Question about The Music
I have a custom 2x12 combo and at a low volume it will fade out or fluctuate I have to turn the volume up to get the sound back and when i do its so loud it will break windows is there a quick fix?
    Problem Solver:
  • 12 Answers
Pot probably needs cleaning with contact cleaner. If amp is more than 20 yrs old, could be time for new filter caps.
Posted on May 12, 2017
Fender hot rod deville 212 111. On the 2nd and 3rd distortion chanels the noise coming out of the speaker is very loud. Is this normal? Hard to play through the noise.
Hi. If the volume and drive levels are considerably low but you still hear a noise, you may want to consider trying a different guitar cable. The noise may be coming from a ground loop which is being amplified and overdriven by the amp itseld. I hope this helps. :-)
May 29, 2011 | Fender Musical Instruments Corporation...
My Laney VS30 212 at band practice last week decided to intermittently cut out, but not fully just the volume would drop out then return about 5 mins later. Not sure if this was a common problem. It might...
Sounds like output valve, if the amp is more than few hundred hours then suspect this for sure. I don't know much about this amp specifically but does the sound fade/return suddenly or over a few seconds? Try running it with the back off and fan on the valves etc. Then play at loudness where problem occurs and see if any improvement. Remember that at band practice you always play much louder than you think and put a lot of stress on it.
May 03, 2011 | Laney VC30-212 VC Series 30 Watt Class A...
When I press the on button the red light fades and shuts down completely. sometimes it can be turned on but it won't stay that way much longer and it starts flipping the drive channel and the more drive...
This is likely a failure of the power switch. It momentarily contacts, charges the power supply caps and then breaks the contact. This is not that uncommon as these switches are not well made and often not designed to handle the inrush surge current.
Mar 27, 2011 | Fender Frontman 212R 100W 2x12 Guitar...
My Fender 212R 100W 2x12 Guitar Combo Amplifier keeps on cutting out. The guy I took it to says there is something wrong with the cylinders? I also could have heard that wrong. I honestly don't know much...
You had best get a second opinion! When somebody says "there is something wrong" means they don't really know the details enough to give you an estimate even. If the amp cuts out sharply I would suspect that: 1. Bad volume control 2. Cracked circuit board 3. Bad solder joint on circuit board 4. Bad jack. These are in order from least to most likely.
Jan 25, 2011 | Fender Frontman 212R 100W 2x12 Guitar...
A new DM7 drum set line out has very low output. It is connected with drum combo Stagg EDA40 and if combo drum inputs are used there is practically nothing to hear . With combo maximum volume there is...
The sound on all the stock kits I found to be too low. What I did was create a custom kit and altered the dynamics of all the pads and cymbals - once you're in the dynamics settings, just hit the pads/cymbals the hardest you normally would and save that setting!
Dec 29, 2010 | Alesis DM7 USB Electronic Drum Kit
I have a Fender Frontman 212r amp. The problem seems to be when I put the volume upto past 4/10 [40%] The amp gives out an awful crackling sound and power light etc flickers on and off. I have had the map...
When i turn on my 212R it turns on in drive channel. if footswith is plugged in, then it turns on in the clean channel, but after switching in drive it is impossible to switch it back in clean channel. What could be wrong? Swith position doesnt change anything and it seems like switch is OK.
Nov 27, 2010 | Fender Frontman 212R 100W 2x12 Guitar...
Have amp only 2 months & clean channel is muddy. it was clean when i bought it. its somewhere in between clean & drive
Test if the sound is clean using the headphone jack.
IF IT IS CLEAN in the phones, you have probablydamaged the speakers with excessive volume causing the voice coils to rub the pole pieces due to heating. If you can reach the cone either front or back GENTLY push on the cone and listen for ANY rubbing noise.
There are also electronic component problems that can cause this IF the headphone test is also muddy sound.
Apr 12, 2010 | Fender Frontman 212R 100W 2x12 Guitar...
Music Logo
15 people viewed this question
Top The Music Experts
John mullen
Larry Stiles
Larry Stiles
D. E. Hev
Are you a The Music Expert? Answer questions, earn points and help others
