Question about Dishwashers
My kitchen sink stopped draining. Under the sink I found a provent would this be the reason the kitchen sink isn't draining. Already used a snake no clogs found.
Double wide trailer if that helps. No draining problems in the rest of the trailer. Just the kitchen sink not draining.
  • Hannah Schroeder
    Hannah Schroeder Oct 25, 2017
    It's really strange that your sink won't drain but you didn't find any clogs with the snake. I'm having a similar problem with the toilet in my master bathroom; it won't clear but a snake went all the way through and didn't find anything. there might still be blocked drains somewhere, so I'm going to call a plumber to take a look at it. http://www.samslocalplumbing.com.au/serv...
    Master:
  • 518 Answers
That's a check valve so to speak...Houses have vents to the top of house..Most trailers have those check valves..When water drains it allows air to come in so it will drain..If it malfunctions it could be the very reason it doesn't drain...What I would do is stop up the right side of sink then fill with water...Then plunge the other side...If something's further than your snake it will hopefully unstop it and make it go on down..Hope this helps
Posted on Oct 06, 2017
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 16 Answers
My friend is actually facing a similar problem. However, I'm not sure if she's tried to snake the sink like you have. Last time I checked, she was considered going to a service provider since she's not sure what could be causing the problem. I also don't see anything wrong with getting a professional opinion if you've done all you can. http://www.goldsealplumbing.com/drain-cleaning-services/
    New Friend:
  • 62 Answers
You need to pull the plumbing under the sink to see if the trap is clogged. Snake after the trap.
Posted on May 08, 2017
Testimonial: "Already did that. No clogs."
My kitchen sink refuses to drain at all.
You'll need a pro with a large cable snake and maybe a cutter head...
I hope it's not due to a garbage disposal. I try to warn people away from those things.
Mar 09, 2014 | Washing Machines
I went to lowes because of a slow drain in kitchen he gave me drain cleaner 100% lye now I have a worst problem it is clogged worst than before have taken all pipes apart under sink the clog is in the...
Rent a snake at equipment rental store just drill type should do it . Since you pull pee trap off already just feed it down pipe until it opens up.
Aug 18, 2013 | Plumbing
My kitchen sink is stopped up and i cannot unplug it! I have tried everything from draino to acid to snakes...still doesn't work!!!
I've had a similar problem and used a full bottle of main drain cleaner. It's only available at hardware stores and stores like Lowes and Home Depot. It should work unless you have tree roots growing into the main drain.
Mar 05, 2010 | Plumbing
Double sinks in the kitchen are not draining properly
You most likely have cast iron drains.They work fine for 20 or 30 years or so. Then they rust from the inside out, they scale up sometimes to the point that they close completly off .My point is that any grease or food matter that gets in the drain can stop it up. the quick fix is to run a drain snake throught it then after you get it to drain you might use some professional drain cleaner to further clean out the line. If I'm correct about your drains, you ll need to replace them in the near future.
Dec 28, 2009 | Plumbing
Won't drain water and backing up in sink
You have a clogged sink. Do you own a snake? (do not use any "liquid plumber" type cleaners in a kitchen sink as you wash and prepare foods in it).
Dec 19, 2009 | KitchenAid 23 in. KUDD01DPPA Stainless...
Water clogged in HDA3700 Water backs up into sink
check the p-trap under your kitchen sink, you may need to have it snaked-cleaned. other than that, where is it tie'd in. it may just be tie'd in too close or on the horisotil portion of your sink drain, when the vertical portion above the p-trap is recomended
Sep 18, 2009 | Dishwashers
My kicthen sink is pulg up;
A power cable (snake) You can rent them or try a cheap hand cable snake one first..
Mar 14, 2009 | Plumb Pak Waste & Overflow Pipe Kit, 1...
Washer drain back flow to sink
No you do not want to restrict the machines pump out feature, FIX the house drain! call Roto Rooter if necessary.
Jul 12, 2008 | Kenmore 46462 Front Load Washer
Water running out from under the washer
sounds like two seperate problems. firsst water running from under your machine might be a bad seal, or water could be backing up the drain line. i would guess that it is a plumbing problem because of theissue with water in the sink. have a plumber snake out the drain lines and the problem with the washer should disappear.
Jan 21, 2008 | Speed Queen AWS52NW Top Load Washer
Dishwashers Logo
98 people viewed this question
Top Dishwashers Experts
