Question about Garden
I have got a garden line 52721 hedge cutter I am looking for a diagram to replace the blades
boscia
  • 163 Answers
SOURCE: Electric Hedge trimmer will not cut
more than likely it damaged the inner gears or drive pins that make the blades reciprocate and need replaced. if you would like instructions to repair it yourself i will send you them or you can take it to a service center.
Posted on Nov 28, 2008
trippssmengi
  • 76 Answers
SOURCE: Long reach hedge trimmer
Try loosening the bolts up on the blades just enough to allow the washers to move freely a little, spray the blades down (but don't soak them ) with WD40 to lubricate the blades, that should solve it. If that doesn't do it then you may need to pull the gear housing cover off to see if something is jammed.
Posted on Jan 14, 2009
slohry
  • 87 Answers
SOURCE: thihl HL75 hedge trimmer engine will not run at full speed
Remove the cutting attachment, insert a screwdriver in to the shaft receptor and it should operate smooth with a slight bit of friction. if not then check the blade bolts and make sure the blades move freely. Lubricate the blades and the gearbox regularly. If the attachment end is good then turn the driveshaft by hand (with attachment still off shaft). If this too moves freely then go to the clutch.
Posted on Apr 10, 2009
SOURCE: Ryobi 18V Hedge Trimmer Blade Question
Just buy a file and push 3 or 4 down strokes down the same slope of the cutter toward the sharp edge. Never file on the flat top of the cutter, only on the slope. Support the frame using a saw horse or pick-up bed. The support makes the file cut the metal better. You can do the same thing with chain saws. You just need the file that fits the cutter. You just hold a consistant angle and count out the same number of strokes. Also, clean out junk between the moving parts, tighten any loose screws, and drop a few drops of 3 in 1 oil between the moving parts. Having things sharpened at a shop is inconvenient and expensive.
Posted on May 24, 2009
Shaping the Blake no a craftsman gas hedge trimmer
You have to keep triggering the cutters until the top teeth and bottom teeth are halfway in between each other. Clamp the blades in a vise and HAND SHARPEN WITH A FILE.
Feb 21, 2017 | Craftsman Garden
Stihl hs86 set blade gap
You shouldn't have to set a gap.. the gap between the blades is 'pre-determined' by a spacer between the blades that each 'blade bolt' passes through. You should be able to tighten up the blade bolts and the blades should still move. If they dont, then the spacers are worn and need to be replaced.
Apr 02, 2014 | Stihl Hedge Trimmer Pruner Cutter Blade...
Need pictures of stihl fs90 ave fuel lines setup,or parts diagrams so i can get or make new fuel lines,thanks anyone
You can look on the internet, some times these things are on there or you can call the company and see if they will send you other book for it.
Nov 01, 2011 | Oregon Scientific Complete Carburetor for...
Electric hedge trimmer only hums when I turn it on. It accidently went through a metal fence. The blade is slilghtly concaved. The hedge trimmer is a black and decker tr1700. I've taken the cover...
look carefully along the teeth of the cutter blades and see if one tooth has not jumped over the opposite tooth thereby locking the blades together
a bent up edge will do the same effect
you can remove the cutter bar and then the cutter bar cams then run the motor
if it still hums , junk it
Oct 07, 2017 | Electric Garden
Can i replace my cord for my hedge cutters
YES
You need the same quality cable and you need to dismantle the cutter to get to the mains connection.
If you are not up to all this then get a garden repair place to do it for you - SAFETY FIRST
Mar 10, 2011 | Garden
My hedge cutter smokes
Your hedge cutter is toast....motors run on smoke and when the smoke comes out they no longer run....:-)
Given that a hedge cutter is not all that much money to replace... trying to repair it will not be worth it...
Your best bet is to just get a new one...
heatman101
Oct 10, 2010 | Garden
Model HTC24 Flymo Hedgetrimmer
Are both the blades still moving? Are the blades sharp?
Aug 01, 2010 | Husqvarna Garden
Change cutting line
Pop of bottom cover and wrap new line by turning head or replace with different spool or blade cutter
Jul 01, 2009 | Craftsman 22" Gas Hedge Trimmer
Thihl HL75 hedge trimmer engine will not run at full speed
Apr 04, 2009 | Oregon Scientific Complete Carburetor for...
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
