Tv/fm 4 way amplifier - Source in ottawa - Audio Players & Recorders
What is the video single output VHF FM UHF 12db
That sounds like the description of a broadband amplifier. It likely has "F" type (cable-coax) connectors and a power cord.
Commonly used to increase the signal level of TV cable to compensate for inserting a signal splitter, or in some cases to increase the signal level from an antenna, typically outdoor TV or FM radio antenna, so it is connected between the signal source (antenna, or cable) and receiver with antenna as input and receiver connected to the output of this little box. The gain (amplification) it provides is 12 dB, so the output is more than 3 times the input.
Oct 03, 2014 | Radio Communications
I moved and cant figure out how to hook my 4030 channel master antenna up again. I have a converter box and hd toshiba tv
INSTALLATION
Channel Master by PCT indoor antennas are designed to provide optimum reception of
UHF / VHF and FM signals. These antennas have 75 ohm outputs, which allow simple,
hassle-free connections to today's newer TV sets that have 75 ohm F type connector
inputs.
Simply attach one end of the supplied 6' cable with F connectors to the output of the
antenna (Fig.1). Attach the other end of the cable to the input of the TV set or VCR
(Fig. 2). Some adjustment of the antenna might be necessary for optimum viewing.
Model CM-4030 includes a built-in amplifier and separate power supply.
1. Follow the same steps as above for antenna to TV / VCR hookup. Note : Model
CM-4030 also allows for two set / VCR hookups with its unique dual output feature.
2. Insert the power injector into the back of the antenna (Fig. 3). Plug in the power
transformer to the closest electrical outlet (Fig. 4).
Google 4030 Channel Master Instruction Sheet for the PDF File with the diagram.
Fig 2a
Fig 3 Fig 4
prohibido por ley.
TV
Fig 1 VCR
Fig 2
Fig 2a
Fig 3 Fig 4
Jan 10, 2014 | Channel Master 4030 Amplified indoor HDTV...
Super digital tv tuner driver for FM 7130 made 2005
http://www.google.co.in/#sclient=psy-ab&hl=en&source=hp&q=tv+tuner+driver+for+FM+7130+&btnK=Google+Search&psj=1&oq=&aq=&aqi=&aql=&gs_sm=&gs_upl=&bav=on.2,or.r_gc.r_pw.,cf.osb&fp=1&biw=1152&bih=669
Oct 04, 2011 | Philips SAA7130 TV Tuner/FM Radio/Video...
FM antenna is not providing reception, despite cable connected to powered antenna amplifier. TV also connected to powered antenna amplifier (splitter) works fine. FM mode produces only static. I purchased...
If I understand your setup, you've connected the receiver antenna terminal to the output of the antenna amplifier. If this is true, I'd suggest trying the receiver using a plain old FM dipole antenna (available at Radio Shack and other stores) or even just a piece of wire hooked to the antenna terminal. You should be able to pick up some local FM stations then.
What might be happening is that the FM is being filtered out by the amplifier. Some amps made mainly as a TV signal booster have an FM trap designed to block the FM broadcast band. In the analog broadcast days, the FM band was right near the sound part of a TV signal, and the trap was there to prevent interference. It may be filtering out your FM band.It may also be possible that you're just overloading the FM antenna input with the amplified signal. Sometimes a signal can be too strong. Using a simple wire antenna will let you test the receiver by itself.
Other than connecting an antenna you shouldn't have to do any setup for FM reception. If you still get no stations at all when using a simple antenna, then the receiver may need service. But I doubt Circuit City would have sold a floor model that was defective, even at the very end, unless it was clearly marked as such and sold "as-is". I'm pretty sure you'll find that the receiver works with an antenna made for FM.
Sep 14, 2011 | Denon DRA-37
It says "Source Direct" and
I think that your receiver might be set to the wrong input. Try to change the input to "tuner" and you should be able to hear the FM radio. To change the input, all you need to do is press the button labled either source or input
Jan 07, 2011 | Kenwood Audio Players & Recorders
JUMPING VERTICAL WHITE LINES
UNPLUGGED TV FOR OVER NIGHT(WAS TOLD 4 HRS) STILL HAD PROBLEM. TOOK ALL CABLES OUT CABLE BOX,DVD,2 VCRS,AMP,SATELLITE, AND FM AMPLIFIER. OPENED BACK VACUUMED ALL BOARDS WITH SOFT BRUSH ,CLEANED LENSES ,MIRROW,FIRST TIME IN 10 YRS. TV LOOKS VERY SHARP!!!!!!!!!!!!!!!!! I THINK IT MAY HAVE BEEN THE FM BOSTER AMP TRANSFORMER GOING BAD CREATING INTERFEARANCE. JUST A GUSS.. COULD NOT HAVE BEEN THE DIRTY LENSES I DONT THINK THAT WOULD HAVE CAUSED INCONSIST CONSENT JUMPING LINES.ENERY THING RECONECTED (NO FM BOSTER AMP) TV LOOKS GREAT. THANKS FOR YOU GUYS GIVING ME THE CONVDENCE TO GET IN THAT PROGECT. KEEPING FINGERS CROSED.......THANKS TV IS A SONY KP-61XBR300 NOT A KP-57WS500 57 IN.
Nov 30, 2008 | Sony KP-57WS500 57" Rear Projection...
Sound
Set your SAT receiver to full volume and use your Sony TV volume control as the master volume control. If you use an external surround sound amplifier do the same thing using the amplifiers volume control as the master volume control.
Consider that all source devices that have the ability to control their output volume will output what they call line level 0dB when the source device is set for maximum volume. If you set the source device to 1/4 volume your output to the amplifier may be around -25dB or lower. Introduce that low of an audio level to the amp and you will have to turn the amp up to half way or better causing the amp to amplify noise too.
Jul 04, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Better fm reception
Is it just a single wire?
If so, purchase a cheap FM antena. It looks like a "T" when spread out (4' to 5'). That should help.
You can purchase an "amplified" antenna, but if your area reception is really bad (such as in a valley) the antenna would just amplify the noise as well. Look for web based radio in this case or if you have cable there are stations on it.
Jeff
Jan 11, 2008 | GPX HM3817DT Shelf System
 Grubhead
Grubhead
