water went into the bottom part...then the oil is ruined also.
So this case needs that all seals to be changed. One must inspect the pistons....because if the pistons are scrathed and pitted...then it is useless to put new seals. Thus new pistons must be put with new seals...and other gaskets renewed.
Feb 07, 2011 | Karcher K2.26 Electric Power Washer
My lms 332c comes on by itself and i
Power switch is stuck on. It is a tricky repair, but disable the swtich internally and install one externally
May 17, 2010 | Lowrance LMS-332C GPS Receiver
We have a water leak and have 2 diagnosis, one said the water pump is bad and the other said it's not bad, water is coming from behind the timing case. do you have any idea?
It's most likely the water pump, the water and the timing case are in the same area. It's possible the gaskets are bad between the timing case and the block. In either case the water pump will have to be removed.
Feb 09, 2010 | 1999 Buick Century
My ice maker is pooring out water. How do you stop the water from pooring out?
unplug frig,if water still come's in than you have a bad inlet valve and nead to turn water off.if water doe's not come in than you nead to unplug ice maker and plug frig back in.if no water come's in than you have a bad ice most case's you are better off buying a new ice maker.
Nov 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker stopped making ice. Water is still coming through to water dispenser
Two possibilities come to mind. The water line to the icemaker could be blocked; however, these lines are fairly large and are not easily clogged.
Assuming that's not the case, the other likely reason is that no water is being moved to the icemaker from the valve at the bottom of the refrigerator. The problem here could lie with the icemaker control unit malfunctioning and not sending the signal to the water valve when water is needed. Or the signal for water is being sent, but the water valve is defective, and no water is sent.
If it were me, I would probably change out the water valve at the bottom of the refrigerator. This is located where the house water enters the refrigerator case.
Oct 12, 2009 | KitchenAid Superba Architect KSCS25INSS...
Leaks water when washing from the door
It's because of a hole in the door seal body. The water runs down inside the machine and comes under the front of the washing machine
For this first unplugged and then take the top off the washer and there is usually a nut and bolt to undo which is holding a clamp band round the door seal fixing it to the tub.
many cases where the water runs down from the bottom of the door but has in fact come from the soap dispenser but the leak was coming from the door.A thin line of water trickles from the soap dispenser and runs round the door frame to appear as a door seal leak. Make sure this isn't the case.
Jul 04, 2009 | Whirlpool Washing Machines
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
